Learn me on turbo rebuilding/replacement - Page 2 - Diesel Forum - TheDieselStop.com
 2Likes
Closed Thread
post #16 of 18 (permalink) Old 01-10-2019, 04:31 PM
RT
RT's Avatar
Obviously, you didn't read completely or maybe just didn't understand what I said. No, I've never had a failure. I know Googs did. He's a competent mechanic and his blew out in the middle of Australia.
My point was the parts are unit balanced. That information came from Garrett. Now, you obviously know better than the manufacturer since you know exactly how they assemble them and they don't. But, if you want to believe the guys that actually put them together, they are balanced TOGETHER as a unit. My analogy was like a tire and wheel are balanced TOGETHER. If you take a tire off a balanced assembly and then put a perfectly balanced tire back on that wheel, you can't expect the ASSEMBLY to still be balanced. Nowhere did I suggest that I would do that. It was an example. Of course, you have to be capable of abstract thought to process that, so I'm sorry if it blew by you.
Now - as a n=1 study, I did have my brand new balanced wheel installed on my existing exhaust shaft and then had that assembly balanced. They had to remove 0.17 grams to get it balanced. Now, that doesn't seem like a lot until you get in the 20,000 RPM range. Now according to your superior knowledge, they wouldn't have had to balance it at all.
jleedog likes this.
RT is online now
post #17 of 18 (permalink) Old 01-10-2019, 07:22 PM
klhansen's Avatar
My Photos: (180)
Keep it civil, guys. Different opinions are OK, but personal shots are not.
), AIS,
regulated return,
klhansen is offline
post #18 of 18 (permalink) Old 01-11-2019, 10:37 AM
69mach1377's Avatar
I balanced mine when I added a billet wheel upgrade, I didn't when I used the same wheels as was stock. For me it was cheap insurance and peace of mind. Some folks live life differently, to each his own.
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is offline
Closed Thread
