Locking Hub Questions? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 09-02-2007, 10:05 AM Thread Starter
Can you leave the hubs locked? I have a set of aftermarket wheels that have cabs that cover my hubs and make it impossible to lock the hubs without removing the 3 allens on each cap. Thanks!
06 F250 LARIAT CREW CAB 6.0, 35K MILES
smkmup is offline
post #2 of 7 (permalink) Old 09-02-2007, 11:34 AM
Re: Locking Hub Questions?
You can but you will be in 4wd full time and tear up something quickly.
Two ideas when combined together will always make a third better idea!
I don't have to be wrong for you to be right.
Kent
@235K miles @ 071127
>202K miles @ 070828
2001 F350 7.3 PSD SD CC DRW Lariat, 4R100 (replaced at 41k w/rebuilt by dealer), 3.73, FX4 ESOF, Long Box - 3rd CPS. CPS in Glove Box MOD. K&N Filter. 6.0 OTA Cooler. Green to Red Coolant. Water filter. 203 T-stat. Fumoto Valve. Monroe Gasmatic Shocks.
techkdb is offline
post #3 of 7 (permalink) Old 09-02-2007, 12:04 PM
Powerstrokedogg's Avatar
i don't think your going to hurt anything except your fuel economy.
back in the 70s dodges didn't come with lockouts, they were locked all the time
2001 F-350 7.3L 4X4(ESOF) CC LWB 4R100 4X4, WIX 46637 open element air filter, Wicked Wheel, walker BTM, 203* Tstat, IC tube foil removed, coolant filter, AIH removed, 08 aluminum finned rear end cover, DP tuner 80econ 140smoke high idle,Phantom gauges, ATS transmission,ATS deep trans pan, 5 star torque converter, V10 trans cooler, 4" MRBP SS downpipe, twin 4" stacks
1989 F-250 6.9L IDI E4OD 500,000+ miles(sold)
1982 VW rabbit 1.6L diesel
2007 Arctic cat 700 diesel ATV
1975 W900 Kenworth 500 Cummins
1997 Ford school bus 5.9 cummins
Powerstrokedogg is offline
post #4 of 7 (permalink) Old 09-02-2007, 12:06 PM
If you mean locking the hub but not the transfer your still going to "crow hop" and chop the tread on the tires if not something worse. You will also be turning gears and pull mpg down as stated above.
Not a good idea in general.
Kent
>202K miles @ 070828
techkdb is offline
post #5 of 7 (permalink) Old 09-02-2007, 12:09 PM
KF6ZVT's Avatar
You can lock the hubs manually and leave them that way. As long as the transfer case is in 2WD you will be OK. But you may have a slight decrease in fuel mileage, and perhaps a little more "road noise". The front wheels will have a little more rolling resistance.
I've lived in places where I locked the hubs at the first snowfall and unlocked them about the first of March. Never had a problem.
2001 F250 SC 4X4 Blue PSD Auto, Cody Gooseneck Hitch, Rancho Shocks and Steering Stabilzer, Tekonsha Prodigy Controller, Garmin Streetpilot 2610 GPS, Walker BTM, 285/75R/16E, Western Diesel Trans-Pyro-Boost, Pillar Mount, Painless fuse panel, In-tank and Pre-pump mods, Slotted Rear Rotors, Slotted and Cross Drilled Front Rotors, Fumoto Valve, Zoodad Mod, Transfer Flow 46 gal tank, Mag-Hytec Differential Cover, Electric Tailgate Lock, IAH Deleted, Coolant Filter, DP-Tuner 80 hp PCM, CCV Mod, 203 Thermostat, Ford AIS Air Filter
KF6ZVT is offline
post #6 of 7 (permalink) Old 09-02-2007, 01:55 PM
I bought a truck from a guy who did this, NOT a good plan, i had to replace the hubs and there is a inner needle bearing that supports the drive shaft (too support it as it enters the hub) and both sides where toast! pain in the butt to replace.
just my two cents
ford121 is offline
post #7 of 7 (permalink) Old 09-02-2007, 02:10 PM Thread Starter
Thanks for all the input...Just have to keep pullin off the old caps [img]/forums/images/%%GRAEMLIN_URL%%/frown.gif[/img]
smkmup is offline
