Long slow start - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 10-13-2018, 10:56 PM Thread Starter
Long slow start
Have a 2001 7.3 runs great but has developed a long start. Changed the oil pressure sensor on the head and it helped. But atill have a long start. No codes any ideas where to go from here?
chillidog10129 is offline
post #2 of 8 (permalink) Old 10-14-2018, 02:46 AM
I would check the glow plug relay and glow plugs, That is a easy DIY job with a multimeter. A search will give you the instructions on how to do it. If the batteries are in good shape my next place to look would be the starter. I have had three over the past 18 years that would turn the truck over but took too much current and the injectors would not fire properly. A good starter will spin the motor fast!! Once you go from a bad one to a good one you can really tell.
DENNY
DENNY is offline
post #3 of 8 (permalink) Old 10-14-2018, 05:01 AM Thread Starter
I should have added that i checked the gpr and plugs as well as the starter and batterues all good.
post #4 of 8 (permalink) Old 10-16-2018, 03:00 PM
brian42's Avatar
Just spitballin' but it sounds like it could be your HPO system bleeding down while the truck is off and it's taking a bit of extra time to make up the loss and get above 500 psi to fire the injectors.
Do you have any signs of higher than normal oil consumption?
The Money Pit
2003 F-250 7.3L PSD FX4 CCSB, Dual Alternators - 160/80 SS, T500, FRx, 6.0 IC & TC (w/Derale), S&B, RR 4/4 Wheel, EBPV-less, RR OCR, IH Up-Pipes, Hydra (PHP & GH), ISSPRO Gauges, FTVB, 4" MBRP, H&H, Racor PS120, 140A Alternators, North Stars, Dynatrac, XRF, ATS Springs
brian42 is offline
post #5 of 8 (permalink) Old 10-31-2018, 11:10 AM Thread Starter
Ok so i ran AE on the truck. Buzz check is good cold and hot. Contribution test good. Contribution readings on the cylinders where 0 except for the following: 3 varied from .5 to 1.5, 5 0 to 1, 8 2 to as high as 5.3. Also my injector oil pressure at idle hot is about 475 to 495. Ideas ?
2001 LWB 7.3l 4X4, DIY Bypass oil filter, Solid turbo pedestal, Leveling kit, Dyna Trac front end, True Trac Limited slip, DP Tuner, Glow Shift Gauges, Bellowed up pipes
post #6 of 8 (permalink) Old 10-31-2018, 03:12 PM
klhansen's Avatar
My Photos: (180)
With AE set to record the following parameters, crank the engine and record, then save the recording as an excel file and post it up. Or if you can graph the data, observe how fast the parameters rise to the min values needed to start.
Engine RPM (100 required to start)
ICP (500 psi required to start)
IPR Duty cycle (14%+/- at key on and rising to no more than about 35% is normal)
Fuel injector pulse width (1-6 msec needed)
Battery Voltage ( greater than 8 V cranking)
If IPR Duty Cycle goes much above 35%, that indicates leakage in the HP oil system. Could be injector o-rings.
Does it take the same cranking time to start whether hot or cold? If longer when hot, that also indicated leakage in the HP oil system, due to the hotter (thinner) oil getting thru the leak faster.
Your idle ICP looks normal, but you need to also observe IPR duty cycle at the same time. It should be no higher than 14%, and probably more like 11-12%. High IPR duty cycle indicates leakage in the HP oil system, with the IPR compensating for oil leaking out instead of building pressure to the injectors.
), AIS,
regulated return,
klhansen is offline
post #7 of 8 (permalink) Old 02-11-2019, 09:44 AM Thread Starter
Well finally got this figured out the starter was bad. Installed a new gear reduction unit and it starts like a champ. For all those that commented will pointers thanks for your input.
post #8 of 8 (permalink) Old 02-11-2019, 02:00 PM
klhansen's Avatar
My Photos: (180)
My crank speed was getting slow as well. I put in a rebuilt stock style starter and the difference in cranking speed is amazing. Spins like a top now.
Thanks for closing the loop on this.
), AIS,
regulated return,
klhansen is offline
