Low mileage 7.3L's. How many are left? - Diesel Forum - TheDieselStop.com
 62Likes
post #1 of 142 (permalink) Old 10-28-2012, 08:49 AM Thread Starter
How many miles does your have on it. Mine is a 2002, 6 speed manual and just has clicked over 23000 miles. Always been garage kept. Still has the original tires, batteries, the plastic protective cover has never been pulled off top of the carpet yet that came on it new and 100% stock.
L Johnson and atic like this.
2002 F-250, PSD, XLT, 4x4, SB, 3.73, 6 speed, x-cab, gooseneck, T-red
jltrent is offline
post #2 of 142 (permalink) Old 10-28-2012, 09:01 AM
Wow, I thought 98k on an '02 was low mileage!
2002 F350D, 7.3 PSD, 98k miles
ISSPRO EV2 trans. gauge
6.0 cooler, Ford/Donaldson AIS
Pacbrake, Updated PCM
2MileHi is offline
post #3 of 142 (permalink) Old 10-28-2012, 10:29 AM
ReefBlue's Avatar
When I hit 1,000,000 miles, I'll do a frame-off concours restoration and enter it at Amelia Island . . .
1999.5 F250 creeping up on 400k.
Check your wiring harness: Chaffed wiring at driver's valve cover.
Keep everyone (and yourself) updated:7.3 mileage and repair thread
If you insist on throwing parts at your truck to fix the problem, go big--don't forget the driver's side frame rail.
If your ICP connector has oil in it, change it. Don't argue, just change it. Don't check other things first, just change it.
ReefBlue is offline
post #4 of 142 (permalink) Old 10-28-2012, 01:51 PM
I wish my 02 only had 23K I'm at 235K at the moment.
2002 F350 CC PS DRW 4X4, AFE Stage 2 Intake, Rosewood Stage 1 injectors, DP Tune, 4" turbo back exhaust, X wheel compressor.
creteus is offline
post #5 of 142 (permalink) Old 10-28-2012, 02:07 PM
Just turned 114,000 on my 01
2001 F250 4x4
AIS Air intake
BTM muffler
RMZRacer723 is offline
post #6 of 142 (permalink) Old 10-28-2012, 02:09 PM
JimmyDee's Avatar
My Photos: (24)
I am about to turn 54,000 miles on my 01. Ford dealer offered me $10,000 for it on trade. Decided to run it another 11 years. It really runs like a dream for being 11 years old. New ball joints, manual hubs and anti sway struts @ $1000 and I think it will go easily until I'm 80 years old, if I live that long.
Jim
MrTommy and L Johnson like this.
2001, F250 4x4, CC, Auto; Mobil 1 in transfer case&Trans.; Frantz Bypass Filter; "Hutch" fuel mods; Sonnax/Tricum mod;
, 30" MagnaFlow; Attitude in A-Pillar and tranny gauge in
AIS; EASE Diagnostics; Reese Slider Hitch; Fr Rotors, Cryo Treated&Slotted by ART.
JimmyDee is offline
post #7 of 142 (permalink) Old 10-28-2012, 02:25 PM
01f25073's Avatar
Very uncommon for ANY 2002 model vehicle with 23K on it. JimmyDee, you should get at least $15K for a truck with that low of mileage. Go on kbb.com and see how much it tells you how much your truck is worth. You might be surprised, I know I was.
L Johnson likes this.
2001 F-250 4X4 CC SB 7.3 4R100 3.73, BFGoodrich All-Terrain TA/KO, Motorcraft filters, Mile Marker manual hub locks w/ESOF (No hub "floating"), AIH delete, Rust-Oleum bed coating, Silverstar Ultra headlamps w/ clear headlight assemblies, 5,000K LED interior lamps; Moog greaseable u-joints, ball-joints, front hub assemblies; retractable bed hitch, original black CPS (BEST "mod" I have), Energy Suspension bushings, Red Heavy Duty ELC, Edge Evolution 15001 (for gauges), Walker BTM, Donaldson AIS
01f25073 is offline
post #8 of 142 (permalink) Old 10-28-2012, 04:51 PM
klhansen's Avatar
My Photos: (180)
Not many creampuff trucks with that low mileage on them. If you keep that up, it'll be one of those "barn fresh" antiques you hear about.
You need to take that thing out and DRIVE it!!! It's not happy being cooped up in the garage.
I though mine was relatively low mileage at 150K for a teenaged truck. We have a shortage of roads around here. If I lived down in America, I'd probably be pushing 300K.
), AIS,
regulated return,
klhansen is offline
post #9 of 142 (permalink) Old 10-28-2012, 05:21 PM
Mine is 2000 with 84,000 on it.
scratcherky is offline
post #10 of 142 (permalink) Old 10-28-2012, 05:23 PM
2002F250's Avatar
My Photos: (13)
I have 120,000 on my '02 7.3. I've heard of guys paying upwards of $20,000 for a low mile 7.3, because of the cost and complexity of the newer trucks.
2002 F-250
Lariat, CC, SB, 4x4 Off Road, 7.3L, Auto Trans, 3.73 LS, AIS, Zoodad, Autometer Ultra Lite Boost, Pyro, Trans & Fuel Pressure Gauges, Walker BTM, IC Tube Foil Delete, DR 2" Leveling Kit, BFG A/T 285's, Door Seal Mod, Tranny Magnefine,
, Harpooned Tank, 4" rear blocks, ITP Overboost, DP-Tuner F6 No Start, Stock, 60E, 80E & 80T, JW Valvebody, PowerSlot Cryo Rotors w/Hawk LTS pads, Bilstein Shocks, Dieselsite Boots, Dieselsite Coolant Filter, Dieselsite 203* T-Stat, Prestone ELC, FRx R/R, IH Bellowed Up-Pipes, '08 Diff Cover, MBRP 4" Turbo Back Exhaust
To Do/Wish List: Turbo-Master, Wicked Wheel 2, Adrenaline HPOP
2002F250 is offline
post #11 of 142 (permalink) Old 10-28-2012, 05:37 PM
tickedoff36's Avatar
yeah wish mine was that low be like brand new i am 241K on 99 7.3 6spd
tickedoff36 is offline
post #12 of 142 (permalink) Old 10-28-2012, 06:56 PM
Greg03PSD's Avatar
I've got about 98,000 on my 2003.
2003 F-250 4x4, 7.3L PowerStroke
6" Skyjacker Z-link lift, 35" MT Baja ATZ tires
18" Wheels
Warn 16.5Ti winch w/ hidden mount
Front & Rear ARB Air Lockers
Dynatrac Free-Spin Front Hub Conversion
Edge Juice Programmer
Fabtech Ladder Bars
AutoEnginuity w/ Ford Enhanced package - New Hampshire seacoast - Just bring beer!
Greg03PSD is offline
post #13 of 142 (permalink) Old 10-28-2012, 08:24 PM
ArmyGuy45's Avatar
2000 100k miles.
23k miles is SWEET. Wish mine was a 6spd.
2000 F350 4Dr 4x4 7.3L Powerstroke
US Army 2005-Present
ArmyGuy45 is offline
post #14 of 142 (permalink) Old 10-28-2012, 08:41 PM
EXODUS's Avatar
Wow...23000 miles. That's awesome.
I have 13.739 miles for every one of yours on my truck!
Drive it in good health...peace.
RJV
1999 F-350 7.3 Super Duty Dually
5" Exhaust, Edge Juice Controller
Tymar Intake
Bilsteins
350K (so far)
EXODUS is offline
post #15 of 142 (permalink) Old 10-28-2012, 09:10 PM
My 01 was bought in September 2000 and has 83K. I'd have to question if I needed a diesel if it only has 23K on it. I only pull my fifth wheel once or twice a year and just keep mine to do that.
brotherxb is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Voodoo
