MAP readings? - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 18 (permalink) Old 05-13-2014, 05:13 PM Thread Starter
Originally Posted by YT90SC View Post
DO you have a tuner? Some tuners skew the MAP reading. The actual sensor output is spot on, but the calculated MAP (what you see on the readout) is wrong. If you have a tuner, load your stock program and recheck before you go spendin a lot of money.
YT90SC you were right. I returned the tuner to Stock program and it reads 14 psi. When I switch to any of the other programs it reads 12 psi. Why do they skew the MAP readings like that?
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
post #17 of 18 (permalink) Old 05-13-2014, 07:28 PM
blue99stroker's Avatar
possibly to prevent defueling in their higher hp tunes.
only thing i can think of.
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #18 of 18 (permalink) Old 05-14-2014, 11:29 PM
Griz, I am not sure at all why. blue might be right, or they might drop it to prevent overboost codes or keeping the wastegate closed longer or... or... maybe some of the tuner guys might weigh in on this...
Dad always said,"Knowledge is limited but stupidity knows no bounds."
YT90SC is offline
