Massive oil Leak - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 07-02-2019, 07:54 PM Thread Starter
Texkenusmc's Avatar
Massive oil Leak
I started my truck to let it chill of before taking kids to swim practice and when I came out the their was over a gallon of oil on the driveway. It was coming out the top of high pressure oil pump around the sensor. I guess the oring let go after 300,000+ miles. I have never heard of a leak here. I checked everywhere starting from the bottom starting with the oil cooler. But as soon as I opened the good it was obvious were it was coming from.
Texkenusmc is offline
post #2 of 6 (permalink) Old 07-02-2019, 08:53 PM
klhansen's Avatar
My Photos: (180)
Do you mean the top of the HPOP reservoir? That's the low pressure side, so you're lucky there, although it can go up to 75 psi or so. Replacing the o-ring is a cheap fix.
), AIS,
regulated return,
klhansen is offline
post #3 of 6 (permalink) Old 07-02-2019, 10:55 PM
2000F250-7.3's Avatar
Posting a picture would help. To help identify the leak.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #4 of 6 (permalink) Old 07-03-2019, 11:00 AM Thread Starter
Texkenusmc's Avatar
Yes top of the reservoir.
post #5 of 6 (permalink) Old 07-03-2019, 04:48 PM
ArcticDriver's Avatar
Could you post a photo?
Is it just an o-ring or something more?
SOLD:
ArcticDriver is offline
post #6 of 6 (permalink) Old 07-03-2019, 06:36 PM
klhansen's Avatar
My Photos: (180)
OP said the leak was around the sensor (actually a switch that senses a minimum oil pressure on the low pressure side and makes the gauge go to mid-range). That and the plug toward the driver's side are SAE boss o-ring style connections. The o-ring is trapped in a groove in the top of the reservoir between that and the sensor or plug. Same type of deal as the HPOP fittings and the ones in the oil lines to the heads, but a smaller size.
), AIS,
regulated return,
klhansen is offline
