missing coolant-1999 f250 7.3 197,000miles - Diesel Forum - TheDieselStop.com
 2Likes
  • 2 Post By RT
post #1 of 9 (permalink) Old 02-22-2019, 03:26 PM Thread Starter
For probably a year the coolant level in the reservoir bottle would run an inch low ever month or two. Topped it off each time. I made a 1000 mile trip and the coolant was 2 or 3 quarts low. I can't find any leaks. If the coolants going out the exhaust, how's it escaping? No coolant in the engine oil, can't see any oil in the coolant. Thanks
Early1999F250ccsb2wd, AIS air, Banks Power Elbow and 4" turbo back exhaust, 6.0 trans cooler.
johnbeck is offline
post #2 of 9 (permalink) Old 02-22-2019, 03:47 PM
When was the last time you changed the water pump? I started losing coolant at about 100k miles on the truck. There weren't any drips on the ground, or on the oil pan underneath, but I would have to top off coolant every couple of months. I finally took it to my mechanic to take a look at. He told me that when the water pump first starts leaking, its such a small amount that it evaporates before it can hit the ground, or gets thrown back under the truck motor as you're driving. I went ahead and had him change the water pump, and the leaking stopped. I only have to top it off an inch or so every 6 to 9 months now.
just my .02 cents worth
short_stuff
Y2K F250 CC PSD Auto, Short-bed Lariat, Woodland Green/Gold, ordered 07/10/99, born 09/12/99, delivered 10/08/99, Bed mat, Zoodad mod, Viper Remote Start Alarm, Fumoto valve, undercoated, 170k somewhat trouble-free miles (so far), Edge Evolution (60 HP setting), Pioneer DVD/CD/iPod/XM satellite, backup camera, aluminum camper shell to replace the ROLLX that I had on the bed
Repairs: CPS, Water Separator Valve assembly, rear axle bearings, VSS, batteries, brakes, alternator, serpentine belt (x2) and tension pullies, all 4 power lock actuators, water pump, air conditioning lines and compressor, battery cables, replaced the leather oem seat covers with very good leather replacements (found a great price from a place in Dallas that custom makes them)
2016 Subaru Outback (Wife's commuter car)
2016 Starcraft Autumn Ridge 29ft TT
1993 MonArk Sun/Spa 20 ft pontoon boat
short_stuff is offline
post #3 of 9 (permalink) Old 02-22-2019, 05:14 PM
RT
RT's Avatar
Mine does the same thing. It will stay one inch low all year long, but as soon as I fill it to the "full" mark, it will slowly work its way back to its happy spot. I've used dye, spent hours dabbing paper towels and searching with a flashlight - no leaks. It just doesn't like being that full. I quit fighting it years ago.
rv6a and jleedog like this.
RT is offline
post #4 of 9 (permalink) Old 02-22-2019, 05:18 PM
ArcticDriver's Avatar
Same here, about 1” lower than factory mark. I just used a black permanent marker and a straight edge to draw a 1” line at the level it likes.
Never had any noticeable loss of fluid in the years since then.
SOLD:
ArcticDriver is offline
post #5 of 9 (permalink) Old 02-26-2019, 02:43 PM
Funny, mine does the same the thing. I tried keeping it full but it always kept itself at the level it seems to like. Can't find leaks and nothing in the oil.
Late '99, F-250 7.3L, PSD, Super Duty, AT, 4X4, Crew Cab, 235 Mich tires, MBRP 4" Exhaust, 6-setting DP-Tuner (set for +80hp Econ mode), K&N Filter and Intake Tube, 203 thermostat, coolant filter, A-Pillar Isspro gauge set (pyro pre-turbo, trans temp, boost), Turbo Master Wastegate Controller, 6.0L tranny cooler, BTS valve body, rebuilt trans at 196K mi, bilstein shocks, HPOP rebuild, Fuel and oil crossover, Chevron Delo 400 10-40w, Zoodad mod, late model cup holder.
No time left for Drinking.
jdkluge is offline
post #6 of 9 (permalink) Old 03-09-2019, 03:35 PM
Mine is the same way, shouldnt there always be at least some in the reservoir even when it's hot? Just had my 2005 6.0 turbo in to have the coolant system inspected for leaks and they could only find one at the egr delete kit which they fixed. But still after I ran it 75 miles today, the reservoir is empty with the engine still hot. Any ideas?
Sent from my SM-G965U using Tapatalk
nathan.hoggatt is offline
post #7 of 9 (permalink) Old 03-09-2019, 04:03 PM
klhansen's Avatar
My Photos: (180)
When the engine is hot, the coolant tank level should be higher than when the engine is cold due to thermal expansion of the coolant.
Does the level come back up when the engine cools off? If so, it may be air in the system, otherwise, you have a leak somewhere.
), AIS,
regulated return,
klhansen is offline
post #8 of 9 (permalink) Old 03-09-2019, 04:44 PM
I'm not sure yet. I'm gonna check it in the morning and see if it comes back up.
post #9 of 9 (permalink) Old 03-10-2019, 09:44 AM
Update. I checked the levels this morning and it did not come back up. I'm wondering now if maybe a bad thermostat could cause the system to lose coolant out the degas bottle?
Similar Threads
1999 f250 4r100 7.3 stroker chris2020 '99 & up 7.3L Power Stroke Engine and Drivetrain 2 02-09-2012 11:49 PM
1999 F250 7.3 Wont start davestruck99 '99 & up 7.3L Power Stroke Engine and Drivetrain 1 02-19-2009 12:04 PM
Coolant swap mattdanbass 7.3L IDI Diesels (Not Power Strokes) 1 09-07-2007 07:46 AM
coolant additive for 6.0?? tlphlps E-Series Vans 58 03-19-2006 02:46 PM
Water pump life extension hint needed Gearhead'90 '99 & up 7.3L Power Stroke Engine and Drivetrain 29 11-30-2005 10:58 AM
