Need help no power - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 10-22-2019, 12:57 AM Thread Starter
Texkenusmc's Avatar
Need help no power
My truck was running fine and lost power and started missing. I limped it home my icp reads 460-500 psi at idle and 1250psi at 3,000 rpm. The ipr was 7.52% at idle and fuel pressure is at 54psi.
Texkenusmc is offline
post #2 of 15 (permalink) Old 10-22-2019, 01:09 AM Thread Starter
Texkenusmc's Avatar
I have a new ipr and icp in the glove box so I guess I will start their.
post #3 of 15 (permalink) Old 10-22-2019, 01:16 AM
klhansen's Avatar
My Photos: (180)
Did the SES light come on? Start by getting codes pulled.
), AIS,
regulated return,
klhansen is offline
post #4 of 15 (permalink) Old 10-22-2019, 01:58 AM Thread Starter
Texkenusmc's Avatar
No light had p1211
post #5 of 15 (permalink) Old 10-22-2019, 01:50 PM Thread Starter
Texkenusmc's Avatar
I am about to go run live data while driving and watch icp & ipr to see what is going on.
post #6 of 15 (permalink) Old 10-22-2019, 04:52 PM Thread Starter
Texkenusmc's Avatar
I just drove it and it was fine till it got up to temp then it feel on its face. Before it got hot idle to under load icp .69v-.85v 460psi-2700psi. The ipr 5-35%
Once it warmed up icp .8-3.9v 500-1800psi ipr was 9-92%
Also ran codes p1280,p1211,p0238, & p0475
post #7 of 15 (permalink) Old 10-22-2019, 07:44 PM
klhansen's Avatar
My Photos: (180)
Check your fuel delivery. Where are you reading fuel pressure from? Could be that your filter is clogged and you're only getting that 54 psi on the tank side of the filter and much less on the injector side.
A lack of fuel can cause a P1211 code.
I can give you more things to look at based on your codes later. P1280 can be caused by an unplugged ICP sensor or a problem with the wiring to it. I would check that also.
), AIS,
regulated return,
klhansen is offline
post #8 of 15 (permalink) Old 10-22-2019, 08:39 PM Thread Starter
Texkenusmc's Avatar
I did 50psi good fuel pressure coming of the fuel bowl with a Gage.
post #9 of 15 (permalink) Old 10-22-2019, 08:42 PM Thread Starter
Texkenusmc's Avatar
Plus it only happens once the truck gets up to temp. I just hope it is not something with injectors. I am in the middle of remodeling the house. I don't need a Big job.
post #10 of 15 (permalink) Old 10-22-2019, 09:48 PM
klhansen's Avatar
My Photos: (180)
You might try unplugging the Engine Oil Temp sensor on the back of the HPOP reservoir. There's a slight chance it might be affecting the ICP signal. My vote is on a wiring issue, though.
Here's some info on the two ICP codes.
  • DTC P1209 and P1211 indicates that injection control pressure was above or below desired level under normal driving conditions.
  • Possible causes:
    • incorrect oil or viscosity
    • poor oil quality
    • gel fuel/no fuel
    • low fuel pressure
    • damaged IPR valve
    • high-pressure oil system leak
    • damaged high-pressure oil pump
    • damaged PCM
  • DTC P1280 indicates injector control signal circuit out of range low was detected during KOEO Self Test or during continuous diagnostic monitoring.
  • Possible causes:
    • biased ICP sensor/PCM
    • open ICP sensor circuit
    • short to SIG RTN or PWR GND on ICP sensor circuit
    • open in VREF circuit
), AIS,
regulated return,
klhansen is offline
post #11 of 15 (permalink) Old 10-25-2019, 08:52 PM Thread Starter
Texkenusmc's Avatar
Thanks for the help. It ended up being the icp sensor and pigtail. I changed it and running like a champ.
post #12 of 15 (permalink) Old 10-28-2019, 10:09 PM Thread Starter
Texkenusmc's Avatar
Thought I had it fixed but it is doing it again. Going it is just the cheap after market sensor. Will replace it again tonight after checking codes and reading live data
post #13 of 15 (permalink) Old 11-03-2019, 03:30 PM Thread Starter
Texkenusmc's Avatar
I am starting to think my problem might be with uvc harness or injector o- rings On my injectors
post #14 of 15 (permalink) Old 11-05-2019, 07:42 PM Thread Starter
Texkenusmc's Avatar
The issue ended up being the ipr. I had changed the screen in the hoop reservoir and some junk must hand got in the ipr.
post #15 of 15 (permalink) Old 11-06-2019, 06:57 PM
losfinch's Avatar
Glad you got her figured out. Thanks for posting the end result!
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny (2nd one :-), 31 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Stancor HD Glow Plug Relay, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
rkick1960
