Neglected 7.3L project. - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 11-07-2018, 06:00 AM Thread Starter
So I purchased a neglected 7.3 that needs injectors. However, I will do a compression test when I get things open and I am a little concerned that I may get poor results. I plan on having everything ready to proceed with the injectors should compression be ok.
1) Assuming all cylinders are in the same range, what is the lowest psi I should accept and go ahead with injectors?
2) If compression is bad, I plan on sending the injectors back and pursuing a rebuilt long block.
3) If #2 is the path, what is the best source for a rebuilt long block?
Thanks.
2000 7.3 F350 4x4 160,000 miles
Truck is a farm truck that will probably see less than 10k miles a year. Will pull an occasional heavy trailer.
'01 F350 DRW Stock
ISSPRO gauges
Automatic trans
MarkMCM is offline
post #2 of 4 (permalink) Old 11-07-2018, 10:59 PM
klhansen's Avatar
My Photos: (180)
Unless your truck has been really neglected, such as dust getting by the filter into the engine for a long time, I'd expect with your mileage, your compression test will be fine probably in the 350 psi range. If you find one or more cylinders below 75% of the highest (say 300 psi versus a high of 400 psi), that would indicate a problem with the base engine. If an engine has been dusted, the center two cylinders on each bank would test lower than the end cylinders. There's really no spec for lowest compression on all cylinders overall, but if there are starting problems that aren't caused by glow plug or other issues like low cranking RPM, that indicates a worn engine.
Again, my guess is that you won't have any base engine issues at 160k miles. It's barely broken in.
), AIS,
regulated return,
klhansen is offline
post #3 of 4 (permalink) Old 11-08-2018, 03:25 PM Thread Starter
Thanks. I'll keep my fingers crossed on the compression test.
'01 F350 DRW Stock
ISSPRO gauges
Automatic trans
MarkMCM is offline
post #4 of 4 (permalink) Old 11-21-2018, 06:55 PM Thread Starter
Ok. Motor shows significant blowby through the oil filler tube.
Compression readings:
1-310
3-300
5-310
7-300
2-300
4-290
6-275
8-140
These are cold readings. A squirt of oil into #8 makes no difference. #8 bleeds the pressure off pretty quickly.
Any other tests I should do, or just move to the next phase. Rebuild/replace.
'01 F350 DRW Stock
ISSPRO gauges
Automatic trans
MarkMCM is offline
