No Cranking After Charging Batteries - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 09-21-2019, 11:37 AM Thread Starter
I hope someone can help. I have a '99 F350 later 7.3 with about 185,000 miles on it. It was used to drive to and from work (20 miles a day). I retired 2 years ago and it hasn't been run regularly. I use it about once a week. About 3 months ago I noticed it was starting as if the batteries were low. I figured the batteries (5 years old) might be losing power from sitting unused because once I ran the truck it would start again as if they were fully charged with no problem. Yesterday after not running the truck for about 10 days, I went to start the truck and it would crank as if the batteries were very low but would not start. I put my charger on it and set it to 40 amps starting mode and the engine started like normal. I turned off the engine, removed the key and left the charger on it for about two hours to bring the batteries back up. When I went to start, all of my dash lights and the WTS lights functioned normally and I could hear the glow plug relay click like normal. When I turned to crank, there was one click from the passenger side near the firewall and nothing else. Total dead silence. There were no accidents/shorts when connecting or removing the charger. DTC codes P1670 and P0541 show on monitor. I have checked the fuses related to starting in both boxes and have found nothing. I have tried starting in neutral, park and while jiggling the automatic shift all with the same result. I removed and again cleaned the battery terminals. The batteries show 12.6 and 12.4 and when the key is turned to crank they only drop to about 11.9 to 12.2. I'm baffled. It started like a champ and after charging nothing. The funny part of this is I was planning on trading in or selling the truck this week and I think the truck heard me.
Winchar is offline
post #2 of 7 (permalink) Old 09-21-2019, 12:07 PM
bugman's Avatar
My Photos: (12)
Start with checking the connections at the starter along with the wiring going to the starter. Along with the ground wires to the block.
Your battery voltage is showing that there is no draw on the batteries other than the glow plugs.
bugman is offline
post #3 of 7 (permalink) Old 09-21-2019, 12:26 PM
ArcticDriver's Avatar
Out of curiousity, what Amp did you charge the batteries at?
Did you hook the 40-Amp up the second time you tried starting the truck (after the full charge)?
Odds are your 5-year old batteries are pretty worn out. The only downside to replacing them before sale is the warranty does not transfer to new owner.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is online now
post #4 of 7 (permalink) Old 09-21-2019, 01:29 PM Thread Starter
I won't be able to work on the truck until Monday, but I will check the grounds.
Winchar is offline
post #5 of 7 (permalink) Old 09-21-2019, 01:39 PM Thread Starter
I made the mistake of leaving the charger still set at 40 amps when it was charging. The batteries were still showing 12+ when disconnected from the truck after charging. I reconnected the batteries to the truck and then connected the charger and tried cranking at the 40 amp setting but the result was the same, just the one click from the passenger firewall side (starter relay?)
Winchar is offline
post #6 of 7 (permalink) Old 09-21-2019, 02:41 PM
You most likely have a bad connection.
DENNY
DENNY is offline
post #7 of 7 (permalink) Old 09-28-2019, 05:23 PM
van_350sd's Avatar
My Photos: (80)
I had the same problem, bought 2 new batteries and now it's good.
I bought the AGM type batteries Duracell from Sams Club, 170.00 each
2000 E350-Super Duty Ext. Mobile LivingRoom-7.3LPSD
van_350sd is offline
