No response from accelerator - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old Yesterday, 09:36 AM Thread Starter
Could use a little help with my 01 f350. Sometimes I get no response from my gas pedal at idle and have to push the pedal a couple times before it will rev the engine. This has also happened a few times when I let off the pedal at slow speeds. While it’s happening the check engine light will come on and once the gas pedal starts working properly, it will go off. Thanks for any help.
Thanks.
01 F-350 7.3 crewcab,longbed, Lariat, 4" DPPI 4 inch exhaust, severe air intake, Sonnax/Tricumulator, Prodigy brake controller and Rhino bedliner.
mike_sp is offline
post #2 of 7 (permalink) Old Yesterday, 12:51 PM
klhansen's Avatar
My Photos: (180)
A scan tool will tell you what's wrong, but most likely, your Idle Validation Switch on the Accelerator Pedal assembly is sticking. The pedal assembly comes out easily, and has two electrical connectors on it. The connector with 2 pins goes to the IVS and the 3-pin connector goes to the AP Position Sensor. I would pull the assembly out and hit the IVS (and the APPS -can't hurt) with some electrical contact cleaner. Reinstall and see if that fixes up your problem.
), AIS,
regulated return,
klhansen is offline
post #3 of 7 (permalink) Old Yesterday, 03:07 PM Thread Starter
Thanks, Iíll look that way. I did check and it shows no codes were thrown.
mike_sp is offline
post #4 of 7 (permalink) Old Yesterday, 04:17 PM
klhansen's Avatar
My Photos: (180)
What did you use for a code reader? The generic ones won't work on your truck. It takes a PSD capable scan tool. If the Check Engine Light was on, there WILL be a code stored.
), AIS,
regulated return,
klhansen is offline
post #5 of 7 (permalink) Old Yesterday, 04:44 PM Thread Starter
Oh. Okay, Iíll see if I can find one. I did take off the pedal assembly and I have only one five pin connector on it. I cleaned the contacts and see if that cures the problem. Thanks.
mike_sp is offline
post #6 of 7 (permalink) Old Yesterday, 07:30 PM
klhansen's Avatar
My Photos: (180)
Hmm, I could have sworn the '01 still had the pedal with two connectors.
Quite a few guys use AutoEnginuity that runs on a laptop. About $360 for the Ford Enhanced package which you'll need.
What needs to be cleaned is the pivot point on the actual switch, as opposed to the connector pins.
), AIS,
regulated return,
klhansen is offline
post #7 of 7 (permalink) Old Today, 09:33 AM Thread Starter
Again thanks for the info. Iíll take it back off and clean the pivot point.
mike_sp is offline
