Noisy clutch - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 11-15-2018, 11:56 PM Thread Starter
Noisy clutch
I’m getting a lot of noise when shifting. Replaced hydraulics about 6 months ago, now have a deep growl and rough feeling clutch pedal. Is this the sound of impending doom of the throwout bearing, pilot bearing or? Truck is a 1999.5 with 126500 on it. TIA
Buffalohead1 is offline
post #2 of 10 (permalink) Old 11-16-2018, 01:10 AM
klhansen's Avatar
My Photos: (180)
My guess would be a worn throwout bearing, but noises can telegraph all over the place.
About the only way you could find out for sure would be to pull the tranny.
), AIS,
regulated return,
klhansen is offline
post #3 of 10 (permalink) Old 11-16-2018, 06:56 AM Thread Starter
I was pretty sure that was the case. Any brand throwout bearing better than another? I figure if I need to pull the transmission I’ll put bellowed uppipes in too, since the right side has a good leak when cold that is getting worse. What about the clutch fork? I recall there was an improved one for different years.
post #4 of 10 (permalink) Old 11-16-2018, 06:56 PM Thread Starter
Well, I think the whole thing is toast now. Pulled my horse trailer about 250 miles and pedal feels really coarse and have to be real quick to shift gears or even pump it in neutral to make the shifts. Any recommendations for a 300 HP clutch?
post #5 of 10 (permalink) Old 11-16-2018, 09:13 PM
klhansen's Avatar
My Photos: (180)
I've got a South Bend ConOFE in mine, and happy with it. They're a little spendy and you'll need the entire kit, including flywheel. Another option is a LUK clutch, available thru NAPA stores, but I have no idea what HP they're rated for. Both will give you a very light clutch pedal feel and you may need to remove the pedal assist spring on the pedal to keep it from sticking to the floor at higher RPMs.
Good idea on replacing the up-pipes when the tranny is out. Makes it a LOT easier.
Your truck likely has the older weaker clutch fork, I know that my 1/99 build truck did, and although I never had problems with it, I replaced it when I put the SB clutch in. IIRC, South Bend's kits come with a throwout bearing, and can supply a clutch fork as well. I think they source them both through Ford, so you could buy them thru your local dealer or order from AutoNation Ford White Bear Lake (site sponsor who sell at a discount.)
), AIS,
regulated return,
klhansen is offline
post #6 of 10 (permalink) Old 11-19-2018, 12:57 PM Thread Starter
This morning can’t even push clutch in. Started it by jumping the starter solenoid to have steering and brakes and pushed it in front of my shop. Lots of metal grinding smoke like throwout bearing chewing on clutch diaphragm I hope. Guess I’ll see what’s trashed next week.
post #7 of 10 (permalink) Old 11-21-2018, 03:30 PM
ArcticDriver's Avatar
Hows the projrct going?
SOLD:
ArcticDriver is offline
post #8 of 10 (permalink) Old 11-21-2018, 05:14 PM Thread Starter
Haven’t touched it yet. Was in the middle of replacing windows and siding on my house when it quit. I will update when I pull it apart.
post #9 of 10 (permalink) Old 03-20-2019, 12:12 PM Thread Starter
Replaced with SouthBend clutch and hydraulic system. So much lighter and smoother. Throwout bearing had blown apart. Clutch fork nearly chewed through. All on the road again!
post #10 of 10 (permalink) Old 03-21-2019, 02:16 AM
klhansen's Avatar
My Photos: (180)
Cool! Glad you got it going again.
Thanks for the update.
), AIS,
regulated return,
klhansen is offline
