Normal IPR Duty Cycle and ICP Readings? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 05-24-2012, 12:49 PM Thread Starter
Can someone tell me what the normal IPR duty cycle % and ICP pressure readings are at idle, normal cruising speeds (60-65mph) and WOT?
Just curious...
Thanks,
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
post #2 of 9 (permalink) Old 05-24-2012, 06:20 PM
Here is a bit of info copied;
ICP should be over 500 but 480-550 is normal Spikes to 2200 while cranking
ICP DC or aka IPR should be between 10-15% as well as Accelerator Pedal Position between 10-15%
WOT ICP DC should not exceed 65% and ICP should not drop below 1800PSI with Pedal Position between 70-80% Take out chip as rev limiter may be disabled with it in.
EXBP should be 10-15psi with EBPV closed and not exceed 45psi at WOT
EXBP showing low (3-5psi) that barley rises with acceleration indicates bad sensor or plugged tube.
Hope it helps some. Seldom do the ICP readings reach 2500 but if you do your truck is awesome.
2001 Excursion Limited Auto trans many buttons I still am finding. Factory 3 inch lift low mileage. 100% stock today we will see what tomorrow brings.
Living the dream 1-1/4 miles closer to heaven.
mtnsammy is offline
post #3 of 9 (permalink) Old 01-07-2015, 05:20 PM
rammertide07's Avatar
Send a message via MSN to rammertide07
Where did you find that info?
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes/160/stock FFD/PowerSlot rotors and green EBC pads/
/MM Hubs/Hood/HPx/FRx/
rammertide07 is offline
post #4 of 9 (permalink) Old 01-07-2015, 08:28 PM
Not sure where he found it, but it seems a bit outdated and incorrect.
post #5 of 9 (permalink) Old 01-07-2015, 09:12 PM
petwolf's Avatar
Can someone give us a more accurate list for our trucks? I am curious too as my duty cycle is way low while ICP is way high as far as I can tell. Kinda need more info before my 132k motor grenades in my driveway much to the wifes pleasure.
2000 F350 Lariat auto 4x4 cc Dually hutch/harpoon mod, zoodad mod, prepump filter/separator, billet fpr gold spring DIY Tymar intake
petwolf is offline
post #6 of 9 (permalink) Old 01-07-2015, 11:50 PM
It's not going to blow.
Maryland dieselnick is offline
post #7 of 9 (permalink) Old 01-08-2015, 12:02 PM
petwolf's Avatar
I sure hope not. Any ideas on a more accurate list or chart?
petwolf is offline
post #8 of 9 (permalink) Old 01-08-2015, 12:40 PM
What happened? Did you check those things?
post #9 of 9 (permalink) Old 02-02-2015, 12:37 AM
Did you find additional information?
Charlie Davis is offline
