Oil Change time...T6 still ok in the 7.3? - Diesel Forum - TheDieselStop.com
 2Likes
  • 1 Post By Absolute
post #1 of 15 (permalink) Old 04-15-2019, 05:27 PM Thread Starter
N_E_T_O's Avatar
Hey all,
It's been a while since I've posted. Still have the 01 7.3 in my sig and it's been running great! We only put a couple thousand miles on it per year and I change my oil every 5000 miles. I've been using the Rotella T6 (5-40) synthetic for years and years and it's due again. Last time I changed it was in 2017, almost 5000 miles ago.
I found a note that I wrote myself (about a year ago I think) in my truck that says: "When it's time to change the oil, find out if T6 is still ok after they changed the formulation and rating from CJ-4 to CK-4". I must have been surfing and found the CJ4/CK4 discussions...
So...is the T6 still good to go in my 7.3? I know the CK4 formulation is supposed to be better for the newer trucks to make the emissions cleaner, but to be honest, I really just care about the longetivity of my 7.3 diesel engine.
After an exhaustive search, I've found nothing but speculation and opinion. Would like to hear from you guys.
If the T6 is NOT ok...what is suggested?
Thanks in advance!
Randy
2001 F350 Lariat PSD, 4x4, 4DR CC SB, purchased 2/27/07. Ford AIS intake with Fender Sleeve (added 4/2/07), ZooDad mod (7/14/07), Pillar Gauges (ISSPRO) EGT, Trans Temp and Boost (added 3/21/07), Dynomax 4" turbo back exhaust (added 3/9/07), 2 inch leveling kit, 285/70-17 Toyo Open Country II's, Huskyliner floor mats, Rear Airbags, TopDeck Tonneau Cover (added 4/3/07), Excursion "Hush Panels" under the dashboard. Factory Forged Rods, 25 row 6.0 Trans Cooler upgrade, added 8/27/09. Bushwacker Pocket Style Fender Flares and chrome door handles/mirrors (4/2014), DP-Tuner w/60TowHeavy, Decel, 80TowLight, 80Daily, 80DailyMountains and 120hpRace installed 5/15/2014.
N_E_T_O is offline
post #2 of 15 (permalink) Old 04-15-2019, 06:31 PM
Absolute's Avatar
Lots of guys here still using it. I never heard of any problems with it. I don't use it, my truck doesn't like it. If they come out with a 15/40 synthetic, Id try that.
ArcticDriver likes this.
Absolute is offline
post #3 of 15 (permalink) Old 04-15-2019, 06:37 PM
Walmart has 15/40 T6 synthetic on the shelf
Buffalohead1 is offline
post #4 of 15 (permalink) Old 04-16-2019, 03:25 AM
ArcticDriver's Avatar
For HDEO, I usually just hear of T6 in 5w40 (Full synthetic) or T5 in 15w40 (Semi-Synthetic).
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is online now
post #5 of 15 (permalink) Old 04-16-2019, 03:31 AM
N_E_T_O,
Shell Rotella T6 5w40 in the new CK-4 is listed as "Approved" by Ford at the bottom of Page 01.
https://www.fcsdchemicalsandlubrican...SSM2C171F1.pdf
(Let us know if you notice any difference using this new CK-4 compared to your years of CJ-4 if you get a chance.)
SOLD:
post #6 of 15 (permalink) Old 04-16-2019, 06:34 AM
Absolute's Avatar
Not in Canada. No such thing as 15/40 synthetic up here. Only 0 and 5/40. Had to get royal purple one time. It was all that was available in synthetic. Its crap, never use again. Up here the 15/40 is the T5.
Thanks for trying to help though.
Absolute is offline
post #7 of 15 (permalink) Old 04-16-2019, 11:41 AM
JJEdwards's Avatar
The T6 15/40 was just recently introduced by Shell and is now available in some areas. 5/40 is better for cold weather starts.
2000 7.3 PSD 4x4 Auto Trans., CC, short box 207,500 miles.
PHP Hydra, Bilstein 5100's, Bilstein steering stabilizers, Auto Meter 3 gauge pod--EGT, Trans Temp & Boost, Deep Trans Pan, Rotella ELC and T6 oil, DieselSite 203*, Riffraff Billet wheel, 4" turbo back MBRP 5" straight pipe, Donaldson 6637 blue, 20" Fuel wheels wrapped with 37" MT's
Security: Ravelco (for the pro's), Viper (for the rookies), The Club 1100 Steering Wheel Lock (visual deterrent).
JJEdwards is offline
post #8 of 15 (permalink) Old 04-16-2019, 05:49 PM
I ran the "new" T6 formula in my truck once and noticed absolutely no difference from the previous one. That being said Last oil change I switched to Mobil TDT synthetic. it is 5-40 synth as well. I paired it with a mobil oil filter vs the motorcraft 1995 that I usually run....(availability was main reason for switch not that I had eve had an issue with either the oil or filter)
I will say that I think the mobil TDT oil stayed cleaner for a fair amount longer than the T6 did.... for whatever that is worth... as far as performance or noise..cant really tell a difference
gamewarden3006 is offline
post #9 of 15 (permalink) Old 04-16-2019, 07:17 PM
Good to know.
Thanks, I am reading about it now on BITOG.
I may switch to this in my bikes.
SOLD:
post #10 of 15 (permalink) Old 04-16-2019, 08:05 PM
And page 9 of Fords Approved oils does include T6 15w40.
SOLD:
post #11 of 15 (permalink) Old 04-16-2019, 08:16 PM
bugman's Avatar
My Photos: (12)
Just because the oil stays "cleaner" longer does not mean that it is doing it's job. You can have oil that is a black as night and it will still be working, keeping its viscosity and additives that it started with. Clean oil can break down and loose both and still look like the day you poured it out of the container.
bugman is offline
post #12 of 15 (permalink) Old 04-16-2019, 08:19 PM
Here is Shell webpage:
https://rotella.shell.com/en_us/prod...lla-15w-40.pdf
SOLD:
post #13 of 15 (permalink) Old 04-19-2019, 10:27 AM
Absolute's Avatar
Oh Ok! That's good info. SO, the T6 is better then. Havnt tried mobil myself but knowing it does a terrible job cleaning my motor is good info. Cant imagine leaving all that crap in my super motor. Spent a lot of money on this puppy.
Absolute is offline
post #14 of 15 (permalink) Old 04-22-2019, 11:13 PM
I was running Rotella T6 5W-40, but that was before CK-4 oils came out. I still had a pretty good stash of CJ-4 oils to work with, but I've only got enough for one more oil change.
I'll steer clear of CK-4 oils. Here's why:
Next time I buy oil, it'll be Schaeffer Supreme 9000 Full Synthetic Oil 5W-40, it's still CJ-4, for now. If I'm on the road and need oil, I'll stick with the WSS-M2C171-F1 oils with the Motorcraft logo on the bottle.
2002 F-250 CCLB 4x4 XLT, 7.3, ZF-6 with Midwest Short-throw shifter, ESOF, 3.73 R&P, HPx line, FRx, Racor prefilter before pump, Amsoil bypass filter, Coolant filter too
txgp17 is offline
post #15 of 15 (permalink) Old 04-23-2019, 08:45 AM
Absolute's Avatar
Thanks, Ill look for the 15/40. As stated earlier. My truck cant stand 5/40. It doesn't like it at all.
JJEdwards likes this.
Absolute is offline
Similar Threads
Bulletproof Diesel Oil Cooler INSTALL -Snake- Upgrades and Aftermarket - 6.0L Engine 7 10-12-2012 11:42 AM
High Pressure Oil Pump / Top End Oil Change firemediceric '99 & up 7.3L Power Stroke Engine and Drivetrain 45 12-22-2009 03:50 PM
