Over boost - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By 79jasper
post #1 of 3 (permalink) Old 08-09-2018, 09:43 PM Thread Starter
Over boost
I am going to install a new Wicked wheel 2 and 1.0 housing on my turbo. Will the 7.3 defuel with a overboost? or just pull a code
2001 Ford F250 4x4 CrewCab 7.3 Automatic, 4 inch MBRP exhaust, Diablosport Predator, Edge evolution (monitor only), Cold Air intake,
Andrew Hubert is offline
post #2 of 3 (permalink) Old 08-09-2018, 10:41 PM
79jasper's Avatar
Both.
Tuning can defeat it.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Andrew Hubert likes this.
79jasper is offline
post #3 of 3 (permalink) Old 08-10-2018, 06:12 PM
jleedog's Avatar
It will defuel at 23 psi if I remember correctly. You can prevent this with a boost fooler, or most programs will prevent it as well, but you will still get a light unless you put in a boost fooler.
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
