p1316 dtc - Diesel Forum - TheDieselStop.com
post #1 of 18 (permalink) Old 02-11-2019, 07:07 PM Thread Starter
larry-56's Avatar
p1316 dtc
2003 Ford F-250 7.3 liter faulting dtc p1316 but the engine is running fine I clear the code and it comes back as soon as I start the truck any help would be appreciated.
Thanks Larry
2003 f250 super duty 7.3
supercab long bed
4" exhaust with 5" magnaflow tip
Hypertech power programer III
larry-56 is offline
post #2 of 18 (permalink) Old 02-11-2019, 07:13 PM
Absolute's Avatar
P1316 Injector Circuit / IDM Codes Detected, run a buzz test to get the IDM codes.
Absolute is online now
post #3 of 18 (permalink) Old 02-11-2019, 07:51 PM Thread Starter
larry-56's Avatar
Thanks, ran the buzz test and code p1277 high to low side open cylinder 7 any ideas where to go now
supercab long bed
larry-56 is offline
post #4 of 18 (permalink) Old 02-11-2019, 11:36 PM
klhansen's Avatar
My Photos: (180)
Replace the Under Valve Cover Harness on the passenger side. Could be external to the valve cover, but the UVCH issues are common. You're likely just running on 7 cylinders.
), AIS,
regulated return,
klhansen is offline
post #5 of 18 (permalink) Old 02-12-2019, 05:42 AM Thread Starter
larry-56's Avatar
klhanson, thanks for the reply. So just one question the engine runs really smooth no noticeable miss is that possible on 7 cylinders thanks for your help this thing is driving me crazy
Larry
supercab long bed
larry-56 is offline
post #6 of 18 (permalink) Old 02-12-2019, 09:36 AM
2000F250-7.3's Avatar
Larry
As Klhanson said Check the harness under the valve cover either has come loose a bit or is needing replaced.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #7 of 18 (permalink) Old 02-12-2019, 12:35 PM Thread Starter
larry-56's Avatar
Thanks, Iím going to check the under valve cover harness tomorrow.
supercab long bed
larry-56 is offline
post #8 of 18 (permalink) Old 02-12-2019, 02:11 PM
The "hansen" feller knows. Good luck, I'm betting you'll find your issue.
By the way, greetings from a fellow 7.3 owner ~100 miles up I-81.
2001 Lariat, F250, 7.3, 6-speed, 3:73, Ford AIS, MBRP 4" turbo back, ATS ported housing, 205į t-stat, Infinity DX w/DP Tuner 80hp tow, coolant filter, Hutched & Harpooned, EGT & Boost gauge. Fuel Mavericks with 285/18, 86k miles(Jan-2017) Bought brand new April 2001.
aclasshog is offline
post #9 of 18 (permalink) Old 02-12-2019, 02:46 PM
klhansen's Avatar
My Photos: (180)
These engines will run fairly smoothly with a dead miss on one cylinder. They'll also run on just one bank of cylinders at idle, but that would be noticeably down on power.
), AIS,
regulated return,
klhansen is offline
post #10 of 18 (permalink) Old 02-13-2019, 03:53 PM Thread Starter
larry-56's Avatar
Ok so I replaced the uvch today cleared the codes started the engine and the code p1316 came back ran the buzz test faulted p1277 high to low side open cylinder 7 same as before. Could it be the IDM?
Thanks fo any help Larry
supercab long bed
larry-56 is offline
post #11 of 18 (permalink) Old 02-13-2019, 04:14 PM
Hi did the truck run better or the same. I would move that injector to cylinder 5 and put five in 7 and retest if it fallows the injector its the injector if it does not then I look at the idm. You could also check resistance with a multimeter on the injector coil on the other injector coils and compare to 7 be for you swap them.
post #12 of 18 (permalink) Old 02-13-2019, 06:04 PM
klhansen's Avatar
My Photos: (180)
I agree completely. First check the resistance across each injector. Should be around 2-5 ohms, IIRC. You can do that from outside the VC. The pin to Injector 7 will be two pins back from the center pin on the connector. The center pin is common, and the location to each injector corresponds with it's position on the engine.
Solenoid coils don't go out that frequently, but it happens. If you find that #7 solenoid coil bad, you can just swap the solenoid with a core injector or order a coil from an injector rebuilder. No real need to pull the whole injector.
Also check where the harness runs across the driver's side valve cover for chafing. That's easily fixed with some electrical tape.
Another thing to do before condemning the IDM (assuming you find everything OK at the injectors and valve covers) is to run a continuity check between the valve cover connectors back to the IDM. The open circuit can be anywhere between the two. IDMs don't go bad that often.
The pins at the valve cover gasket where the wiring connects can also be corroded.
), AIS,
regulated return,
klhansen is offline
post #13 of 18 (permalink) Old 02-13-2019, 07:15 PM Thread Starter
larry-56's Avatar
Thanks for the replyís. The truck ran about the same but I do have a little miss at cold start not plugged in but after it warms up it runs fine itís been doing that for a while with no check engine light. I checked the resistance and all were 3.3 ohms
I will check the wiring on the drivers side valve cover for chafing. I had an issue with chafing wires on the valve cover about 10 years ago and it affected all 4 cylinders on drivers side taped the wires and put some insulation around the wires and no issues since.
There is no corrosion on the plug or valve cover pins but I cleaned those with some electrical cleaner just to be safe side. I will also check the wiring from the IDM to the valve cover
Thanks Larry
supercab long bed
larry-56 is offline
post #14 of 18 (permalink) Old 02-14-2019, 12:46 PM Thread Starter
larry-56's Avatar
Hey guys,
Iím still trying to figure out what is going on with this truck. So this morning I checked all the wires on the drivers side harness above and the valve cover no chafing that I could see.
So yesterday afternoon I checked the codes again and got new code p0475 and still had the p1316. Ive had the ebpv unplugged for years with no check engine light so i thought I would plug it back up and maybe the p0475 would go away but it did not but the p1316 did wit it unplugged I get both, plugged up i just get the p0475. Iím really confused now it doesnít make any sense to me.
Thanks Larry
supercab long bed
larry-56 is offline
post #15 of 18 (permalink) Old 02-14-2019, 07:07 PM
klhansen's Avatar
My Photos: (180)
That's strange. The EBPV circuits should have no affect on the injector circuits. You might have a short between circuits somewhere. Probably going to be real hard to find.
), AIS,
regulated return,
klhansen is offline
Similar Threads
Wrench Light - Limp Home Mode vwsportbug 6.0L Power Stroke Engine and Drivetrain 16 11-15-2013 01:03 PM
Glow Plug Codes Dooner '99 & up 7.3L Power Stroke Engine and Drivetrain 8 11-12-2013 04:56 PM
7.3L Trouble Codes HoustonTrimIII Power Strokes 1994-1997 General 0 01-29-2012 09:55 AM
Help Please ! ballz Power Strokes 1994-1997 General 6 02-20-2008 01:40 PM
DTC p1316 IDM rikx500 '99 & up 7.3L Power Stroke Engine and Drivetrain 5 01-14-2007 09:36 PM
