p1316 dtc - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 26 (permalink) Old 02-14-2019, 07:40 PM Thread Starter
larry-56's Avatar
Yeah i know what you mean, not sure which way to go now the really weird thing is the engine is still running strong . thanks for your help if you can think of anything else let me know iím going to unplug the ebpv and go from there. Iím going to see if I can trace the ebpv wires and see if possibley they are in the same wire loom as the injector circuits wish me luck.
Thanks again Larry
2003 f250 super duty 7.3
supercab long bed
4" exhaust with 5" magnaflow tip
Hypertech power programer III
larry-56 is offline
post #17 of 26 (permalink) Old 02-14-2019, 08:10 PM
klhansen's Avatar
My Photos: (180)
The circuits all come together at the 42 pin connector over the driver's side valve cover. You said you had repaired some chafed wires over that valve cover, so that might be a place to start.
Good Luck.
), AIS,
regulated return,
klhansen is offline
post #18 of 26 (permalink) Old 02-15-2019, 04:09 AM Thread Starter
larry-56's Avatar
klhanson thanks for all your help. I will check the wires at the 42 pin plug again,but not today Iím going to give it a break today cause itís driving me crazy haha also thanks to all replies.
supercab long bed
larry-56 is offline
post #19 of 26 (permalink) Old 02-18-2019, 06:19 PM Thread Starter
larry-56's Avatar
Hey guys I havenít had a chance to do anymore troubleshooting on the wiring the weather has been really crappy and I have to work outside. So that being said I drove the truck today ran fine as usual but I did notice a little fluctuation in the rpms at idle looks like it was fluctuating about 50 rpms up and down just wondering if this has to do with idm code or something else.
Thanks again Larry
supercab long bed
larry-56 is offline
post #20 of 26 (permalink) Old 03-07-2019, 07:58 AM Thread Starter
larry-56's Avatar
Hi fellas,
So I finally got a chance to do some more troubleshooting and checked the circuits from idm to valve cover harness all show within specs checked 42 pin connector to valve cover harness looks lik itís good. So I cleared rather codes ran it for a little while and noticed like I said before Iím getting a little fluctuation in rpms at idle-not much that being said I checked the codes again and the p1316 and p0475 are gone but faulted another code p1000 Iíve been driving the truck for about a week hoping it would go away haha but check engine light is still on checked it again today and same code p1000 any ideas what to do next.
Thanks for any help. Larry
supercab long bed
larry-56 is offline
post #21 of 26 (permalink) Old 03-07-2019, 08:15 AM
Absolute's Avatar
Potential causes of a P1000 include:
The battery or PCM has been disconnected .
The diagnostic trouble codes have been cleared .
An OBD monitor concern occured before completion of the drive cycle
Possible Solutions Although this may be considered a common Ford DTC, it's very minor. You in fact can safely ignore this code and it should go away as part of normal driving, you do not need to clear this code (as it may not actually turn off the MIL). If you want to the code to clear itself, faster, run through the Ford Drive Cycle.
Absolute is offline
post #22 of 26 (permalink) Old 03-07-2019, 10:56 AM Thread Starter
larry-56's Avatar
Thanks Absolute,
Hopefully it will reset itself like I said itís driving me crazy.Do you have any idea what the Ford Drive Cycle is?
Thanks again, Larry
supercab long bed
larry-56 is offline
post #23 of 26 (permalink) Old 03-07-2019, 02:45 PM
Originally Posted by larry-56 View Post
Thanks Absolute,
Thanks again, Larry
Ford Motor Company Driving Cycle
Check the above link. It tells you how to complete the Ford Drive Cycle and clear the P1000.
DonWarkentin is offline
post #24 of 26 (permalink) Old 03-30-2019, 12:44 PM Thread Starter
larry-56's Avatar
Well I finally got a chance to work on my truck again today. I ordered a solenoid from pensacola fuel injection. I replaced the solenoid on #7 injector cleared the codes and fired it up check engine light off finally. Thanks to everybody for all the help.
Thanks again Larry
supercab long bed
larry-56 is offline
post #25 of 26 (permalink) Old 03-30-2019, 09:42 PM
klhansen's Avatar
My Photos: (180)
Glad you got it figured out. And thanks for letting us know what the problem was.
), AIS,
regulated return,
klhansen is offline
post #26 of 26 (permalink) Old 03-31-2019, 06:08 AM Thread Starter
larry-56's Avatar
No problem, Hopefully it might help somebody with the same problem figure it out.
Thanks klhanson for your post on just replacing the solenoid,never thought about doing that.
Thanks again Larry
supercab long bed
larry-56 is offline
Similar Threads
Wrench Light - Limp Home Mode vwsportbug 6.0L Power Stroke Engine and Drivetrain 16 11-15-2013 12:03 PM
Glow Plug Codes Dooner '99 & up 7.3L Power Stroke Engine and Drivetrain 8 11-12-2013 03:56 PM
7.3L Trouble Codes HoustonTrimIII Power Strokes 1994-1997 General 0 01-29-2012 08:55 AM
Help Please ! ballz Power Strokes 1994-1997 General 6 02-20-2008 12:40 PM
DTC p1316 IDM rikx500 '99 & up 7.3L Power Stroke Engine and Drivetrain 5 01-14-2007 08:36 PM
