My trucks fine but during an inspection I found that a rodent ate threw three wires which go to the PCM. Im having a hard time matching these up to what I find for wire color charts. Can anyone tell me what these are for and how important it is that I repair? Its going to be a really tough job to do.
attached is a photo but as far as I can tell they are one is as I shot it and one is with some saturation added.
violet/pink
Red/Green
Green/Red (EDIT: Green/Yellow)
Note: Im assuming its the PCM.. its the connection that is attached to the firewall that has a single 10mm bolt. I think that is where I installed my Hydra tuner
Guess I will research these and see why my truck SEEMS to be working normally. According to this chart it doesnt say my e99 doesnt use the Glow plug controller output.
Edit: I dont see how my truck could be shifiting correctly.
If anyone can clarify these Id appreciate it before I spend hours trying to splice these. 2 of these have 1" of cable hanging out the pcm connector.
Ran a scan.. glow plug and trans error. However the brake lights work.
This is gonna be a hell of a job. Bought some cool splicers that have solder in the middle.. low temp solder you heat with hot air. Hope they dont melt from heat in engine bay. Luckily I have a surface component hot air solder tool.
Going to buy anti rodent tape.. not gonna risk this happening again.
Well nearly 5 hours later and I was able to use the hot air solder splicers to get the job done. It was a real pain. Ran a scan and glow plug error is gone. There are 3 brake sensors and all three work including pressure. I dont know if the transmission one works because I cant move my truck at the moment.
While I was out there I saw a squirrel running around with a baby in its mouth. I was trying to feel sympathetic but failed to do so.
Must be some big squirrels there. Shame on whoever left that baby unattended.
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
