R4100 trans - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 02-15-2018, 05:49 PM Thread Starter
R4100 trans
no drive or second gear reverse and low works fluid full not burnt no sigh of trans slipping ae shows #1 solenoid on 2/3 off 213000 miles thanks
early 99 f250 auto 190000 miles ts6 chip, riffraff frx, 6637 filter with riffraff cover edpv delete 4in exhaust tru- cool max,dedc tow mirrors with lights/heat,glow shift boost,egt,trans, fuel, gauges. hopkins agility brake control,pyle backup camera,firestone air bags,marinco plug, 265/75r 16 cooper discoverer a/t3 tires sinister diesel coolant filter,Bilstein 5100 stancor gpr.
stumpman is offline
post #2 of 13 (permalink) Old 02-15-2018, 07:53 PM
jleedog's Avatar
Mark will come along with some insight soon. Any codes? Was the O/D light flashing?
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #3 of 13 (permalink) Old 02-15-2018, 08:00 PM Thread Starter
no codes od lite not flashing but will turn on and off with switch thanks for reply
stumpman is offline
post #4 of 13 (permalink) Old 02-15-2018, 08:54 PM
Mark Kovalsky's Avatar
My Photos: (6)
Solenoid 1 on and solenoid 2 off is correct for first gear. Does this ever change? You need to turn on solenoid 2 and keep 1 on to get second gear. Solenoid 1 goes off and 2 stays on for third gear. Both are off for fourth gear.
Can you read the commanded gear with the AE?
And it's 4R100, not R4100.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #5 of 13 (permalink) Old 02-15-2018, 09:07 PM Thread Starter
no doesn't change will ae turn solenoids on and off no idea on read command gear please school me on that thanke
stumpman is offline
post #6 of 13 (permalink) Old 02-15-2018, 09:34 PM
My Photos: (6)
I've never used AE. I have no idea what it can and cannot do.
Mark
Former
post #7 of 13 (permalink) Old 02-15-2018, 09:37 PM
RT
RT's Avatar
AE will not turn the solenoids on or off, but it will report what they are being commanded to do. Not necessarily what they are doing, but what the PCM is calling for.
Sent from my iPad using Tapatalk
RT is online now
post #8 of 13 (permalink) Old 02-16-2018, 06:24 AM Thread Starter
thanks mark /rt hooked ae up gear selector in d solenoids 1on 2off. gear selector in 2 solenoids 1on 2on gear selector in 1 solenoids 1 on 2off any idea what this is telling me thanks
stumpman is offline
post #9 of 13 (permalink) Old 02-16-2018, 07:07 AM
My Photos: (6)
It's telling you to drive the truck and see if the solenoids are commanded to change when the transmission should shift.
Mark
Former
post #10 of 13 (permalink) Old 02-16-2018, 07:25 AM Thread Starter
only have low gear when gear shift is in 1st gear nothing in d
stumpman is offline
post #11 of 13 (permalink) Old 02-16-2018, 10:58 AM Thread Starter
truck will not move in drive. ae shows transmission selector working in all gears when moving shift lever also shows od when shifter is in drive and od button on shows d when od is off . so if pcm is not calling for both solenoids to turn off in drive where and what to check for next thanks
stumpman is offline
post #12 of 13 (permalink) Old 02-16-2018, 11:49 AM
My Photos: (6)
The next thing to check is the overdrive one way clutch. I'm 99% sure it's failed.
The way to check it is to take the trans out of the truck and tear it down. While it is all apart it's time to do a full rebuild. That's what it is going to take to fix this transmission. This CANNOT be a solenoid or anything electrical.
Mark
Former
post #13 of 13 (permalink) Old 02-16-2018, 11:59 AM Thread Starter
not what I wanted to hear thanks mark will call transmission shop to set up appointment thanks again
stumpman is offline
