Rattle/grinding under my feet.. I think? - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 02-10-2019, 12:36 AM Thread Starter
I have an 02 7.3 with just over 250k on it. For the past month or so I've been hearing some rattling or grinding coming from either the front and or somewhere in between. I dont hear it at idle and I dont hear it above 20 mph. As soon as I start coasting below 20 it becomes real prominent till I come to a stop. I have no clue what it is. Hubs are new breaks and all components are newish, fluid level is good... I was told it could be the flex plate, but i assume then I would hear it at idle as well? Please help I really need to get it fixed or at least diagnosed. Thanks guys. If you guys or anyone you know is around the Loveland / fort Collins area and could help out that would be great.
Foxn194 is offline
post #2 of 9 (permalink) Old 02-10-2019, 07:50 AM
ArcticDriver's Avatar
Doesn’t a faulty flexplate usually make the most noise when the starter is engaged?
Does it happen in both 2WD and 4WD?
Does it continue the same if you tap your brakes while it is occurring?
Not looking at the flexplate, you could jack up the front end and set jackstands for safety and then rotate the front tires by hand while listening for noise and feeling for rough spots while spinning.
SOLD:
ArcticDriver is offline
post #3 of 9 (permalink) Old 02-10-2019, 12:09 PM
blue99stroker's Avatar
It could be a cracked flexplate or its completely stripped around the mount bolts
99.5 f250 7.3 4x4- 277k FF 160/30, Hydra w/SDK Tunes, S&B CAI, 4" Exhaust, Van turbo w/Riffraff Billet wheel, Autometer Gauges, Built Trans, Trucool Max, 08 Tow Mirrors.
Dads-2000 f250 7.3 4x4- 118k K&N Intake w/Amsoil Filter, 4" Exhaust, Autometer Gauges, Superchip 1705 (Tow Safe), BD Billet Wheel, TruCool Max, 08 Tow Mirrors.
blue99stroker is offline
post #4 of 9 (permalink) Old 02-10-2019, 04:44 PM
Absolute's Avatar
How old are those new hubs. If they weren't from ford, I'd guess your new hubs failed.
Absolute is offline
post #5 of 9 (permalink) Old 02-11-2019, 09:17 AM Thread Starter
4wd works
The hubs are warn hubs and less than a month old.
I dont hear any noise at idle or start up, just when I coast or cruise below 20 mph.
Foxn194 is offline
post #6 of 9 (permalink) Old 02-11-2019, 10:58 AM
Originally Posted by Foxn194 View Post
4wd works
And you hear the noise in both 2WD and 4WD and when the hubs are locked and unlocked in 2WD ?
Noise always the same?
SOLD:
post #7 of 9 (permalink) Old 02-11-2019, 07:23 PM
Absolute's Avatar
U Joint?
Absolute is offline
post #8 of 9 (permalink) Old 02-11-2019, 11:51 PM
Duece's Avatar
Front wheel bearing assembly...?
Jack it up and feel for bearing noise/play. Had to replace mine on my dually at 250k.
2000 F350 DRW, Super-Cab, 4WD, ESOF, SB, Lariat LE, 7.3L DI PSD, 4R100, 4.10, 210k miles, Hypertech Tuner, Fender Flares Steps and Spoiler Pkg, Sun Visor.
New CPS and rear speed sensor @130K. Original Tranny!?
72 F250 390 PS, Front discs, 350K mi, New motor @ 300k, original C-6 Tranny
Duece is online now
post #9 of 9 (permalink) Old 02-13-2019, 06:53 PM
I had a similar noise once, seemed like it was right under my left foot. So I concentrated my efforts to find it in the front. After finding nothing I checked my rear differential and I had a very bad axel carrier bearing. This is what I would do
1. Check your starter attachment bolts, they can come loose and make similar low speed noise.
2. Lock your hubs in, if the noise goes away your hub spindle bearings are bad, they are replaceable.
3. With the hubs unlocked jack one side up at a time and hand roll it, if you can feel ANY bearing roughness it is very bad, but just because you can't feel it doesn't mean there are no bearing element defects.
4. Check flex plated condition and connection
5. Service your rear differential, if you have silver fish scale looking shavings in the differential you have a bearing going bad, if you have both silver and dark debris you have a opinion, carrier and or wheel bearing that has failed.
2002 F250 7.3L PSD, bought new now at 226K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline
Similar Threads
No Air Flow on Feet bgiebels 6.0L Power Stroke Engine and Drivetrain 2 12-31-2017 10:23 AM
55,000Lb plus possible? m35a2 Off-Topic Discussions 6 01-29-2014 04:07 PM
Want black smoke? Climb to 7K feet pulling something and then floor it rotaryboots 7.3L IDI Diesels (Not Power Strokes) 2 11-25-2009 03:29 PM
when it rains it pours, on my feet!!! IDIABUSE 7.3L IDI Diesels (Not Power Strokes) 3 11-21-2005 02:06 PM
My feet are freezing! ScaldedDog Power Stroke Excursions 3 02-08-2004 06:53 PM
