Ringofrey - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 07-15-2019, 07:01 PM Thread Starter
Ringofrey
I have a 99 F450 with the 7.3l. The speedometer/odometer stopped working and the overdrive us flashing. I changed both VSS sensors and it still doesn't work. I just had it checked and there are no codes being thrown. Any help would be appreciated.
Ringofrey is offline
post #2 of 2 (permalink) Old 07-16-2019, 08:27 AM
RT
RT's Avatar
If the overdrive is flashing, you have transmission codes. You need a scanner capable of reading them. When I had this happen, it turned out the wiring harness coming from the VSS was self destructing. I bought a new pigtail for the VSS, but when I went to splice it in, the wiring was chalky black powder. I cut up a few inches - still oxidized wire. I ended up cutting a couple of feet forward of the VSS before I found good copper. Spliced in a new wire and problem solved. Yours could be the same, or it could be something completely different. The code will help narrow it down.
RT is offline
Closed Thread
