RT's 250K Tuneup - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By RT
post #1 of 13 (permalink) Old 05-31-2019, 03:15 PM Thread Starter
RT's 250K Tuneup
RT wrote: "I just pulled my valve covers to do my 250,000 mile tuneup and they were clean enough to eat off of."
So I ask RT, what does your tuneup entail?
Gary
2002 F250 XLT, Super Cab, Short Bed 4X4
Build Date: 10/1/2001
7.3 PSD, 6 Speed Manual Transmission
AIS Severe Duty Intake
20.1 MPG Average
Pine Junction, Colorado
rv6a is offline
post #2 of 13 (permalink) Old 05-31-2019, 06:32 PM
RT
RT's Avatar
Full Force stage 1 injectors, new glow plugs, and new UVC harnesses. I also replaced the UVC o-rings on the high pressure oil rails. Next, Im going to rebuild the turbo and replace the boots and up pipes, reseal the HPOP and fuel filter housing.
Sent from my iPad using Tapatalk
aclasshog likes this.
RT is offline
post #3 of 13 (permalink) Old 05-31-2019, 07:13 PM
RT, where did you get all of your piece parts from?
2001 Lariat, F250, 7.3, 6-speed, 3:73, Ford AIS, MBRP 4" turbo back, ATS ported housing, 205 t-stat, Infinity DX w/DP Tuner 80hp tow, coolant filter, Hutched & Harpooned, EGT & Boost gauge. Fuel Mavericks with 285/18, 86k miles(Jan-2017) Bought brand new April 2001.
aclasshog is offline
post #4 of 13 (permalink) Old 05-31-2019, 07:45 PM
Big Horn's Avatar
Learning a lot from this site (DS) , good info.
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #5 of 13 (permalink) Old 05-31-2019, 08:07 PM
RT
RT's Avatar
RT's 250K Tuneup
I got my injectors from DP-Tuner because you get a free tune reburn if you have their tuner. Get them from Full Force directly otherwise. Got a turbo center section rebuilt by Arundel diesel with a RiffRaff wheel. Everything else I got from Bob at Diesel O-rings.
RT is offline
post #6 of 13 (permalink) Old 06-01-2019, 12:03 AM
jleedog's Avatar
I assume that DP outsources its injector rebuilding? Do you know RT who does them? I want to put new injectors in and I have a DP tuner as well. I was going to get them from full force and pay for a reburn after install. Thoughts?
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #7 of 13 (permalink) Old 06-01-2019, 08:11 AM
RT
RT's Avatar
DP just does the sale. You send your cores to Full Force Diesel and the rebuilts come directly from Full Force.
RT is offline
post #8 of 13 (permalink) Old 06-01-2019, 08:57 AM
Absolute's Avatar
No new Lpop? The high volume melling?
Absolute is offline
post #9 of 13 (permalink) Old 06-01-2019, 02:00 PM
RT
RT's Avatar
Embarrassingly enough, my Autometer oil pressure gauge started showing lower oil pressure at about 200,000 miles. I jumped the gun and swapped the pump then with that very Melling pump. Pressure came back up a bit, but not to normal. Turned out, the sending unit was bad. New sending unit and pressure restored. My fault for not testing first.
RT is offline
post #10 of 13 (permalink) Old 06-02-2019, 01:51 AM
Absolute's Avatar
That must be a crappy sending unit. I got the same one, and it crapped out a while ago. Gauges comes to life about once a week. POS
Absolute is offline
post #11 of 13 (permalink) Old 06-02-2019, 03:26 PM
RT
RT's Avatar
I read the reviews on O'Reilly and everyone said the same thing - lasts about a year and goes nuts. Mine lasted about 6 years so I guess I got lucky. They're too expensive to have to replace them every year so if this one goes, I might get a mechanical gauge.
RT is offline
post #12 of 13 (permalink) Old 06-03-2019, 03:05 PM Thread Starter
Thank you for the info RT. I plan a tune-up later this summer as the clutch and up-pipe replacement soaked a lot of my funds. I was thinking of just replacing the stock injectors in my 2002 with new Alliant injectors. I think they be new, they say they are new. I have to pass Colorado emissions standards and stock does so easily.
Gary
20.1 MPG Average
rv6a is offline
post #13 of 13 (permalink) Old 06-03-2019, 04:17 PM
RT
RT's Avatar
To be honest, if I had to do it again, I'd probably either go stock or Stage 1.5's. I'm not seeing a huge difference between my stock injectors and the Stage 1s. I've only got about 1000 miles on them, so maybe I'll get a better impression of them with time. Full Force has new stock injectors for a good price as well. They are a great company to do business with.
RT is offline
