Serpentine Belt Replacement 7.3 liter, 99.5 - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 06-20-2006, 08:37 PM Thread Starter
I need to replace my serpentine belt. Can someone provide me instructions on how to do this?
markfaust4 is offline
post #2 of 7 (permalink) Old 06-20-2006, 08:53 PM
Re: Serpentine Belt Replacement 7.3 liter, 99.5
Look under the hood, there should be a diagram, or look in owners manual or if you can't find it there, use a digital or phone camera, take a pic and replace in kind, draw a diagram etc..... the manual or sticker under the hood may show you about the tension release, some use a breaker bar or ratchet for this.
02 F-350 Crew Cab Dually, PSD, Long Bed 4 X 4, K&N Air Filter, Auto Trans, Line X, all else stock
RicksF350 is offline
post #3 of 7 (permalink) Old 06-20-2006, 09:37 PM
ReefBlue's Avatar
Or do you mean that the radiator hose goes through the hose and you can't figure out how to remove the belt with the hose in the way?
1999.5 F250 creeping up on 400k.
Check your wiring harness: Chaffed wiring at driver's valve cover.
Keep everyone (and yourself) updated:7.3 mileage and repair thread
If you insist on throwing parts at your truck to fix the problem, go big--don't forget the driver's side frame rail.
If your ICP connector has oil in it, change it. Don't argue, just change it. Don't check other things first, just change it.
ReefBlue is offline
post #4 of 7 (permalink) Old 06-20-2006, 10:44 PM
JimTJr's Avatar
My Photos: (20)
The tensioner has a square hole in it that takes a 1/2" breaker bar. This will allow you to release tension on the belt. Then unthread it from around all the pulleys. IF Your Freeking top radiator hose goes thru the belt,,, [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] *** was FORD thinking?? Then maybe you would like to replace that hose with one that is for the "DUAL ALTERNATOR" option. It will go around behind the belt into that bracket like thing where it can lay and be tiestrapped to.
You will obviously have to drain some of your antifreeze to do this.
If you do NOT Have a diagram sticker under the hood, then look Here, if this link doesnt work, look in "My pics" Misc, and page two in sig
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #5 of 7 (permalink) Old 06-21-2006, 06:32 AM
2002F250's Avatar
My Photos: (13)
Is there a way to buy that sticker? I just bought my truck recently and have noticed that the sticker has mostly rubbed off...not sure how. [img]/ubbthreads/images/graemlins/shrug.gif[/img] Anyway, I'd like to replace the sticker..anyone got a p/n?
2002 F-250
Lariat, CC, SB, 4x4 Off Road, 7.3L, Auto Trans, 3.73 LS, AIS, Zoodad, Autometer Ultra Lite Boost, Pyro, Trans & Fuel Pressure Gauges, Walker BTM, IC Tube Foil Delete, DR 2" Leveling Kit, BFG A/T 285's, Door Seal Mod, Tranny Magnefine,
, Harpooned Tank, 4" rear blocks, ITP Overboost, DP-Tuner F6 No Start, Stock, 60E, 80E & 80T, JW Valvebody, PowerSlot Cryo Rotors w/Hawk LTS pads, Bilstein Shocks, Dieselsite Boots, Dieselsite Coolant Filter, Dieselsite 203* T-Stat, Prestone ELC, FRx R/R, IH Bellowed Up-Pipes, '08 Diff Cover, MBRP 4" Turbo Back Exhaust
To Do/Wish List: Turbo-Master, Wicked Wheel 2, Adrenaline HPOP
2002F250 is offline
post #6 of 7 (permalink) Old 06-21-2006, 06:50 AM
R.J.'s Avatar
My Photos: (10)
anyone got a p/n?
F81E-19A286-BA right from the sticker on my truck
Bob
"I'm not saying we wouldn't get our hair mussed. But I do say no more than ten to twenty million killed, tops. Uh, depending on the breaks."
2002, PSD, F250, 4x4, CC, Auto, 8ft, 3.73LS, Manual hubs, Line-X, Isspro Pyro, Boost & Trans temp, Wicked Wheel, AIS intake, Magnaflow exhaust, ITP regulated return, EBPV & IAH delete, A.R.E. MX cap, BrakeSmart, DuraFlap Mud Flap, 6.0/31 row tranny cooler, Dieselsite coolant filter & 203 thermostat. Cat ELC coolant. Toreador Red/Silver.
R.J. is offline
post #7 of 7 (permalink) Old 06-21-2006, 07:07 AM
2002F250's Avatar
My Photos: (13)
anyone got a p/n?
Awesome!! Thanks! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2002 F-250
2002F250 is offline
