Sputtering at 1500rpm - Diesel Forum - TheDieselStop.com
post #1 of 16 (permalink) Old 10-14-2019, 09:50 PM Thread Starter
I have a 99 F250 sd 7.3L. For the last couple of months i have been having issues with it sputtering between 1500 and 1700 rpm when trying to cruise. When accelerating i have no issues. I can cruise at less than 1500 with virtually no issues and higher than 1700 with virtually no issues. It's just that 200 rpm range that gives me a problem. and that puts me around 40+ miles per hour at cruising speed.
I have had the following done
1) Fuel line blown out from tank to bowl
2) Screen on pump pickup replaced (was not in good cond)
3) Regulator (or what ever it is) on side of fuel bowl replaced
All of these have lessened the problem temporarily but it still comes back. What the hell is going on? I have approximately 323k miles on the engine and approximately 50k on the rebuilt transmission.
1999 Ford F250 Super Duty Crew Cab 4x4, 7.3L Diesel, Automatic Transmission, manual locking hubs
ricf250diesel7.3 is offline
post #2 of 16 (permalink) Old 10-15-2019, 04:09 PM
Have you injectors been rebuilt or replaced? I had this same issue when I got my 99.5 had shaking from 1300-1700 rpm and after replacing it was golden....
twglace is offline
post #3 of 16 (permalink) Old 10-15-2019, 04:10 PM
Maybe try draining the fuel bowl and filling it with some diesel purge or a cleaner of your choice see if it makes a difference
twglace is offline
post #4 of 16 (permalink) Old 10-16-2019, 03:07 PM Thread Starter
Are you talking about something like DieselKleen to help clean the injectors?
post #5 of 16 (permalink) Old 10-17-2019, 08:50 AM
Yes, I would maybe do something that’s for the injectors like Stanadyne Performance or hotshots. More than likely if it was the same issue I had you’ll have to replace the injectors.
twglace is offline
post #6 of 16 (permalink) Old 10-18-2019, 12:28 AM
ArcticDriver's Avatar
I don’t recall Stanadyne Performance being formulated to run undiluted in a fuel bowl. Are you sure thats recommended?
I would instead just fuel up with a B10 or B20 diesel and run it near empty. Although it might be hard to find that percentage of BioD as the temps are dropping.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #7 of 16 (permalink) Old 10-18-2019, 12:26 PM
I wish I could find b10/20 near me ....
twglace is offline
post #8 of 16 (permalink) Old 10-18-2019, 11:49 PM
Where do you live?
SOLD:
post #9 of 16 (permalink) Old 10-19-2019, 06:31 PM
Roswell, GA about 40 mins north of Atlanta.
twglace is offline
post #10 of 16 (permalink) Old 10-19-2019, 11:05 PM
http://www.drivebiodiesel.net/State/...Biodiesel.html
SOLD:
post #11 of 16 (permalink) Old 10-20-2019, 08:15 AM Thread Starter
What's up with the BioDiesel? Is it actually better for the engine? I've actually been told by multiple people to run "off-road" diesel in my 7.3L. I haven't because I can't guarantee the filters have been changed as often and as needed like they are for the on-road diesel.
post #12 of 16 (permalink) Old 10-20-2019, 09:51 AM
I can’t say with certainty this is true for GA but typically on-highway vs off-highway diesel is exactly the same except off-highway has a red dye added.
Off-highway diesel does not have highway taxes added and so it is cheaper. It is designed for construction, agriculture, generators, etc.
Because it is cheaper, some diesel owners have attempted to save money by using it on-highway and the tax man does not like to be cheated. Fuel tanks are inspected when there is any suspicion or a guy is witnessed fueling with it at the gas station and the red dye provides immediate evidence to law enforcement. The fine is $1,000’s.
The red dye is very concentrated and it stains your fuel filter so even after you stop using it, there is proof that you did use it.
The reason I offered the suggestion of a B10 or B20 was for an alternative cleaning agent rather than undiluted Stanadyne in the fuel bowl. BioD has a detergent like quality that cleans quite well.
SOLD:
post #13 of 16 (permalink) Old 10-20-2019, 03:51 PM
One of the stations on the list you provided is about 30 mins away so I will make that work. So it’s safe to just start pumping into the truck ?
twglace is offline
post #14 of 16 (permalink) Old 10-20-2019, 05:43 PM
Big Horn's Avatar
Yep, what Arctic said— better not get caught in Illinois running off highway diesel.
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #15 of 16 (permalink) Old 10-20-2019, 11:17 PM
I have run B20 without any issue. In the summer I have run B10 regularly but it gels in colder temps. B5 is fine all winter long and is what you find in IL.
I don’t think you see increased benefit above B20 and even B10 is probably sufficient.
It depends on what they sell near you.
You can always dilute it with regular diesel.
SOLD:
