Strange high metallic knocking sound - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 10-09-2018, 02:54 PM Thread Starter
bea_rolf@fidibusteam.com's Avatar
Send a message via Skype™ to bea_rolf@fidibusteam.com
Question Strange high metallic knocking sound
Hi everybody, maybe this sounds familiar to somebody. Where could this sound come from. It sounds especially strong on the passenger side.
Thanks for any hint.
2002 Ford F350 Super Duty crew cab, long, 4x4, 6 speed manual transmission, manual hubs, double rear wheels, 47000 miles in June 2018 - going back to South America and continuing travelling
post #2 of 8 (permalink) Old 10-09-2018, 05:10 PM
RT
RT's Avatar
Take your serpentine belt off and see if the noise goes away.
RT is online now
post #3 of 8 (permalink) Old 10-09-2018, 05:28 PM Thread Starter
thank you. Will do tomorrow and see. May be any pulley bad?
post #4 of 8 (permalink) Old 10-09-2018, 05:37 PM
Pulleys
Possible, even on a low mileage truck like yours. There is an idler pulley that one can replace for about 20 bucks or refurbish with an new sealed bearing for 5 if you can press a bearing in an out. Entirely possible and highly likely regardless of low mileage is that the spring loaded belt tensioner is weak, a function of time tensioned more than miles, allowing the belt to misalign and squeal. Not a difficult R&R and around 100 bucks in parts.
The belt removal test RT recommended is the logical start, assuming nothing else is in contact with the belt.
2002 F250 7.3L PSD, bought new now at 226K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline
post #5 of 8 (permalink) Old 10-09-2018, 06:22 PM Thread Starter
Yes could be. We noticed some slight movement of a pulley and tensioner also.
Thanks.
Will study tomorrow.
post #6 of 8 (permalink) Old 10-10-2018, 12:18 PM Thread Starter
Hi, were checking the pulleys and tensioner. The slight movements are not play - just normal.
Tensioner not weak.
Sound does not come from there, comes from a lower point on passenger side.
There is the belowed up pipe kit stainless steel installed. Might the sound come from there?
post #7 of 8 (permalink) Old 10-10-2018, 12:57 PM
RT
RT's Avatar
Might be worth picking up a cheap stethoscope and go hunting. Just don't get it caught in the fan...
RT is online now
post #8 of 8 (permalink) Old 10-10-2018, 01:17 PM Thread Starter
Good idea. Will try that.
