Testing glowplug pigtail - Diesel Forum - TheDieselStop.com
 3Likes
  • 1 Post By klhansen
  • 2 Post By klhansen
post #1 of 8 (permalink) Old 10-19-2018, 02:32 PM Thread Starter
Hard white smoke starts. Tested the glow plugs threw the valve cover harness and have 2 that are infinite..rest are in the 1.2 ohm range. Is there a way to test the pigtail back to fix issues that way, while im at it. Thanks.
buzzard01 is offline
post #2 of 8 (permalink) Old 10-19-2018, 05:14 PM
klhansen's Avatar
My Photos: (180)
If you're talking about the pigtail between the GPR and the VC connector, just a continuity test would do it.
To get any further to tell whether it's a bad glow plug or a disconnected or broken wire in the UVCH, you'll need to pull the valve cover off. You already know that there's an issue there. Once you have the VC off, test the GP's directly for resistance. If they all test good, then your issue was the UVCH.
), AIS,
regulated return,
klhansen is offline
post #3 of 8 (permalink) Old 10-21-2018, 08:49 AM
Absolute's Avatar
Since you know you have 2 dead plugs, your going in anyway. 2 dead is totally enough to make it smoke when cold. Mine is hard to start if 2 are dead. I know cause I have 2 that wont stay plugged in, keeps popping off the plug, and there so fragile I don't want to try and tighten the clip. So I glued it. Lol. The harness can be tested without taking the cover off, if the plugs are plugged in. lol. The procedure is in the service manual and tests all the wires. If you need a harness, don't buy the after market, they are garbage, and most times the gasket part of it is off and they don't seal properly causeing leaks. Tried most of them, none are any good unless you goop them. Plugs are cheap, if your going in. replace them all.
Absolute is offline
post #4 of 8 (permalink) Old 01-06-2019, 04:08 PM
69mach1377's Avatar
Rather than start a new thread I'll just dog pile on here...lol
Only 1 ohmed out over 13, so I'm going in.
Do you really need to remove the CCV 'dog house' to remove the driver side valve cover? I've seen it both ways on the interwebs.
And if so, do you need the (4?) OEM style O-rings which may be all squashed, or can you just use some the right size?
Thanks in advance.
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is offline
post #5 of 8 (permalink) Old 01-06-2019, 06:04 PM
klhansen's Avatar
My Photos: (180)
I've done it both ways. No need to remove the doghouse. It makes a handy "handle" for the valve cover.
If your doghouse isn't leaking around the o-rings or at the screws, leave them along. The larger ones are triangular cross section o-rings, not normal round ones, so if you do replace them, get the correct ones, which the ones you linked to appear to be.
69mach1377 likes this.
), AIS,
regulated return,
klhansen is offline
post #6 of 8 (permalink) Old 01-07-2019, 08:35 AM
69mach1377's Avatar
I didn't notice any leaking from that area, or any area at all, but I'll double check. Thanks again.
post #7 of 8 (permalink) Old 01-11-2019, 09:47 AM
69mach1377's Avatar
So I got the glow plugs torqued and connected, but still need to ohm them out before putting everything back together.
Question about the oil around the old glow plugs. I removed some of it before pulling them out but apparently not all of it. Is it bad to try and start it up this way or should I rotate the engine with plugs out first to push oil out?
post #8 of 8 (permalink) Old 01-11-2019, 01:47 PM
klhansen's Avatar
My Photos: (180)
I don't believe there's enough oil to lock the engine up, but I would at least rotate the engine 2 full turns by hand before attempting to start. I wouldn't bother taking the glow plugs back out. As long as the engine rotates freely by hand, it will start and burn off any oil that's in the cylinders. Probably don't have mosquitoes this time of year, but it's good repellent.
69mach1377 and aclasshog like this.
), AIS,
regulated return,
klhansen is offline
