Transmission Fluid Leak? - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By Mark Kovalsky
post #1 of 12 (permalink) Old 11-15-2017, 12:11 AM Thread Starter
My truck has a leak under the front driver's side radiator. I thought it was the transmission cooler line but I'll be damned if I can find a diagram.
Can someone confirm that is what it is? It's def trans fluid. It's the line in the foreground of this pic.
T-1000 is offline
post #2 of 12 (permalink) Old 11-15-2017, 12:22 AM Thread Starter
Another pic.
T-1000 is offline
post #3 of 12 (permalink) Old 11-15-2017, 01:40 AM
2000F250-7.3's Avatar
Yep That is the trans line looks like something hit it and bent it. I believe it comes from the trans to the trans cooler and the to the radiator then back to the transmission.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #4 of 12 (permalink) Old 11-15-2017, 08:23 AM
Mark Kovalsky's Avatar
My Photos: (6)
You've got it backward. The flow is from the front of the trans to the radiator, then to the trans cooler, then back to the rear of the trans.
2000F250-7.3 likes this.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #5 of 12 (permalink) Old 11-16-2017, 12:23 AM Thread Starter
This is the line that goes from the in-radiator cooler to the auxiliary cooler. They gave me the wrong line at O'Reillys. Should I just get the right line, or upgrade...hmmm...
T-1000 is offline
post #6 of 12 (permalink) Old 11-16-2017, 12:25 AM Thread Starter
Anyone got the part number for this line?
T-1000 is offline
post #7 of 12 (permalink) Old 11-16-2017, 12:56 AM Thread Starter
So far this seems like the only option I've found...
https://www.autozone.com/drivetrain/...49897_804932_0
T-1000 is offline
post #8 of 12 (permalink) Old 11-16-2017, 08:43 AM
Thank you mark for correcting me. My 2000 7.3 auto does not go to the radiator it just goes to my 31 row 6.0 cooler with no over heating issues.
post #9 of 12 (permalink) Old 11-17-2017, 03:17 PM Thread Starter
So...does anyone know if that is the correct part? I already ordered it...
T-1000 is offline
post #10 of 12 (permalink) Old 11-17-2017, 04:27 PM
ArcticDriver's Avatar
I tried to find it on Ford.com but the site won't allow me to enlarge the schematic on my iPad so I can't locate Ford P/N.
That would be the best way to cross-reference your Dorman part.
EDIT:
Can you enlarge the drawing and find the correct P/N from this link?
http://www.fordparts.com/Commerce/Ca...%20Duty#Search
SOLD:
ArcticDriver is offline
post #11 of 12 (permalink) Old 11-17-2017, 04:30 PM
My 2000 is the same as yours. No ATF lines into radiator. They changed it later in the year but issued a TSB for our design if there were issues of overheating which included new radiator with new design. Unfortunately, no Ford dealer will honor a 12-year old TSB.
SOLD:
post #12 of 12 (permalink) Old 11-17-2017, 04:32 PM
Another pic.
You are very lucky that its leaking fluid because its pinched closed and would have resulted in your ATF not circulating and cooling down. Your trans would have gotten quite hot.
SOLD:
