Truck just died, running fine, then started sputtering, then would not start. - Diesel Forum - TheDieselStop.com
post #1 of 117 (permalink) Old 08-23-2007, 05:28 PM Thread Starter
Thumper723's Avatar
Truck has been running fine. 129,000 miles, 1999 F250, 7.3, 6-speed.
Started truck to go about 100 yards to pick up my laundry. Started fine, then became unresponsive to throttle, then started lopey/knocking idle than died.
Will not restart and run. Will kick over, but then immediately cut out.
No SES light. No codes that are popping on my cheap code reader.
Fuel pump is running, I can feel it hum when I put my hand on it. When I turn the water drain valve, I get a healthy stream of fuel.
I put a known good CPS in it just as a hunch. Nothing. Just turns over, may start and run for 1-2 seconds, then die.
Will not stay running. Checked relays/fuses, no popped fuses. Played "musical relays" just to see if that would get it.
I'm out of ideas. My "Childrens" (CHILTONs) manual is not helping much either.
Truck is stock, save a straight pipe in place of muffler.
1999 F250 7.3/6-Spd 2WD SC SB 135,000 miles
DP Tuner F5, 40t 60t 80e DECEL
Dipricol Pyro/Trans Temp/Boost kit from ITP
Unrestricted Naval Aviator #26873
GMI Class of 2001 ME-Auto
Thumper723 is offline
post #2 of 117 (permalink) Old 08-23-2007, 05:29 PM Thread Starter
Thumper723's Avatar
Re: Truck just died, running fine, then started sputtering, then would not start.
Oh, I drove it for 45 miles this morning, 3 start cycles, and it was fine.
post #3 of 117 (permalink) Old 08-23-2007, 05:30 PM
Is the oil full?...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #4 of 117 (permalink) Old 08-23-2007, 05:35 PM Thread Starter
Thumper723's Avatar
Yep. Full with 15W40 Rotella. About 1000 miles on oil.
post #5 of 117 (permalink) Old 08-23-2007, 07:35 PM
Since you have fuel and a new CPS, may be it`s an oil problem. Possible it`s an IPR problem? Stuck open? Just a thought.
orthopod is offline
post #6 of 117 (permalink) Old 08-23-2007, 07:51 PM
Do you know anyone that has a scanner?...Read ICP & IPRDC %
Rick.....
post #7 of 117 (permalink) Old 08-23-2007, 08:39 PM
Just a thought. I'd had a similar problem last year. Truck would run fine for days, then would sputter, run rough then die. Discovered after I let it set awhile it would start and run, maybe for several days before it happened again. My problem was the fuel pump.
'00 F350 XLT, DRW, CC, 7.3 PSD, 6 speed, combo 90 gallon fuel tank/tool box, Banks Stinger-Plus, 203 T-stat, A-Pillar ISSPRO guages, Hadley Air horn, PowerSlide rear window, AIC, AIS, KCM S.S. HPX Line, Riffraff FRx.
Member # 10965
HorseHauler is offline
post #8 of 117 (permalink) Old 08-23-2007, 09:26 PM Thread Starter
Thumper723's Avatar
How would I check for IPR? Need the scanner to read the position it is in?
The fuel pump is easy and cheap enough to change.
Looks like $150 or so for it.
It hums but no real noise out of it. I get pressure to purge the fuel bowl, but not sure if it is enough to run.
post #9 of 117 (permalink) Old 08-23-2007, 09:33 PM Thread Starter
Thumper723's Avatar
Any recommendations for an affordable scanner that will work with these trucks minus the just giving code numbers?
post #10 of 117 (permalink) Old 08-23-2007, 09:35 PM
A E.... Click here.....
Rick.....
post #11 of 117 (permalink) Old 08-23-2007, 09:57 PM Thread Starter
Thumper723's Avatar
I guess $400 is not as bad as some others.. This thing is starting to cost more to keep running than a payment on a new truck.
(Just had to sink $350 into the brakes last week, and its going to need a clutch soon, now this)
post #12 of 117 (permalink) Old 08-23-2007, 11:11 PM
Don't let it bug you too much. Every once in a while they will go through a money spell. Just and it up by the year, not as bad as a truck payment.
IPR cleaning instructions are right here. I was able to get mine off by sticking a deep well socket on the IPR, and had enough socket left to barely get the ratchet in, it slipped a couple of times but it came off. Also, wrap the braided line in something, to keep your hand from looking like you got in a fight with an alley cat.
Good luck.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
post #13 of 117 (permalink) Old 08-24-2007, 01:01 AM Thread Starter
Thumper723's Avatar
It does have a cheap payment vs a new one ($235 vs 500+)
It just seems to have that "bank account surplus" detector that Ford installed.. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
post #14 of 117 (permalink) Old 08-24-2007, 10:50 AM Thread Starter
Thumper723's Avatar
Just tried unlpugging the IPR, no luck. It doesn't even cough with the IPR disconnected. I have a battery charger hooked up to make sure the batteries stay topped off.
Since my Chiltons manual is about useless, since it tells you HOW to check the fuel pressure, but neglects to list a value for it, what should I be getting at the pump output?
I'm searching the forum for this, but if anyone knows the spec on the fuel pump for amp draw, I'd feel a lot better about buying a $150 non-returnable part if I had a warm-fuzzy that that really is it.
Should I be able to HEAR the pump running? I can feel it buzz, but can't hear it run. The annoying door/start chimes dont help but I even had someone get in, close the door and go key-on when I was under.
Can feel it hum, but not hear it, even when next to it.
And that IPR.. That is going to be a bear to get at.
While I was in there, I unpugged and re-plugged the Valve Cover Harnesses. Saw no corrosion.
post #15 of 117 (permalink) Old 08-24-2007, 11:39 AM Thread Starter
Thumper723's Avatar
Just hooked up my ammeter to the pump.
KEY-ON
AMMETER-0
WTS-ON
RELAY-CLICK
AMMETER-3.05A
WTS-OFF
RELAY CLICK
AMMETER-0
Crank truck, just a the cough but no start. Still no codes/SES light.
