Truck just died, running fine, then started sputtering, then would not start. - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 117 (permalink) Old 08-24-2007, 02:28 PM Thread Starter
Thumper723's Avatar
Re: Truck just died, running fine, then started sputtering, then would not start.
Using the port on the back of the fuel filter housing, I have 60psi for fuel pressure when the pump is running. After 20-30 seconds, it clicks off, and slowly drops to 40 (I have slight leak in the gauge setup).
Made an adapter out of a 7/16-20 flare to pipe adapter, a 90 degree street elbow, a 3" nipple, and union with a pressure gauge attached.
Thread the flare union into the housing, with an Oring on it, and then once its in tight, with the hole in the elbow going up, thread the nipple and gauge into it. I'll post pics in a bit.
60psi is enough, right?
Any other place to start looking?
1999 F250 7.3/6-Spd 2WD SC SB 135,000 miles
DP Tuner F5, 40t 60t 80e DECEL
Dipricol Pyro/Trans Temp/Boost kit from ITP
Unrestricted Naval Aviator #26873
GMI Class of 2001 ME-Auto
Thumper723 is offline
post #17 of 117 (permalink) Old 08-24-2007, 02:53 PM
What is is when you give it throttle,& at WOT.....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #18 of 117 (permalink) Old 08-24-2007, 03:03 PM Thread Starter
Thumper723's Avatar
It won't run. So I can't test it at WOT.
It holds 60 while cranking.
post #19 of 117 (permalink) Old 08-24-2007, 03:16 PM
Have you tried unplugging the ICP connector ?...
Rick.....
post #20 of 117 (permalink) Old 08-24-2007, 03:22 PM Thread Starter
Thumper723's Avatar
Unplugged the ICP. Truck won't even sputter with it disconnected.
post #21 of 117 (permalink) Old 08-24-2007, 03:24 PM
You mean before?, or just now?...
Rick.....
post #22 of 117 (permalink) Old 08-24-2007, 03:30 PM
Here ... Is some reading for you...
There are instructions on how to use a guage to test the HP oil system...
Rick.....
post #23 of 117 (permalink) Old 08-24-2007, 03:45 PM Thread Starter
Thumper723's Avatar
When nothing unplugged:
Cranks at about 350rpm, but "jumps" like it wants to start, but cannot.
With ICP SENSOR (left head, round sensor near front) unplugged:
No change. 350/jumps
With IPR Actuator unplugged:
Cranks at 350-400 rpm, but no jumping. Just like cranking a motor with no fuel.
I think I am calling AE to order their ford bundle. $395 with shipping.
post #24 of 117 (permalink) Old 08-24-2007, 03:48 PM
That'll help....
Rick.....
post #25 of 117 (permalink) Old 08-24-2007, 04:12 PM Thread Starter
Thumper723's Avatar
Just ordered it from ITP. They had them on the shelf, and cheaper than direct from AE, who was out of them.
$360 with 2nd day air.
I just hope it's a cheap sensor issue or the like. I'm just hoping its not a HPOP or some other stupidly expensive part.. I swear, the truck "knows" I just paid off one of the many bills I got stuck with in my divorce. I don't want a $500+ a month payment, but if I have my $240 a month payment, and have to sink $3-400 a month into this thing, that extra payment doesn't look so bad.
I've been trying to avoid that, because I may be going to Japan in a year and a half, and don't want to have a new truck rotting in long term storage for 3-4 years.
post #26 of 117 (permalink) Old 08-24-2007, 04:21 PM
Let us know when you get it setup...
Rick.....
post #27 of 117 (permalink) Old 08-24-2007, 04:24 PM
My vote is there is a short in the wiring harness under the drivers side or passengers side valve cover. My truck did the same thing at about the same mileage....
2000 Ford F-250 SD Lariat, Crew Cab, White/Harvest Gold, 156 WB, ESOF 4X4 Off-Road w/ X-Springs, 7.3L PSD, 3.73 LS, 4 SPD Auto, Leather Capts. Chairs, Trailer tow, HD Suspension, TT Mirrors, Roof Lights, Autometer Guages, Banks Monster Exhaust, Tinted Windows, Tool Box, Smittybilt Outland Stainless Steel Cow Catcher w/ three KC Stainless Daylighters running aircraft landing lights with [color:"blue"] [/color]
, two 12" Eclipse subs, 2200 watts of DEI power!
ChrisP is offline
post #28 of 117 (permalink) Old 08-24-2007, 06:21 PM
Was yours a no start?...
Rick.....
post #29 of 117 (permalink) Old 08-24-2007, 06:49 PM Thread Starter
Thumper723's Avatar
Are you talking the harness on the other side of the valve cover plug that branches out to the injectors/plugs?
Where did it short? Just a thing I can check while I am waiting for the AE kit to come.
Also going to do the rail oil pressure checks if I can get the proper fitting.
What is the "common name" of the type of fitting that goes into the oil ports in the head? And would NAPA have that type of fitting?
post #30 of 117 (permalink) Old 08-24-2007, 06:55 PM
This.... Is what usually happens ,...
It could be This .... Too...
Rick.....
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
