Trying to find exhaust/cold side leak - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 04-01-2019, 07:47 PM Thread Starter
Deeds86's Avatar
Hey, so I'm really struggling with trying to find some kind of a leak on my truck... I hear a ticking through my firewall mostly on the driver's side. its loudest when engines cold and quiets a bit once warmed but does not fully go away, when I pop the hood I cannot find any soot streaks on any of the exhaust I have checked up pipes the whole way through and the most I can find is if I scrape my nail between the manifold and the up pipe but it's barely anything. It seems like a lot of my noise is coming internally from the CAC? Pipe... is there something I'm not understanding here! I'm still learning this truck and cannot find any real direction on where to go with this leak! My truck is stock with 190k and only aftermaket is the ais intake. My truck doesn't roll coal nor do I want it to but could this be why I'm not finding any soot? I'm down on power and mileage but am getting decent boost (around 5 to 7 unloaded at 65mph) any help is appreciated!
Deeds86 is offline
post #2 of 5 (permalink) Old 04-03-2019, 06:12 AM
I'm not sure if you are looking for a leak or a ticking noise. How long have you had your truck? Are you sure you have a problem, or are you just getting used to the truck?
Put the truck on a scanner and see if you have any codes.
2002 F350 7.3 psd supercab dually 2wd, AIS, Moog joints, Bilstein, Michelin Defender LTX, Dieselsite coolant filter, red ELC, prepump spin-on fuel filter, 257,000 miles, hutch/harpoon mod, marinco mod, scan gauge ll, Zoodad, Dieselsite boots, pedestal delete, CNC Fab w/ crossover oil lines, 6.0 trans cooler, replaced oil pan, Walker BTM, Denso starter, bellowed up pipes, rebuilt oil cooler, billet dip stick adapter, HD glow plug relay
1974 CJ6 ... off the frame needs work
2013 Expedition... wife's car
Panhead ... 53 motor, 51 tanks, B grind cam, S&S carb, points, drum brakes ... It doesn't just sit in the garage
panhead george is offline
post #3 of 5 (permalink) Old 04-03-2019, 10:10 AM
Absolute's Avatar
Another member posted that he found his leaks by putting his leaf blower in the tail pipe and looking for the air coming out. A feather would be usefull here, but tissue paper will work.
Absolute is offline
post #4 of 5 (permalink) Old 04-05-2019, 06:19 PM
Texkenusmc's Avatar
I always say all the piping down with Dawn dish soap and water and put air to it. If you have a leak it will blow bubbles.
Texkenusmc is offline
post #5 of 5 (permalink) Old 04-07-2019, 11:36 AM Thread Starter
Deeds86's Avatar
I tried the lead blower and couldn't find anything, then tried the dawn dish soap and came to the the conclusion I have a driver side manifold leak when cold closest to the #8 cylinder but have no soot around the head it just blew a few bubbles and that's where the tick sounds the loudest. So I'll have to outsource that cause I'm definitely not dealing with it... but I think I'll wait till it gets a bit worse since it goes away shortly after reaching operating temp
Deeds86 is offline
Similar Threads
Coolant Leak - Radiator Front Drivers Side jriltex 6.7L Power Stroke Engine and Drivetrain 17 07-11-2016 05:27 PM
Passenger side oil leak jtbel Power Strokes 1994-1997 General 1 09-12-2013 02:31 PM
cylinders 1,3,5,7 codes ole_blu '99 & up 7.3L Power Stroke Engine and Drivetrain 13 08-18-2010 11:56 AM
Looking for a lot of help themacguyver '99 & up 7.3L Power Stroke Engine and Drivetrain 40 05-25-2008 06:28 PM
Bogging 6.0 03 along with coolant leak, passengers side BogSpores 6.0L Power Stroke Engine and Drivetrain 8 04-07-2008 02:31 PM
