Unplugged connection - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 10-11-2019, 08:54 PM Thread Starter
Forester121's Avatar
Unplugged connection-img_20191010_174454_1570841460305.jpg When I was looking under my 7.3 I noticed a connection hanging down that was located below the steering column. I also noticed an oil leak that I attached an image for as well. If anyone knows what either of these could be it would mean a lot. Josh.
Early 1999 F250 XLT 7.3l 4x4
252,000 miles and increasing
Forester121 is offline
post #2 of 8 (permalink) Old 10-11-2019, 10:06 PM
klhansen's Avatar
My Photos: (180)
Has the engine block heater been replaced? That disconnected plug looks similar to the one that connects to the heater element. I don't recall that the stock heater cord has a right angle connector on it.
Have you tried finding the other end of the disconnected wire?
), AIS,
regulated return,
klhansen is offline
post #3 of 8 (permalink) Old 10-11-2019, 10:47 PM Thread Starter
I couldn't tell ya, I'm new to the truck still and there is a plug at the grill that the guy said is for a block heater. I haven't followed back the unplugged one yet, it might be pretty tough. I have a million wires under my hood because the truck was setup for plowing and I need to tear then out. Not sure where to start though.
post #4 of 8 (permalink) Old 10-11-2019, 10:55 PM
bugman's Avatar
My Photos: (12)
I can't see your picture too well but since I am on a phone but the block heater cord will look like a round extension cord. It aslo connects right above the oil filter
Sent from my SM-J737V using Tapatalk
bugman is online now
post #5 of 8 (permalink) Old 10-12-2019, 12:49 PM
I think Kevin nailed it, Old block heater cord. Is the oil leak up near the brake master cylinder? Check the Power Steering fluid return line from the Master Cylinder to the pump. This is a simple hose that can deteriorate over time.
DENNY
Go to your homepage and put some info about your truck in the sig block, makes it easier for us to give advice
DENNY is offline
post #6 of 8 (permalink) Old 10-12-2019, 10:42 PM Thread Starter
Okay thanks you guys, I'm on a phone as well and cannot figure out how to add my truck info I can try figuring it out on desktop soon.
post #7 of 8 (permalink) Old 10-13-2019, 09:41 AM
Big Horn's Avatar
If you want to edit your profile from your phone, when you’re on the TDS go to top left of your screen and touch the menu where you go to select forum, sign, etc. Go to the bottom of the menu and select “ exit enhanced mobile view”. Then on the next page select “Menu”, then “Full Version”, and then “User CP” . When that page opens you will see all available edits and selections for your profile.
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #8 of 8 (permalink) Old 10-13-2019, 04:24 PM Thread Starter
Thanks Big Horn, I got some information added now!
