What gets tired on these engines - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By Brandonpdx
post #1 of 5 (permalink) Old 11-27-2017, 11:27 PM Thread Starter
My 01 7.3 Excursion seems to run just fine, but it doesn't have the umph it once had. Maybe it's just my imagination. But seems like it used to pull a lot stronger than it does now.
It is all stock, not much done to it, replaced a couple sensors over the years, regular oil changes, etc. Engine has 212k on it, getting about 16 mpg on the highway, which seems low to me.
Is there anything I should test, or inspect.
bossbotana is offline
post #2 of 5 (permalink) Old 11-28-2017, 12:09 AM
klhansen's Avatar
My Photos: (180)
16 MPG is pretty good.
Things that might reduce the power are exhaust up-pipe leaks which causes less boost. Also leaking intercooler boots.
A good engine cleanup and inspection would reveal any of those things.
), AIS,
regulated return,
klhansen is offline
post #3 of 5 (permalink) Old 11-28-2017, 12:04 PM
2000F250-7.3's Avatar
The injectors get tired over time and with 212 on the clock. But 16 mpg is still showing decent on the injectors. One thing that woke mine up was a new turbo I did the GTP38R the drop in replacement. As klhansen noted up pipes to the turbo if stock leak and you lose a little power. Intercooler boots get soft and can leak boost pressure causing lower power and poor fuel economy 4inch turbo back exhaust helps and the 6637 air filter will help a lot.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #4 of 5 (permalink) Old 11-29-2017, 04:52 PM
greenskeeper79's Avatar
check your fuel pressure
most of the time the driver behind the wheel gets "tired" and gets rid of the vehicle before the engine gets tired.
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD
99 F-250 CC 4x4 7.3L PSD ZF6 E99 CALI DELETE
ROTELLA 5W-40, MOBIL1 ATF, PENNZOIL SYNCHROMESH
greenskeeper79 is offline
post #5 of 5 (permalink) Old 12-01-2017, 05:44 AM
Everything related to the fuel system. Pump, pressure regulator, screens in the tank sending unit get clogged. Injectors themselves usually have significant signs of wear by that mileage. If the engine is noisy, lacks power, idles rough, and smokes when it's cold and warming up but smooths back out and runs well as the oil gets hot, that's the injectors. They are expensive to replace but they make a wide variety of choices depending on how much extra power you want or whether you want extra trouble or hassle getting it tuned right.
Googs likes this.
Brandonpdx is offline
