What's your mileage on your 7.3L ? and with what repairs??? - Page 10 - Diesel Forum - TheDieselStop.com
post #136 of 455 (permalink) Old 03-16-2009, 01:32 AM
2000 F350 crew cab long bed 4x4 Lariat
136,320 miles, bought it with 39,000 miles. Parts replaced so far due to need;
1- upper and lower ball joints( replaced with grease able uppers)
2- both hub bearings
3- transmission and torque converter(replaced with sun coast trans and triple clutch torque converter)
4- 2nd torque converter(replaced under warranty by sun coast)
5- front brake rotors(replaced with power slots)
6- CPS x 1
7- water pump
8- 1 rear diff seal
9- 1 alternator and belt
10- both batteries
11- 4 glow plugs(warranty)
12- 1 glow plug relay(warranty)
13- coolant reservoir tank
14- 1 set Michelin XLT's
15- just installed Brigestone Revo's
16- lower door seals
17- all metal brake lines(I hate salt/brine)
Things I've done because I wanted to;
1- Banks stinger plus kit
2- Oil guard bypass filter
3- 3 pillar gauges
4- shocks(Napa)
5- Mag hytech rear diff cover(I tow heavy things)
6- real cup holder
7- excursion sound deadening under dash panels
8- mud flaps(in my opinion a must have on all vehicles)
9- new radio and speakers
10- AIS air filter kit(factory severe duty filter)
11- coolant filter
Things I'm about to install;
1- Dieselsite CPR fuel system
2- AIH plug
3- non EBPV pedestal(to stop truck from marking it's spot)
4- big bore turbo outlet to eliminate back pressure valve
5- sway bar links
I've changed the oil every 5-6000 miles including all filters(Shell Rotella 15-40)
front brake pads numerous times
rear brake pads once
I intend to keep this truck until it rots into the dirt, it is by far the best truck I've owned. If I ever have to replace it I'll hunt down a low mileage 7.3 and start again.
Dan
amthatiam is offline
post #137 of 455 (permalink) Old 03-16-2009, 01:56 PM
Browning01's Avatar
127000 miles
1 Battery
Alternator
Valve cover wiring harness
1 Injector
Transmition
2001 F250 7.3L White 4X4, Lariat Crew Cab, 7 1/2" Superlift, Mickey Thompson Classic lock Wheels wrapped in Dick Cepek 325/80/16 tires, 05-07 Grille and Headlights, wood dash kit, Pioneer Flip out DVD player, Cobra CB mounted under the 4x4 switch, DP-TUNER WITH STOCK, NO START, 80 ECON and 140 AGRESSIVE, DIY Intake with napa 6637 filter, IC Foil delete, new aftermarket tranny with sonnix shift kit and triple disc billet Torque converter, 4" Magnaflow Turbo back exhaust, Plantdrive wvo kit with 75 gallon external L shaped heated tank in the bed, Racor filter inline before the stock one, 146,000 miles
Browning01 is offline
post #138 of 455 (permalink) Old 03-16-2009, 02:35 PM
Parts Jimmy's Avatar
227K
1-Waterpump
1-Valvecover Gasket
1-U-joint
1-Alternator
2-Batteries
1-Transmission at 205k
1-Rearend Bearings at 210k
Brakes have been replaced three times up front (front rotors once) and twice in the rear. (no rotors) All belts and hoses have been replace as routine maintenance.
It has towed heavy and often its entire life.
7.3 Power Stroke Diesel, 4R100, 4" MBRP Exhaust, Ford AIC, Motorcraft Air Induction System,
DP-Tuned, AIH Deleted, EBPV Deleted, Bellowed Up-Pipes, Dieselsite Coolant Filter, Bilstein 5100 Shocks, Timbren Overloads, Husky Mudflaps, Hella 700FF Driving Lights, Autometer Gauges
Parts Jimmy is offline
post #139 of 455 (permalink) Old 03-16-2009, 03:32 PM
52,000 miles, purchased new in 2000. No major repairs. Replaced original tires and wiper blades two years ago.
Dan
Y2k F350 PSD CC 4x4
<60k miles so far- darn seals are probably dried out
NAA60512 is offline
post #140 of 455 (permalink) Old 03-16-2009, 11:02 PM
Mileage & Repairs
122,000 miles. Front brakes at 92k. I'm fixing (southern expression) to replace all the hoses, the water pump, the rollers and the serpentine belt and go to DELO 500,000 mile coolant. The gasket where the drive shaft enters the differential has a very small leak and I will get it fixed in a month or so. The front end has an intermittent bounce when I hit a bump and I suspect the front end will need some work when I have it into the shop for the other things in a week or so.
The belts, hoses, and water pump/belt rollers are working fine, but with 122k and 8 years and planning on a long Alaska trip, I want to make sure everything is in good shape.
Service, fluids, and filters absolutely changed by the Ford maintenance manual. No mods. I drive it like I paid for it with my own money and I plan to drive it until I die... If I'm lucky I'll live long enough that the state will take away my license, but I ain't counting on it.
Florida Ed
2011 Suzuki Burgman 650cc Rice Rocket Scooter 49 MPG, 120+ MPH, & 2009 Honda Shadow 750cc 51 MPG, 100+ MPH
2001 7.3 F-350 Dually Lariat CC LWB 4X2 Dark Green 4.10 4R100 5'ver Hauler (32' Montana 2 slides 10,500# - 2,000# tongue weight), 106 gal aux tank, 198K miles, nephews arguing over who will inherit it 'cause I'm gonna' drive it 'til I die. Bone stock.
SOLD 2001 5.4 Gasser F-250 XLT Crewcab SWB 4X2 3.73 4R100 98K miles headed to 150K stock as the day it was made
Before these: '00 F-250 CC PSD, '97 F-250 CC PSD, '94 Ford F-150, '91 Ford E-250, '81 Ford E-150, '66 Ford F-100 (cars not included)
FloridaEd is offline
post #141 of 455 (permalink) Old 03-17-2009, 10:59 AM
Tallavana's Avatar
My Photos: (14)
105k. I have replaced a lot of things but the only things I have replaced because it was broken are
rear pinion seal @ 20k
1st alt @ 25k
gas pedal @ 60k
2nd alt @ 75k
1 lock actuator @ 77k
I changed the CPS at the same time as the gas pedal because the symptoms are similar and I need to rule out one to know its the other. Also CPS is cheap and I now have spare.
Light travels faster than sound. This is why some people appear bright until you hear them speak.
2002 F250 Lariat 4x4 Crewcab PSD Shadow Grey/Black
BD X-Monitor, BD Pressure-Loc, SCMT(80),AFE Magnum, 2.5"leveling and 4" block, Bilsteins, Retrax, LineX, Oilguard, MBRP 4" SS, Moto Metal 950 18x9, Toyo A/T 325/60/18, 05 front end w/Harleys, KC 05 light kit w/3 driving lights.
Tallavana is offline
post #142 of 455 (permalink) Old 03-17-2009, 07:55 PM
Bought new in 2002. Only put on 23k miles on it since. No repairs once so ever, except the CPS recall which was done last week.
Doolie7point3 is offline
post #143 of 455 (permalink) Old 03-19-2009, 07:42 PM
1999 F250, 4WD, 7.3 Ltr, 138K..Well here goes..6 spd stick rebuilt, clutch replaced w t/o bearing, PCM replaced, 2 glow plugs ( so replaced all 8), fuel filter, fuel pump, brake rotor was hung up..so replaced both on the rear and now the water seperator is leaking. (have kit on the way). Not all of this happened at once but over time. I use a Quadzilla Performance Chip (Towing). seems to work well. Only in for a couple of weeks. Getting about 19-20 mpg, not towing. Still love the damned truck though...Lee
lee d is offline
post #144 of 455 (permalink) Old 03-19-2009, 08:29 PM
'99 F250 4x4 105k
new hpop at 35k
new clutch at 80k (which it didn't need. it just needed a new master cylinder)
new cluch master cylinder and clutch at 81.5k (it's a long story)
new ipc at 105k
Dennis
'99.5 F250 4x4 SC 6 speed 3.73 LS, Magnaflow 4" exhaust, South Bend con-o clutch.
The_Dude is offline
post #145 of 455 (permalink) Old 03-21-2009, 05:20 PM
Rckymtn's Avatar
Red face 2001 F350 4x4 Crew Cab short bed.
162,000 miles, with 17.5 MPG avg
Mods include a Superchip program, Bilstien shocks, AFE air cleaner, and 4" turbo back exhaust.
Repairs:
Transmission rebuild at 80k
CPS (had a spare in the glove box)
left front hub
ball joints,
block heater.
I do a lot of business with oil and gas producers so this truck has seen alot of dirt roads. It is still tight and a joy to drive.
Dorothy Diesel has been retired.
My office now is a 2014 two tone Ruby Red, 6.7ltr F350, CrewCab, Short Bed, Off Road 4X4, Lariat, with Sync System, matching A.R.E. shell and carpet kit.
Rckymtn is offline
post #146 of 455 (permalink) Old 03-21-2009, 08:24 PM
2003 owned since new 104,000 miles presently
Item repaired or replaced:
CPS at 50k
Power Steering Line at about 65k
Original SteelTex tires at 80K (I got great service from those tires)
Both batteries at 5 yrs and about 85K
HPOP o-rings at 87K
Brakes at 98k
Get about 16.5 mpg city highway combined
oh and a 2008 tailgate installed a few months ago after I backed into my mailbox.....
2003 7.3 SD, CC, 4x4 with FX4 package, white and 100% stock
benco57 is offline
post #147 of 455 (permalink) Old 05-10-2009, 12:41 AM
Banned
172,658 on a 2000 F250SD 7.3L 4x4
According to service records and previous owner when I purchased it, upgraded Exhaust, Intake, and Turbo. Only problems has been batteries, one alternator, and the bloody compressor clutch not engaging.
Oh yeah, Apparently the Fuel Filter wasn't changed like Ford said it was. Had the original OEM unit installed (how I don't know) died in the middle of the freeway one day thing was coated in algae.
I've had some issues with door seals but they were minor had to purchase new clips. Other than that everything is a okay.
Oh and it is a 80% of the time heavy trailer puller.
****9-4-2009 Fuel Pump (Frame Mounted) went out. Limped it home, going to install new one tonight.
KD7CAO is offline
post #148 of 455 (permalink) Old 05-10-2009, 10:23 AM
110,000 miles 14.7mpg's
Power steering hose and pump C/O.
2002 F250 CC 4X4 short bed
Texasuperduty is offline
post #149 of 455 (permalink) Old 06-15-2009, 12:57 PM
Originally Posted by HighwayPrisoner View Post
684,377 miles. 1 set of injectors, 2 waterpumps, 3 alternators, 1 starter, 2 CPS, 1 IPR,2 sets glow plugs, 2GPR, 1 turbo, 1 Tranny, fixed for good with a BTS, u-joints, 2 sets diff bearings,1 fuel pump,2 sets of rotors, and pads front and rear, 4 sets of rancho shocks f&r, gotta love lifetime warranties, ICP sensor, and preperation H.
----- ,highway,I see you are now at over 804,000 mile's,how's the BTS holding up???? and have you put you put any new part's on lately????,can't beat a 7.3 PSD.
2002 F350 4 door Dually XLT lariat PSD Crew Cab 4R100 4.10 VDH4 Prepump, In-Tank, Crossover,Tymar air intake, Edge Evolution, Magellan 6000T GPS, White Night backup light's, DPPI Guages, Walker "Big Truck" Muffler, b&w turn over hitch, pulling a 2004 Sunnybrook 31bwks triple slide 5th wheel. , Total Gross 20900#.truck wt empty 7420# all at the scale, born 05/02/02. bought 06/18/02 & the wife's 2007 eddie bower expedtion 5.4,6 speed automatic ,power everything,redfire & tan.
poppie is offline
post #150 of 455 (permalink) Old 06-15-2009, 08:49 PM
102,000 miles, replaced brake pads at 60,000. Runs great, all belts and hoses probably should be replaced but look good. Main drive belt looks great, no cracks or splits. Pull a 32' fifth wheel trailer quite often. Truck has been serviced as scheduled. Oil change every 3000 miles. Am going to change the rear end fluid this month.
Probably the best truck that I have ever owned and at 72 years old will be the last diesel I will own. Built Ford Tough.
2000 Crew Cab, Sherrod Conversion Power Stroke, SCMT Tuner, 4' Turbo back exhaust, Banks Gauges, AIS Severe Duty, Monroe Reflex Shocks, Pulling a 32' Prowler 5th wheel.
Bennie is offline
