What's your mileage on your 7.3L ? and with what repairs??? - Page 11 - Diesel Forum - TheDieselStop.com
post #151 of 455 (permalink) Old 06-16-2009, 10:29 AM
Originally Posted by poppie View Post
----- ,highway,I see you are now at over 804,000 mile's,how's the BTS holding up???? and have you put you put any new part's on lately????,can't beat a 7.3 PSD.
The BTS is still doing great with over 400K miles. I changed the ring and pinion recently, it had just a little wear pattern, it was time. Replaced u-joints, carrier bearing, and had the shafts balanced, new front rotors, and pads, replaced alternator, front wheel bearings. That is the pretty much everything, I can remember off hand. Still strokin.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95
Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
HighwayPrisoner is offline
post #152 of 455 (permalink) Old 06-16-2009, 08:46 PM
------------------,we have the same truck except for the 4X4 on your's and mine's still a virgin at 77,000 mile's,no doubt you truck will make the millon mile mark but i have one question for you based on my family's experience (BAD) with the 6.Oh Oh's,one son 39 & and one son 30, egr sticking, egr cooler's, sticking turbo's, cracked Y pipe's,BTW,they have two different set's of Y pipe's for the 2004 6.Oh Oh's,my son's has been in the shop for 2 week's and they just keep throwing part's at the thing, the cab in the air 6.4 and fuel millage = to a V10 is no winner for sure, IF you ever wear that 7.3 out what will you replace it with???.
2002 F350 4 door Dually XLT lariat PSD Crew Cab 4R100 4.10 VDH4 Prepump, In-Tank, Crossover,Tymar air intake, Edge Evolution, Magellan 6000T GPS, White Night backup light's, DPPI Guages, Walker "Big Truck" Muffler, b&w turn over hitch, pulling a 2004 Sunnybrook 31bwks triple slide 5th wheel. , Total Gross 20900#.truck wt empty 7420# all at the scale, born 05/02/02. bought 06/18/02 & the wife's 2007 eddie bower expedtion 5.4,6 speed automatic ,power everything,redfire & tan.
poppie is offline
post #153 of 455 (permalink) Old 06-17-2009, 07:04 AM
poppie, you sure ask the hard questions. What will I replace "old reliable" with, I really don't know, and there are not any good reliable choices. I still prefer the Ford truck, but they don't have a good, reliable diesel motor. I hate to say this but, the 2010 Dodge crew cab dually looks good in the pictures. I just can't see me owning a Dodge, especially with the merge with Fiat. I keep coming up with the same answer, none of the above. Hopefully, "old reliable" has many miles in it's future.
SLAPS Member
Sold 62 Corvair 95
Bus
post #154 of 455 (permalink) Old 06-17-2009, 08:25 AM
JakeSpoon's Avatar
137700 miles, average about 14.5 mpg
Just replaced the factory serpentine belt, figured I would do it since I had an Idler pulley failure... I siezed up and fell off the truck and I ran over it...LOL
Other repairs:
Water pump at 92,000
Altenator around 100,000
Fuel Filter o-rings at 105,000
HPOP o-rings at 115,000
3rd set of tires at 125,000
Idler pulley (top by AC) 137,700 & belt
1999.5 F250 CC 4X4 PSD Lariat White over Gold BONE STOCK w/ 205475 miles as of 1-1-19
JakeSpoon is offline
post #155 of 455 (permalink) Old 06-17-2009, 09:18 AM
bluefishbeagle's Avatar
1993 - F250 - 7.3 turbo (non-power stroke)
GP relay - water pump - oil cooler reseal - clutch (previous owner) all u-joints - rear seal (seal good diff vent line clogged blew seal) - starter replace - fan clutch - ignition switch -
All told not much for such a great truck. Biggest problem is listening to the wife complain about the smell. (I just told her she was jealous).
1993 F250 7.3IDI Turbo (factory) 2X4 ZF5 4.10 Diff, Floating axle, Extended Cab Long Bed ZeeDee running boards, 185K miles, Second Owner
1999 Victory V92C Overdrive Sprocket, Power Commander, High Compression Pistons, Performance cam. Slash Cut pipes, Corbin Seat, Factory windscreen, Highway bars.
*Commercial pilot and certified aircraft mechanic by choice, Ford mechanic by necessity*
Most iconic aircraft ever built? Ford Tri-Motor of course!! Take a virtual tour
bluefishbeagle is offline
post #156 of 455 (permalink) Old 06-17-2009, 11:44 AM
Talking 7.3
And why did they stop making this motor?
over the edge is offline
post #157 of 455 (permalink) Old 06-17-2009, 05:25 PM
316,000 and had to replace a 1 lugnut.
For real the only engine work I have had to do is replace 3 water pumps, glow plugs and replace 1 IPR. I have never replaced anything on the engine. The rest of the truck is Ford have worked on every part. I have over 675,000 miles between the 3 trucks.
Best Regards,
2K Excursion Ltd Burg Auto, 193k
2K F350 DRW Lariat 6spd CC White/tan, 248k
Late 98 (04/98), WHT F250 Std Cab 6 spd, 365k miles
Coolant Filter, fuel and hpop crossover, Hutch tank mod,
open ccv, 6637 air filter
looks like a muffler (looks can be deceiving)
DP stock, 80T, 80E, 140 Extreme (normally in extreme and still get 19 plus mpg)
fuel gauge on bowl and shimmed return
Penny glow plugs at AutoZone
moxyspirit is offline
post #158 of 455 (permalink) Old 06-18-2009, 06:30 PM
Agent Orange's Avatar
Thumbs up
126,000 miles.
I have'nt replaced anything due to failure.
Just normal stuff that wears out. Tires, Hoses, Belts, Filters, Fluids etc...
So far, it's been a Great Truck. I would buy another one.
22 mpg Highway
20 mpg average (town & Hwy)
2002 XLT, CC, SRW, SCT Programmer, 4" Magnaflow, 3.73, 4R100...
2002 F250 SD PSD 4X2 SRW CC SCT MAGNAFLOW DIESELSITE
Agent Orange is offline
post #159 of 455 (permalink) Old 06-19-2009, 10:44 AM
Todes's Avatar
176,000mi 2002 F250 4x4 extended cab with short bed
Repairs done
  • Flywheel (Starter chewed it up) $500, rented a lift and did myself
  • 2 starters - Myself, can't remember price of part...thinking ~$100
  • 1 alt - Myself ~$75
Repairs needed
  • Valve cover gaskets - Will do Myself
  • Front axle u-joints - ~$600, will have let Ford do this
  • LF inner axle seal - ~$400, will also have Ford do
  • A/C clutch or condiser (haven't narrowed it down yet) - Depends on whats wrong
  • Rear Diff cover gasket - Myself once I find a new diff cover I like
  • Trans pan gasket - Buddy's repair shop, I don't touch auto trans!
Repairs/upgrade & Fix wants
  • New cd player Alpine display unit - Repair, my cd player doesn't work
  • New BF Goodrich M/T KM2 tires - Repair, tires are bald and had one blow last week, on spare
  • Marker lights - Upgrade, truck didn't have these
  • 03 headlights and mirrors - Upgrade
Probably more than what you were looking for, but it seems like your doing some research about possibly buying a superduty with a 7.3L. Good choice...lol...I love this truck and I haven't been able to kill it yet (unless my mom or sister drive it and run it out of fuel >.<, lesson learned don't fall asleep on long trips!). I included the Repairs and upgrade wants to give you an idea of what you can do to older superduty's to update them and make them look newer while keeping a 7.3L!!!!!
7.3L Stroken 4 life!!!
STOLEN 12/14/14
- Recovered 12/16/14: 2002 F-250 4x4 7.3L Powerstroke - Traded due to damages for 6.7 Cummins...
2014 2500 Cummins - Sold (don't bother with their auto trans offerings)
Current - 2018 F-350 SRW Lariat Crew Cab 6.7L Powerstroke 4x4 short bed
Todes is offline
post #160 of 455 (permalink) Old 06-19-2009, 09:23 PM
rednexx's Avatar
My Photos: (20)
Truck in sig, 160,000 miles:
Throwout bearing
All idler pully bearings
Fan clutch
Clutch
Glowplugs
Ball joints
Tie rod
3 rear brake calipers
2 alternators
ZF 6 tranny
All in the 30,000 i've had it.
Early 99 F-250 Superduty X/C SB, 6 speed, South Bend Con OFE clutch, 4" turbo back exhaust, Ebpv Brake Mod, DIY Tymar, Hutch Mod, 2" leveling kit, 315/75/16's, DP tuner ( 60tow, 80econo, 120race, 140extreme), Warn premium hubs, Autometer pyro, boost, tranny, and fuel pressure gauges. AE if anyone in the area needs.
76' (updated) E series 24' Motorhome - 94' 7.3IDI w/ATS turbo (Brand spank'in new turbo spec motor
) ZF 5 speed, LUK clutch, Borg Warner 1356 transfercase, dana 60 front, 3.73 gears, 245/75/16, and its a 4x4 too!
My Gallery
Next........MORE!!!:
rednexx is offline
post #161 of 455 (permalink) Old 06-19-2009, 10:30 PM
---------------------------------------------, I still prefer the Ford truck, but they don't have a good, reliable diesel motor.----ya got that right,my son just got his 2004 F350 4 door dully 6.Oh Oh out of the shop today after 2 week's for sluggish take off from a standing start,empty or loaded,he was scared to cross the highway, he pulled out of an rv park in tenn on the way home from Illinois going up hill and thought he would need a tow up the hill,when he get's rolling it's fine!!!!, it is just about to go off warranty,he has 3 page's of part's that add up to better than $5000.00 with out labor, no one want's that bill out of warranty!!!!, he's now thinking of buying ford's ESP for $2700.00 for 3 year's,this on a truck that's totaly stock and "NEVER" get's beat with just over 60,000 mile's,he also has a slight bed plate leak but does not want the cab lifted for the fix so the leak stay's,I feel for you,your between the rock and the hard place,your truck is your bread & butter,my other son in Montana tell's me a company out there that does the cummin's conversion in a Ford now has a PCM to run the Ford automatic tran's,you can e mail him if you want here , [email protected] for more info,poppie
poppie is offline
post #162 of 455 (permalink) Old 06-26-2009, 12:32 PM
Just did front rotors, calipers/pads, wheel bearings...551,606 miles...no motor work.
1995(10/94) F350 XLT CC 2WD DRW Flatbed, ZF 5-speed, LUK clutch, 4.10 Eaton TrueTrac, full Banks kit, New 4" Diamond Eye exhaust w/ muffler, BD exhaust brake, Firestone air bags, 100 gallon fuel capacity... 816,217 miles and counting...
oldstroke is offline
post #163 of 455 (permalink) Old 06-27-2009, 01:39 PM
'99 F250 7.3L with 192,000 miles. I bought it at 173,000 a year ago and have only put a transmission in it by my own wrong doing. I got stuck and smoked the 1st gear clutch pack. It did have the original tranny and the shop said it had not been rebuilt. I am trying to figure put why my transfer case stopped working though. Surprisingly I don't even leak any oil from the gaskets. I have more problems with my wifes '04 Acura TSX than my truck.
"The CARnivore"
Nothing like smoking a lil' rice burner!
'99 F-250 Extended Cab Short Box 7.3L Turbo
Sniper Delta Force Tuner, Stage 2 Turbo, Banks intercooler, Banks Exhaust brake, Trans Brake, Bagged,
after market exhaust, 35" Toyo M/T, 192,000 miles and still smokin'
99CARnivore is offline
post #164 of 455 (permalink) Old 06-27-2009, 03:24 PM
PowerstrokeConverters's Avatar
My Photos: (23)
Send a message via MSN to PowerstrokeConverters Send a message via Skype™ to PowerstrokeConverters
I don't really remember mileage but I have changed: CPS,Water pump,TC (just because I used to tow a lot),front end links,pass. side injectors harness.
I have around 114k miles, which is nothing to a 7.3, but it runs like a champ and I do a lot of preventive maintenance to keep it that way, wanna drive it for at least 500k miles.
2000
F-350 7.3 PS ,4R100 Lariat Dually
4x2 LB 3.73 gears, 115k miles(better than new)
6" Fabtech lift w/ duall steering stabilizers
22.5 polished Freightliner wheels
Triple Clutch Triple Bearings Billet Low stall Converter.
V10 Tranny cooler + Trucool max cooler
Wicked Wheel-loud little sucker!
DieselStop Boost fooler
Full Turbo back 4'' exhaust,
Triple Autometer Phantom gauges on pillar,
Now using Superchips 80hp Performance tune.
Wastegate disconnected
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
4'' Ported Housing non-ATS
IC pipe ceramic coated w/ foil delete
Inlet heater deleted.
3 tv's + Backup Cam,DVD,Nav.,Satelite Music.IPod
Jason smooth topper.
Big air compressor/tank
2 air horns w/ big valves
Quick connect Air hose for any air tool/tires
All work done at DieselTriple.Com-Miami,FL
Here but not installed:ATS 1.00 a/r, non-ebv pedestal and outlet,turbo master actuator,203 thermo.,billet thermo. inlet.
Pictures:
PowerstrokeConverters is offline
post #165 of 455 (permalink) Old 06-27-2009, 03:29 PM
My Photos: (23)
Congrats!!! That is what I'm shooting for w/ mine, hopefully more,like 1000,000!!
2000
2005 front clip.
Zoodad mod.
CFM+
CCV rerouted
S&B CAI
Pictures:
