What's your mileage on your 7.3L ? and with what repairs??? - Page 13 - Diesel Forum - TheDieselStop.com
post #181 of 455 (permalink) Old 09-22-2010, 04:10 PM
2000 Excursion with 270K
2 alternators
2 water pumps
Idler pulley
CPS
Ball joints,
LF Wheel bearing
Rear Diff - Rebuilt - bearing
Brakes/rotors
Tires - on 4th set
2000 Excursion Limited / Black on Tan / 7.3L
X-Monitor Digital Gauge Pack,
norm14770 is offline
post #182 of 455 (permalink) Old 09-22-2010, 05:50 PM
RIStroker2000's Avatar
Send a message via AIM to RIStroker2000
164K.. dont know what previous owner did but what ive done.. front calipers/brakes, rear leaf springs, 2 u joints, tires... front end brake line, rear brake line (next to tank).. batteries.. think thats it
2000 7.3 Extended Cab Long Bed Lariat...
nothing crazy, it carries alot of weight, it tows alot.. has all the 'usual' upgrades plus some..
she breaths well, has extra air and fuel
RIStroker2000 is offline
post #183 of 455 (permalink) Old 09-22-2010, 06:35 PM
lance1955's Avatar
Front end rebuild
CPS
Shocks
Ujoints
Caliper bracket
Transmission line
Reseal kit for fuel bowl
1 alt
2 Staters
1 water pump,thermostat and housing
Shifter replacement (wire broke at base of shifter)
Temp sending unit
Replaced auto lock hubs
2 set of batts
Regular stuff fluids, rotor,pads.
2002 Excursion 7.3L 200K+, After market tranny cooler, diesel site transmission filter kit, coolant filter kit and complete boot kit, bilstein shocks. Original transmission with mobile syn ATF
lance1955 is offline
post #184 of 455 (permalink) Old 09-22-2010, 08:41 PM
Heres my list as of 143000 miles-- alternator, ac compressor, radiator, sway bar end links, ipr, cps, front & rear brakes, heater hoses, radiator hoses, t-stat housing, rear u-joints, shocks, glow plug relay and tires. All within the last 28,000 miles. Now at 165,000 I can add front axle seals, passenger side axle u-joint, sway bar bushings, icp and ipr sensors, uvch drivers side, hpop orings again, and clutch pedal assembly.
1999 Ford F350 ex. cab, long box, 4X4, 6 speed, manual hubs, 239k, build date 7-98
NEFORDFAN is offline
post #185 of 455 (permalink) Old 09-22-2010, 09:13 PM
Parts Jimmy's Avatar
Originally Posted by Parts Jimmy View Post
227K
1-Waterpump
1-Valvecover Gasket
1-U-joint
1-Alternator
2-Batteries
1-Transmission at 205k
1-Rearend Bearings at 210k
Brakes have been replaced three times up front (front rotors once) and twice in the rear. (no rotors) All belts and hoses have been replace as routine maintenance.
It has towed heavy and often its entire life.
Just add ball joints to the list at 255k.
7.3 Power Stroke Diesel, 4R100, 4" MBRP Exhaust, Ford AIC, Motorcraft Air Induction System,
DP-Tuned, AIH Deleted, EBPV Deleted, Bellowed Up-Pipes, Dieselsite Coolant Filter, Bilstein 5100 Shocks, Timbren Overloads, Husky Mudflaps, Hella 700FF Driving Lights, Autometer Gauges
Parts Jimmy is offline
post #186 of 455 (permalink) Old 09-22-2010, 09:32 PM
nasty50's Avatar
Send a message via AIM to nasty50
bought it with 166000 on it. since i've had it -- tires, brakes, door locks, icp, oh yea and an engine(that was at 190000) now have 192000 or so.
2001 crew cab 4x4 7.3 straight pipe, Bully Dog GT, oil crossover kit, wheels and tires(mt classic II's with 305/70/16 terra grapplers) 2 tv's, 4 8 inch cadence subs and other non important stuff
89 mustang gt, intake, heads, nos, gears, etc.
86 mustang trunk car, built 351 windsor, c4, built 8.8 rear, lakewood shocks and struts,eibach springs, too much too list, mostly race, maybe go get some milk with it
92 mustang gt convertible, triple white, exhaust, pulleys, just a clean driver car
05 scion xb, wheels, tint, 3tv's
nasty50 is offline
post #187 of 455 (permalink) Old 09-22-2010, 10:08 PM
bought my truck 11/2007 with 299750 km. $" exhaust, AFE stage 1 intake
since then (all in km):
301389 CPS recall
302081 repair OHC display, loose resistors
302274 switch pass airbag
305871 U-bolts rear
306827 ball joints and front brakes (rotors and pads)
308113 parking brake cable assembly
322551 starter
326676 glow plug relay
329074 started using veggie oil as supplement
332000 ish brake line rear
333674 rad, water pump, belt, idler pulleys
339314 front bearing hubs
342309 front brake calipers
342972 rear brakes: rotor, pads, caliper
347770 edge evolution
348283 new batteries, hutch mod, harpoon mod
348550 stancor glow plug relay
352145 track bar assembly and bushings front and
362075 air filter sock
364150 front shocks
364250 rear shocks
370000 km and counting still going strong.
Eriol: 2002 F350 PSD Lariat SCSB 4WD 4R100(deleted) ZF6; 460,000 km as of Sep. 2014
AFe Big Boost 24-91042 on home made intake, 4" turbo back magnaflow exhaust, Edge Evo 2, running 60% SVO in tank, Hellwig big wig sway bars, HPx.
in-tank fuel mod (hutch mod and harpoon mod).586-902 stancor GPR moved out of the valley. Baldwin 1212 pre-pump filter mod. Always bright OHC. boostvalve. TrueTrac diff in rear.
AE: southern Vancouver Island, B.C. or wherever I go.
Camper: 2012 Palamino Maverick 8801
eriol is offline
post #188 of 455 (permalink) Old 10-25-2010, 08:05 AM
Just replaced the two remaining original injectors #1 and #5...still goin!
1995(10/94) F350 XLT CC 2WD DRW Flatbed, ZF 5-speed, LUK clutch, 4.10 Eaton TrueTrac, full Banks kit, New 4" Diamond Eye exhaust w/ muffler, BD exhaust brake, Firestone air bags, 100 gallon fuel capacity... 816,217 miles and counting...
oldstroke is offline
post #189 of 455 (permalink) Old 10-25-2010, 03:20 PM
lance1955's Avatar
What the 632,000 mile secret ? If my injector go that long ill just grin
impressive
post #190 of 455 (permalink) Old 10-25-2010, 10:28 PM
I have replaced a couple injectors twice. I was surprised myself as I keep a log of all maintenance I do on the truck. The only injectors that had not been replaced were #1 and #5 and both recently failed the 'buzz' test after experiencing a rough cold idle. There is no real science. I have never used a fuel additive or have I overly maintained the truck. Some of the same people that swear by fuel additives swear not to use Fram filters...the only filters, both fuel and oil that have been used on the truck.
post #191 of 455 (permalink) Old 10-26-2010, 03:59 AM
Wobblin-Goblin's Avatar
67,000 miles:
Just had the CPS recall done last week
Replaced original batteries this summer
Replaced original pads (front and rear) this summer
Replaced original rotors (front) this summer
On my third fuel filter (including original)
That's it. About half of the miles are towing.
2003 F-350 SRW XLT 7.3L 4R100 PSD 4x4 Supercab SB 3.73
1994 Dodge 3500 SLT Dually 5.9L Cummins NV4500 5spd US Gear "splitter" Exhaust brake 4x4
RETIRED: 1985 Chevy K20 6.2L Turbo-400 3spd auto 4x4 4.10
2003 Ford Explorer XLT 4.0L V-6 5-spd auto 4wd 3.55
NRA Life member
Wobblin-Goblin is offline
post #192 of 455 (permalink) Old 10-26-2010, 12:19 PM
170K miles.
Ford AIS broke lid tab on original lid 55k
Cluch - Spring on plate came out. 101k
throw out bearing
clutch fork
pilot bearing.
water pump 125k ,added coolant filter,and thermostat w/ housing
Batterys every 4 years
up pipe donuts 101k
hpop o-rings 101k
shocks 65k
brake pads front 110k -caliper hung up ,rear 130k
Tires
Clutch hydraulics - under warranty40k
UVC harness 101 k
door lock solenoids 110k
hydro-boost actuator 135k leaking.
fuel filter drain O-rings 125k
F-350 PSD SC 4x4 6spd. XLT, ESOF, SRW,Westach Boost&EGT Gauge, Camper Shell, CB, Nerf Steps, After market Fog Lights.Built 4/98 bought 9/98
JRNOLL is offline
post #193 of 455 (permalink) Old 10-29-2010, 07:05 PM
ReefBlue's Avatar
My most recent update:
300,000 miles: Driver's side caliper bracket with rusted solid slide pins, passenger side slide pins.
304,000 miles: New 4R100 transmission and flexplate. This is the original transmission, anyone got more miles than that on the original?
1999.5 F250 creeping up on 400k.
Check your wiring harness: Chaffed wiring at driver's valve cover.
Keep everyone (and yourself) updated:7.3 mileage and repair thread
If you insist on throwing parts at your truck to fix the problem, go big--don't forget the driver's side frame rail.
If your ICP connector has oil in it, change it. Don't argue, just change it. Don't check other things first, just change it.
ReefBlue is offline
post #194 of 455 (permalink) Old 10-29-2010, 09:02 PM
Since I owned the truck in June, I've done the following major repairs all at 215k. Previous owner neglected the truck apparently, but I guess you can say I got a good deal
* Oil pan
* PS Pump
* IPR and ICP
* Steering gear
* Front hub
* Rear springs
dieselmike is offline
post #195 of 455 (permalink) Old 11-01-2010, 03:50 PM
Bought new in 2002. 130K so far
> Power steering hose & pump
> New Power slot rotors and pads at 100k
> original trans
> New alternator and yellow top batteries
> New shocks
> about to replace ball joints and maybe steering box.
Truck is all stock, hopefully adding new exhaust and open airfilter
What is the best exhaust and air intake out?????
2002 F250 CC 4X4 short bed
Texasuperduty is offline
