What's your mileage on your 7.3L ? and with what repairs??? - Page 9 - Diesel Forum - TheDieselStop.com
post #121 of 455 (permalink) Old 01-08-2009, 05:45 PM
2 Front Bearings And Axle U Joints 3 Times..
SUPERDAVE557 is offline
post #122 of 455 (permalink) Old 01-18-2009, 08:08 PM
Send a message via AIM to icem237 Send a message via Yahoo to icem237
I have an 2001 F250 4x4. 142,400 miles 20mpg 6sp. sonn to need clutch replaces and clutch master & slave cylinder assembly. cant wait to tackle this monster tranny. oh yeah and valve cover gaskets. Lastly whatever that small oil leak is that seems like a remain seal leak, was told it didnt have a rear seal like on a gasser but i dont know, seen this happen on many a PSD.
Replaced:
Tie rod ends
All ujoints
emergency brake shoes and cables
emergency brake assembly
both front hub assemblies
water pump
thermostat (put a 203F)
belt
front and rear sway bar bushings and links
brake calipers
complete brake fluid change (turned weird green color)
radiator fluid
radiator hose clamps
CPS (reccall)
injector/glow plug harnesses
Thats all i can think of. Been a really good truck. no major breakdowns.
icem237 is offline
post #123 of 455 (permalink) Old 01-18-2009, 11:35 PM
kavanrose's Avatar
My Photos: (9)
285k tranny,CPS and need to do the GPs soon.Other than that just the normal oil change and stuff.
1999 F-250 7.3 4X4 SD CC long Bed SRW 3-1/2in Streight Pipe Turbo Back Super Chips 1805 FLASHPAQ Tuner 8in Pro Comp Lift 20X12 Pro Comp Black Wheels 37X13.5X20 Toyo's Chrome Rocker Panels Pro Comp Light Bar 2 KC Hilights up Front Kenwood Deck Sony 800w Sub Amp Sony 600w High&Mid Amp MTX 15in Subwoofer. With 306,000 miles and still goin.
kavanrose is offline
post #124 of 455 (permalink) Old 01-19-2009, 09:59 AM
2003 CC 4x4 102,000 miles
1) just replaced the brakes
2) 80k replaced tires (steeltex were great tires still had enough tread to pass Insp.)
3) 72k replaced HPOP orings
4) 60k replace power steering hose
5) 50K CPS went out
Been a great truck tires and breaks are part of maintenance and really should not be on the list but I was impressed at how long they lasted as did my batteries, replace those at almost 5 years and they were still working just a little weak
2003 7.3 SD, CC, 4x4 with FX4 package, white and 100% stock
benco57 is offline
post #125 of 455 (permalink) Old 01-19-2009, 10:37 AM
stateboy776's Avatar
Truck in Sig. 68,800 and getting a new(lower mileage) engine as I type.Broke a ring after an injector stuck open, due to UVCH short. Other than that I have had just the normal stuff, like brakes and GPR.
PMT1 PCM,
Short Box Lariat,Auto,4X4,F350
Black with Tan Leather,Straight Piped with full gauges.
BUILD DATE 08/00
stateboy776 is offline
post #126 of 455 (permalink) Old 01-19-2009, 12:13 PM
I own an 03 4x4 Dually Crew Cab with the last of the 7.3's. I purchased the truck in Jan of 04 with 38.5K miles and now have a whopping 77K miles. In that time I have replaced a universal joint, rear axle seal, and alternator. This one owner truck was used by a contractor to pull a small construction trailer on dirt roads. That's what I attribute the universal joint and rear axle seal to. The alternators are somewhat problematic. I did break down on the way to the beach but this was a fuse failure only. One set of tires and that's it.
TURBY_1959 is offline
post #127 of 455 (permalink) Old 01-19-2009, 12:55 PM
Agent Orange's Avatar
Mileage:
115,000 miles
No problems, just normal stuff:
Tires, Filters, Hoses, Belts, Crank position sensor and Performance Mods
Fuel Mileage:
20-22 mpg Interstate (depending on drive-keep RPM below 2000)
13-15 mpg w/ fully loaded 8X20 enclosed trailer (10,000 lbs)
In town stop and go traffic, not sure probably around 15 mpg
Love the truck
2002 F250 SD PSD 4X2 SRW CC SCT MAGNAFLOW DIESELSITE
Agent Orange is offline
post #128 of 455 (permalink) Old 01-19-2009, 07:59 PM
120,000 miles
Before I chipped it: CPS, Ceramic Brake Pads (bad mistake), 2 Front wheel bearing assemblies
After I Chipped it: Tranny & TC upgrade, Turbo, another front wheel bearing assembly, Alternator, All the rotors were warped by the ceramic pads so they were replaced with Powerslot Cryo rotors and new pads. I think that's all.
It spends about half its time with a 12,000 lb Fifth-wheel attached.
2012 Ford F-250 SD; 6.7L PSD; Crew Cab; SB, SRW; Lariat; Air Lift rear suspension; Rancho shocks; Mag-Hytec Differential cover
Willcamp2001 is offline
post #129 of 455 (permalink) Old 01-19-2009, 08:58 PM
87000 miles tranny, tourqe converter, Shocks, Tires, Waterpump, CPS, batteries pretty badass and relieable truck so far.....
1999 F-350 Dually 7.3 diesel lifted 8.5inches 37x13.50 xtream all terrains
Just Installed a DP Tuner F-5 chip, with stock, Decel, 60 Hp Tow, 80 HP econo and 120 HP performance and WOW!!! k&n airfilter Road Armor front bumber Warn 15000 winch Shift Kit, Beefier tourqe converter. Kenwood Indash Navigation, Sirius Radio, Back up camera, Kodiak Electric Steps HID Conversion Kit..
Next up is Gears!
buzzy12 is offline
post #130 of 455 (permalink) Old 02-21-2009, 02:39 PM
Aside from the 'usual' or 'normal' replacement items for the PSD, these significant parts are original to the 10/94 build date:
engine
front and rear suspension(replaced all four shocks twice)
steering box
radiator
two of the injectors
rear brake drums(not a fan of turning them)
original ZF 5-speed rebuilt: 322,416
4.10 ring and pinion twice, converted back to old dino 85w-140 and Mag-Hytec cover
2 turbos
4 vacuum pumps
parts replaced at 500,000+:
all the original rad and heater hoses, water pump(yes, still had the factory clear coat) crank dampner and front seal: 503,161
HPOP, IPR: 508,870
The truck almost always has at least a 6,500# trailer attached...been a real work horse!
Update as of yesterday: replaced another cooked VC gasket, VC pigtail and all GP's(had 246k on them) on the driver's bank. Replaced original PS pump(reservoir leaking, pump still good) after getting tired of topping off before each trip.
Rick
1995(10/94) F350 XLT CC 2WD DRW Flatbed, ZF 5-speed, LUK clutch, 4.10 Eaton TrueTrac, full Banks kit, New 4" Diamond Eye exhaust w/ muffler, BD exhaust brake, Firestone air bags, 100 gallon fuel capacity... 816,217 miles and counting...
oldstroke is offline
post #131 of 455 (permalink) Old 02-22-2009, 03:08 PM
2001 482,172 miles
transmission @ 250,000
Water pump
balljoints
and a bed side
edge tuner @ 350,000
2004.5 f350 single wheel
jfisher387 is offline
post #132 of 455 (permalink) Old 02-22-2009, 09:15 PM
2003 X-limited - 67243.2 miles - 99% stock
52k when I got it. Oasis showed turbo pedestal rings replaced at 47k
I had one battery go bad, passenger side. New Batteries were my first purchase, my second being a rear sway bar.
Took a 3500mi trip - avg 21.8mpg hand calculated.
54k - 17x9.5" rims w/265's
58k - HPOP rings
62k - CPS
I may have a slight boost leak costing me some MPG, currently avg 14.4. Its a bit past due for brakes. The Front sway bar ends pop endlessly so bushings and links are up on my to-do also.
2003 X 7.3L - 67k mi DD
1977 Bronco - OD Green Custom FE2O3 floorpans
1970 Bronco - Vato Gray - Concrete Covering
moaiz is offline
post #133 of 455 (permalink) Old 03-15-2009, 06:10 PM
Water Pump
Shocks
CPS
Ball joints
Steering Damper - needed again...
Door switch
Rotors
Shift fork - had the weak one from the factory
Finally needs a clutch I think.
And that's about it.
I used to feel bad about not putting a lot of miles on her - you guys make me feel better.
AndyMeyer is offline
post #134 of 455 (permalink) Old 03-15-2009, 11:30 PM
Update, present mileage 775,004 and still strokin'.
Sold 02 F350 Lariat CrewCab Toreador Red/ Silver DRW LB AT 4X4 4.10 gears, BTS custom chip, and tranny. built BTS and Ford Tough! 859,532 miles
SOLD: 02 F350 Lariat CC Toreador Red, DRW AT 4.10 gears, BTS custom chip, and Tranny 214,550 miles,Built BTS, and Ford Tough!
Sold 94 F350 XLT SC DI DRW 5Speed 314,000
Lifetime Member "BTS BUBBA" Association
"Ain't no feelin like BTS mobilin"
SLAPS Member
Sold 62 Corvair 95
Bus
92 Buick deuce and a quarter
03 Ford Windstar- Granny Hauler
HighwayPrisoner is offline
post #135 of 455 (permalink) Old 03-16-2009, 12:50 AM
Wow 775k is a lot of miles, but that is pretty impressive.
Mr. Insurance is offline
