who has the most miles on the original injectors? - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By rv6a
post #1 of 10 (permalink) Old 03-04-2019, 02:35 PM Thread Starter
Along the same lines as the who has the most miles on their 7.3, wondering who has the most miles on the stock, original injectors.
The injectors in my 7.3 work fine, buzz test OK, @ almost 280k miles.
I change the oil & filter every 5K miles.
The 3.55 gear keeps the RPMs low, I hope that helps too.
Is it better to replace the injectors as a PM, after some ??? number of miles on them, or wait until one or more fail?
If I had a truck, I would just drive it until failure, and do all the R&R myself.
But mine is a van, I dont see any way to change injectors & cups w/o either removing the body or removing the engine, things that this 69 year old cant manage any more!
Frank
2000 E350, I ordered it from the factory, new. Dual A/C, XLT Super Duty trim, 3.55 limited slip, trailer tow class IV package, dual alternators,
speed control/tilt wheel, HD4R100 installed @203k miles, B&M cast pan,
Dahl 100 fuel filter, deleted stock fuel bowl drain valve (leaker),
replaced turbo pedestal w/ non-EBPV, deleted AIH. Bilstein shocks. Jensen VX7021 Navigation receiver, Garmin 65W dash cam
tcnofh1 is offline
post #2 of 10 (permalink) Old 03-04-2019, 03:31 PM
2000F250-7.3's Avatar
I had 245,000 on mine when I changed them out. They were still going strong but just did not like the cold starts in the Colorado mountains. There is no change interval on injectors just the o-rings I had a diesel tech tell me o-rings should be replaced between 150,000 - 180,000 miles. If it starts good and has a great idle I keep running them tell you start having a problem. I forgot in my experience just put a rebuilt or a new set of injectors in dont do one or two a time.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #3 of 10 (permalink) Old 03-05-2019, 11:06 AM
I have 225K on my 03 and have been thinking about changing mine to help with starting when it's below 0. The truck doesn't seem to start as easily as it did when it was younger. Not sure if I'm better with stock injectors or something a little hotter.
4phils is offline
post #4 of 10 (permalink) Old 03-05-2019, 11:15 AM
I have 240K on my 01. The truck starts very easily. The idle is great. The injectors are original.
DonWarkentin is offline
post #5 of 10 (permalink) Old 03-05-2019, 05:11 PM
Texkenusmc's Avatar
I have over 340,000 miles on mine with no issues. I have the money put aside for a set but hope I can get over 400,000 miles on them. My Carpenter has well over 400,000 on his original injectors.
Texkenusmc is offline
post #6 of 10 (permalink) Old 03-06-2019, 09:50 AM
344,000 on the originals and they still seem to work great.
larry-56 likes this.
Gary
2002 F250 XLT, Super Cab, Short Bed 4X4
Build Date: 10/1/2001
7.3 PSD, 6 Speed Manual Transmission
AIS Severe Duty Intake
20.1 MPG Average
Pine Junction, Colorado
rv6a is offline
post #7 of 10 (permalink) Old 03-09-2019, 11:13 AM
415,000 havnt touched them. Honestly, havnt been that great at oil changes the last 150,000 since the body started rusting out, its lucky if it gets changed by 9000.
pinboy122 is offline
post #8 of 10 (permalink) Old 04-13-2019, 09:20 PM
404K miles for my early-99. Tiny bit of rough idle, and not the power it used to have. Not too consistent with the oil changes either, but have been running Stanadyne Performance Formula pretty regularly since 50K miles.
Early '99 7.3 L, 4WD, nearly stock, minor differential alterations
dadiver is offline
post #9 of 10 (permalink) Old 04-15-2019, 11:23 AM
Absolute's Avatar
My addiction to torque was too much. I had to changed mine out when I rebuilt at about 176 000 miles. They were too teeny weeny for me. Ahhhhh, much better now.
Absolute is offline
post #10 of 10 (permalink) Old 04-25-2019, 08:18 PM
Kinasz's Avatar
456,000 in my 99.
Kinasz is offline
Similar Threads
Injector replacement - with pictures GregH 6.0L Power Stroke Engine and Drivetrain FAQ 38 02-26-2013 11:37 AM
bigger 7.3 injectors powerstroke73314 '99 & up Upgrades and Aftermarket - 7.3L Engine 7 01-27-2010 11:40 PM
dynoed the work van rpm1 E-Series Vans 16 12-28-2008 01:52 PM
Effects of WVO inside the heads and injectors after 100,000 miles. TravisT Bio-Diesel and Alternative Fuels 38 03-29-2008 07:29 AM
