Who has put the most miles on their powerstroke? - Page 5 - Diesel Forum - TheDieselStop.com
 2Likes
post #61 of 72 (permalink) Old 12-01-2018, 02:52 PM
273,242 so far. Bought it new. Original 4R100 lasted until 203,000, put in a 4R100HD, will see how long it lasts. Normal replacements of water pumps every 100k or so, alternators, (put in a Leece-Neville this time, will see if it does better than the auto parts stores rebuilt), DENSO starter (same deal, auto parts stores starters last 6 months). Change the Delvac 1300 every 5k.
Biggest fear is when the injectors or glow plugs need work, impossible to do in a van w/o motor removal or body removal so as to get to the motor.
BryceB likes this.
2000 E350, I ordered it from the factory, new. Dual A/C, XLT Super Duty trim, 3.55 limited slip, trailer tow class IV package, dual alternators,
speed control/tilt wheel, HD4R100 installed @203k miles, B&M cast pan,
Dahl 100 fuel filter, deleted stock fuel bowl drain valve (leaker),
replaced turbo pedestal w/ non-EBPV, deleted AIH. Bilstein shocks. Jensen VX7021 Navigation receiver, Garmin 65W dash cam
tcnofh1 is offline
post #62 of 72 (permalink) Old 12-01-2018, 02:54 PM
BryceB's Avatar
Yourctruvk has a out 2x the miles on the 4R100HD than my truck does. Any issues
"The Rig" - 2001 Ford F-250 CCSB 4x4 7.3 PSD Lariat - 285/75R16 BFG AT KO, HD4R100, MBRP 4" XP series exhaust, Ford AIS Intake, Zoodad, Fumoto oil drain valve, Pioneer AVIC-Z130BT In-Dash Nav, ScanGauge II, GlowShift 3 Gauge Pod (EGT, TFT, Boost)
307rwhp / 651rwft-lbs
BryceB is online now
post #63 of 72 (permalink) Old 12-01-2018, 04:40 PM
Nope, the HD shifts perfect, I change the oil in it every 25k miles. (Mobil1 synthetic ATF) Installed a spin-on filter between the cooler out and transmission input.
4R100inputfilter
also put the biggest oil cooler I could find on the HD (it's really hot here 10 months of the year)
ford_4r100HD_oil_cooler
tcnofh1 is offline
post #64 of 72 (permalink) Old 12-02-2018, 09:17 AM
psdfanplus's Avatar
How Many miles?
I sold the truck in my signature a couple of months ago with 430K. I bought the truck with 25K in 2001 to haul our 15k 5th wheel and performed the modifications listed. I had the modifications and maintenance performed by "qualified" diesel techs, the truck was running as good as ever when I sold it to a contractor to haul equipment.
Early 99 (10/98), F-350, 2WD, CC, Dually, LB, Access Cover, ZF 6 w/South Bend 1944-60KHD clutch, 20K Reese Hitch, Ford AIS, Auto Meter Gauges, MagnFlow 3.5 DP w/4inch exhaust, Banks Big Head Wastegate Actuator, MagHytec on Dana 80, Timbrens, DP F6 (No Start, 1200 rpm, 1200 rpm/w EBV, Decel, 40T, 60T, 80T, 60E, & 80E) , 36 foot triple slide 5th wheel (15K), 403K
psdfanplus is offline
post #65 of 72 (permalink) Old 12-29-2018, 10:01 PM
Cool
Just about to roll 374K. Original engine with common repairs (water pump, radiator, HPOP, boots) and original tranny. It's my daily drive as well as pulling horse trailers and RV.
Love my truck!
Farm-Mom NW of Houston, Texas
99 F250 Super Duty 7.3 Crew Cab,
2WD, Automatic, short bed. RED
381K w/original engine & tranny
"Big Red"
FarmMom is offline
post #66 of 72 (permalink) Old 12-31-2018, 12:59 PM
240,000 miles. Still runs great. DRW.
DonWarkentin is offline
post #67 of 72 (permalink) Old 02-22-2019, 06:08 PM
DDauphinee7.3 is offline
post #68 of 72 (permalink) Old 02-27-2019, 10:21 PM
losfinch's Avatar
Original tranny? Wow! That's amazing with that many miles. Way to go. I'm on 3rd tranny with 352,000 (OEM, BTS #1 and BTS#2)
Early 99 F350 4X4 CC 7.3 Auto. A.R.E. Topper, bed carpet/bench inserts, Rhino grill guard, AIS w/sleeve, Fuel filler mod, GOS headlight harness, 02-04 Headlights, Rancho HD stabilizer, 06 Telescoping/heated mirrors with C-Btr Mirrors, Hella FF1000, Htr Bypass valve, front receiver hitch, Quadzilla XZT gauges, ITP Pre-pump/In-tank mods, Pioneer P5000UB w/XM radio, 4 Infinity Kappa 682.7cf, Fumoto valve, FIAMM Highway blaster horns, SS HPX, IDM mod, DP F5 (Stock,Drive-thru,60T,80E,120,80E-Mountain,1200), Walker BTM, RR, Dieselsite BRV, BTS Tranny (2nd one :-), 31 row tranny cooler, Bilstein shocks, Amsoil bypass oil filter, Stancor HD Glow Plug Relay, billet thermostat housing, front & rear parking cameras, Aux reverse lights, Heated Seats.
Security: CrimeGuard Alarm with remote notification, DIY jimmi-jammers, door cylinder locks and linkage removed, padlocked rear bench seat hinge, PCM, DIY "pitstop" switch.
losfinch is offline
post #69 of 72 (permalink) Old 02-27-2019, 10:23 PM
losfinch's Avatar
Love my truck!
Original tranny with that many miles is great. Wow! I'm on tranny number 3 with 352,000 miles (OEM, BTS#1 and BTS #2)
losfinch is offline
post #70 of 72 (permalink) Old 02-27-2019, 11:30 PM
jgarden's Avatar
So, what was the problem with BTS#1?
jgarden is offline
post #71 of 72 (permalink) Old 03-02-2019, 10:39 AM
Well, BTS did my tranny back in 2003 with 78K on the clock..
It lasted 9 years and 140K...Doing a lot of towing of my 10K# camper...
The thrust washers finally wore out and the tranny crapped out...
I went with a Ford Reman. tranny with a 3yr, 100K mi warranty...
The Reman. worked well until I sold the truck this last fall
Put 60K on the Reman.
Brian said he stand behind his tranny work BUT, I had to wait 3 months for him to get to it,
and I had to pay shipping both ways [$750/total] plus R & R costs...
Estimated total $12-$1500..
Bottom line I went with the Reman. for out the door price of $3000
XS_SUV
Graupp is offline
post #72 of 72 (permalink) Old 03-12-2019, 09:39 PM
losfinch's Avatar
I'm not sure what took it out. It just starting slipping one day under normal driving. Lasted 86,000 miles. I sent it back to Brian and had to pay for a new convertor and a new solenoid...with shipping probably about $1250 altogether, if I remember correctly. I got it back relatively fast which I was grateful for but rather surprise that I had to pay for parts on what I thought was a lifetime warranty. Never towed with it and never with real heavy loads. Also had the large Ford 6.0 cooler on it when I first put it in. Kind of disappointing. He said that it looked like I had run some sort of additive in it and that had damaged it. I never did though and only used Schaeffers All-Trans according to his recommendations and changed it out every 30,000 miles. I've got 67,000 on the 2nd one so far without any problems.
losfinch is offline
