Whooshing after ebpv delete - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 03-05-2019, 07:48 PM Thread Starter
Hi there, I am new to this site but I have gotten a lot of useful info from here.
My problem is since I just completed the ebpv delete by getting the non ebpv ped and the closed off adapter. Now I am getting a whooshing noise that was similar to when the valve was closed when it was installed. It is only under acceleration and sounds like a jet engine.
The only other mods that I have is an intake and SCT x4 street tune on it, but I have put it back to the stock tune with the same problem.
It doesn't sound like a surging noise just whooshing if that makes sense. I do not have an egt gauge yet(ordered not yet installed until shipped) so my fear is that something is clogging the system and it is raising them without me knowing too high.
No noticeable coal on the firewall to indicate a clamp leak.
boost is semi normal, but seems like less power(just a little)
I appreciate any help on this
parker4 is offline
post #2 of 8 (permalink) Old 03-05-2019, 07:52 PM Thread Starter
also it is a 2001 f250 with the 7.3l
parker4 is offline
post #3 of 8 (permalink) Old 03-06-2019, 09:17 AM
2000F250-7.3's Avatar
I would recheck all intercooler connections make sure clamps are tight. The turbo outlet make sure it and the intake spider are lined up are good way to line that up is to get it in the lower boots the the engine and then tighten the v ban clamp first then the boot clamps. The up pipes y collector lined up with no gap? The down pipe lined up too? The clamps do a good job of help centering the connections up but sometimes you have to center them before you tighten the clamps up.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #4 of 8 (permalink) Old 03-06-2019, 12:53 PM Thread Starter
I think you hit the nail right on the head with the up pipes and y connector. Went out and checked the up pipes, because after you said that I thought of one mistake I made after putting on the ped was I didnt shake the Y connector to see if it had play in it. Well I disconnected it today and found a little bit of play on the connections and new soot down the passenger side one. The connection seemed tight but that Y pipe to the turbo is so hard to mess with because of the location that it may have been not all the way on like you said seeing as I didn't loosen the bottom bolts near the manifolds. loosening them is a good suggestion since I just ordered a new set of up pipes just now. Hopefully it will be fixed this weekend. Will post updates when fixed. thank you for your suggestion.
parker4 is offline
post #5 of 8 (permalink) Old 03-06-2019, 01:01 PM Thread Starter
also getting a new compressor wheel to rule out any more boost problems, but I am thinking the little bit of boost loss was from that passenger side Y pipe fitting and possibly the clamp a little too. Before I could barley hear the turbo spool up inside the cab when I had the ebpv in. Now it sounds like you are sitting near the end of a plane on takeoff. Way louder than before.
parker4 is offline
post #6 of 8 (permalink) Old 03-06-2019, 01:37 PM
Glad I could help I have done several turbo swaps on 7.3 you learn a few things every time. Questions do you have a tuner on the truck if you do on a stock turbo your probably getting compressor surge a new compressor wheel like wicked wheel 2 will get rid of that or a ported compressor housing will fix that RiffRaff diesel can get you the parts to fix that.
post #7 of 8 (permalink) Old 03-06-2019, 03:01 PM Thread Starter
yeah I have an sct x4 tuner for it. I actually just purchased the one from riff raff haha, so good call on that one, my current wheel isn't chipped but is worn and I have heard that I could get surging with the tuner while towing my 5th wheel that I haven't had a chance to haul until next month. Thanks again though for your help
parker4 is offline
post #8 of 8 (permalink) Old 03-06-2019, 03:37 PM
No problem anytime.
Similar Threads
EBPV pedestal delete panhead george '99 & up Upgrades and Aftermarket - 7.3L Engine 2 02-14-2016 12:10 AM
Gutting EBPV and New Turbo Noise HELLRAISER Power Strokes 1994-1997 Upgrades and Aftermarket 6 10-13-2009 03:51 PM
EBPV delete question and P0475 NorCalDiesel '99 & up 7.3L Power Stroke Engine and Drivetrain 2 01-26-2007 01:33 AM
EBPV delete......machined piece?? PowerChoker '99 & up Upgrades and Aftermarket - 7.3L Engine 4 10-02-2006 10:02 AM
