Is it worth the trouble to clean the intercooler? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 08-27-2014, 11:42 AM Thread Starter
I am wondering if it is worth the time and effort to clean out the intercooler? For those who have done it, did you see any noticeable difference? If so what were they and how did you clean it?
Thanks,
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
post #2 of 6 (permalink) Old 08-27-2014, 02:20 PM
rammertide07's Avatar
Send a message via MSN to rammertide07
Thanks,
Griz
Only took me about 1hr to take it out. I filled the intercooler with degreaser, soak over night. Emptied next day and sprayed more cleaner in it as I rinsed it out. Similar with the tubes, some soak, and scrub and degreaser. I did mine because I had ingested water into the intake and later found out I bent a rod. Getting my truck back soon. Last of the body work is getting done this week. Has rebuilt Black Water engine and single shots now, so don't know a true before/after difference. But the job isn't bad. May be worth it, hard to tell what the inside is like. Once you do it, then you have a better idea of what you got.
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes/160/stock FFD/PowerSlot rotors and green EBC pads/
/MM Hubs/Hood/HPx/FRx/
rammertide07 is offline
post #3 of 6 (permalink) Old 08-27-2014, 03:30 PM
N2GN2's Avatar
Do you monitor your intake temp? Mine is usually 10 degrees warmer than ambient. I'm not going to bother cleaning my IC. If you want to lower EGT's try a 1.0 exhaust housing. That's my next project.
(HIS) 2000 F350 4X4 Lariat ZF6 CC Long Box 260k+, 4" MBRP Straight Pipe w/ 5" Tip, Gearhead Hydra Chip, K&N Intake, Dieselsite Boots, MAX AC Assist, AIH Delete, Foil Delete, EBP Delete, Garrett 1.0 Exhaust Housing and Non-EBPV Pedestal, Wicked Wheel 2, Water Injection, International Bellowed Up Pipes, 203* Thermostat, South Bend Dyna Max Clutch Con OFE, 2.5" Leveling Kit, Rancho 9000XL, Weathertech Mats, Cooper Discoverer ST MAXX 285/75-16 on Pro Comp 1069, Duraflap's Front and Rear, Smoked Lens Projector Headlights w/ Raptor HID 55w 6000K and Smoked Lens LED Tail Lights.
(HERS) 2001 Excursion Limited 4x4, V codes w/ Bilstein shocks.
N2GN2 is offline
post #4 of 6 (permalink) Old 08-28-2014, 10:46 AM
It's not a temperature or EGT concern.
And is the temperature split you are measuring against ambient temp. pre-intercooler or post-intercooler?
post #5 of 6 (permalink) Old 08-28-2014, 10:54 AM
I will say this, I would not have done it if it wasn't filled with water. For one, my mechanic had already pulled it and flushed it from the last time my turbo went out. And I had already done the ccv mod. So....
post #6 of 6 (permalink) Old 08-28-2014, 08:37 PM
N2GN2's Avatar
Opps, I forgot the air sensor reading is from the IAT not MAT that is located in the spider. Never mind.
N2GN2 is offline
