'01 7.3L Turbo, Injector, HPOP advice wanted - Page 2 - Diesel Forum - TheDieselStop.com
 6Likes
post #16 of 23 (permalink) Old 01-13-2017, 12:56 PM
blue99stroker's Avatar
I'm going to agree with Justin.
The honey badger pumps are garbage.
A stock replacement or t500 is better.
A Reman stock pump is more than up to the task to handle 160/30's.
[email protected] likes this.
blue99stroker is offline
post #17 of 23 (permalink) Old 01-13-2017, 01:13 PM
CAREYBO's Avatar
That is absurdly delusional!
The T-500 is not reliable at all. Check out all of the forums. They don't lie. No reason to.
CAREYBO is offline
post #18 of 23 (permalink) Old 01-13-2017, 01:39 PM
Have you run a T500? They are the only pump we carry for a reason.
Spoke to a customer just a few days ago who has gone through 3 HBJR pumps (leaks and failures). He was sick of swapping HPOP's so he called me and ordered a T500. He is well known on some of these 7.3L forums.
I can count on one hand the number of T500 pump issues I have dealt with in the past 4+ years.
post #19 of 23 (permalink) Old 01-13-2017, 03:08 PM
I've heard of a few T500's having issues lately, But after thousands that's pretty good.
The HBJR was all hyped up and ended up being junk. Just like the original SRP pumps lol heck you might argue the SRP1.1's were junk too
post #20 of 23 (permalink) Old 01-13-2017, 03:13 PM
Justin, what are they doing? Are they just putting a larger rotator group and valve plate in or are they cocking the swashplate a few degrees more?
Maryland dieselnick is offline
post #21 of 23 (permalink) Old 01-13-2017, 03:17 PM
Unless you are the one who has to pull your front brackets off to get the front oil rail plugs out, get the back ones out, pull injectors so you can flush out hunks of the brass slippers, out of your oil rail.
post #22 of 23 (permalink) Old 01-13-2017, 07:31 PM
yan7gin's Avatar
I always heard really good thing about the T500
Never knew that HBJR pump existed
Sent from AutoGuide.com Free App
F350 2002 7.3
auto, 37/13.5/20 open country, Bushwaker cut-out flare, Bilstein 5100, Maxtow gauges (EGT, Trans temp, Boost), 4 inch diamond eye turbo back axel drop with BTM muffler, S&B intake, RR AIH plug, billet FPR with gold spring, CNCfab Sgt 1 HPOP, CNCfab HPOP line with cross over, CNCfab 4 line fuel kit, ARP heads stud, RDP plenum reinforcing insert, complete CAC intercooler boot kit, full engine seal and gasket kit, 360* turbo rebuilt, WWII, EGPV delete, dark blue CPS, Hydra chip with SDK tunes, Polished compressor manifold, HD coolant, 203* thermostat, Transgo HD kit, Energy suspension bushing kit, front and rear diff fully rebuilt with 4:88 gear ratio, Z36 powerstop heavy hauling brake kit, headlight relay mod, Fumoto drain valve AND STICKER
F350 2008 6.4 (sold)
TT 26' Springdale 2014
7x17 enclose trailer (shop) 2012
yan7gin is offline
post #23 of 23 (permalink) Old 01-17-2017, 05:09 PM
There is a reason Stealth went out of business. If the pumps were good, then that probably would not have been the case.
You would have to get in touch with Joey at Terminator to get the details of what he is doing to the pump. It really is nothing crazy, as the stock pump design is proven and works good. He just mods a couple things inside I believe. Does not change the swash plate angle as far as I know.
Most of the pumps that have a bad reputation tried doing too much to change from the stock design.
