2000 F350 Programer Issue?? - Diesel Forum - TheDieselStop.com
 4Likes
  • 2 Post By RT
  • 1 Post By klhansen
  • 1 Post By bugman
post #1 of 11 (permalink) Old 03-17-2017, 09:08 PM Thread Starter
I have a 2000 F350 dually, 2wd. Stock performance wise, except 5" mbrp from turbo back with muffler & 6637 filter. I decided to try a cheap tuner Diablo Predator just for a little extra for towing.
Well it won't load any program because it won't save my stock tune, says possibly because it's not a stock tune? I get error code when I scan: p0603, which from what I researched would confirm I do not have stock tune. ( I believe)
What can I do to figure out what type of tune is in the PCM?
Thanks for the Help!!!
GMKILLER5.0 is offline
post #2 of 11 (permalink) Old 03-17-2017, 09:27 PM
klhansen's Avatar
My Photos: (180)
P0603 means that either the power has been disconnected from the PCM or you've used a programmer, which you tried to do.
It could be that the fuse for the Keep Alive Memory circuit is blown and the programmer needs that circuit powered up to be able to load a program.
), AIS,
regulated return,
klhansen is offline
post #3 of 11 (permalink) Old 03-17-2017, 09:30 PM Thread Starter
Any idea which fuse that is?
post #4 of 11 (permalink) Old 03-17-2017, 09:53 PM Thread Starter
Let's assume the previous owner loaded some sort of tune. What are my options to figure out what it is, or how do I get back to stock to start from scratch?
post #5 of 11 (permalink) Old 03-17-2017, 10:58 PM
RT
RT's Avatar
The dealer could reprogram it, but if it was me, I'd pull the PCM and send it to DP-Tuner and have them burn the 80 HP econo tune on it. Then sell that Diablo on fleabay to another sucker.
Sent from AutoGuide.com Free App
rv6a and [email protected] like this.
RT is offline
post #6 of 11 (permalink) Old 03-17-2017, 11:56 PM
klhansen's Avatar
My Photos: (180)
Not a bad idea.
DP-Tuner's 80E tune rocks.
The fuse you need to check should be #15, 5A under the dash.
[email protected] likes this.
), AIS,
regulated return,
klhansen is offline
post #7 of 11 (permalink) Old 03-18-2017, 12:06 PM
bugman's Avatar
My Photos: (12)
A problem that I am seeing with programmers is that if you decide to go back to the stock tune that they won't do it or if they do the stock program is corrupt where you need to get the PCM flashed to get it to even work.
I'd also just send my PCM to DP-Tuner and have them take care of it.
bugman is online now
post #8 of 11 (permalink) Old 03-19-2017, 10:31 AM
69mach1377's Avatar
I suspect someone else's stock tune is already saved in the tuner...
2000 F250 XLT 4x4 SC 7.3 w/rebuilt 4R100, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods, lakes and streams if possible.
See my album for a recent pic.
69mach1377 is offline
post #9 of 11 (permalink) Old 03-20-2017, 12:28 PM
blue99stroker's Avatar
80e... nothing like a lot of timing and high Icp lol
Does the programmer say vin locked at all?
The Diablo tunes are ok, pretty rough on auto trans.
blue99stroker is offline
post #10 of 11 (permalink) Old 03-21-2017, 07:55 AM Thread Starter
It does not have another tune in it, it's guaranteed 'unmarried'.
post #11 of 11 (permalink) Old 03-23-2017, 02:43 PM
We can flash your PCM back to stock or put a tune of your choosing on there...
https://www.dp-tuner.com/ford-powers...nce-flash.html
You may have had a non-stock tune on there already and the programmer cannot recognize it as a stock tune. This happened a lot when Bully Dog programmers were used. Regardless, we can flash it for you though. Even if the PCM was blank.
