7.3 w/ superchips 1705 MAX Micro Tuner - Diesel Forum - TheDieselStop.com
 2Likes
post #1 of 21 (permalink) Old 12-25-2009, 07:35 PM Thread Starter
I bought my new to me 2002 F250 CC SRW with the 7.3 last weekend. It has 122000 miles on it so far. Previous owner had this Superchips Micro Tuner and had used it in Tow Safe Mode when he pulled his fifth wheel camper. I know from reading thus far that this is not the greatest tuner on the market but it came with the truck and at this time I don't have plans of doing anything else to the truck or getting another tuner/chip. My question is would I be better running it in the stock mode all of the time and only using the tow safe mode for when I pull my trailers, or will I get better mpg with it in tow safe mode? It also has hi performance mode, but I don't plan on using that either. As of right now, the rest of the truck is stock and I don't have any other EGT gauges or anything to do any monitoring. Thanks in advance for your opinions.
Chuckdog is offline
post #2 of 21 (permalink) Old 12-25-2009, 09:42 PM
mythreesons's Avatar
Well if I were you the first thing to do is install gauges. No matter what type of chip/tuner you have no truck should be operated without having gauges !! I have the Superchips 1805 and just ordered an DP F5 chip. I wouldn't pull anything with your truck until gauges are installed! Good Luck.
jleedog likes this.
Early 99 F250 XLT, 6 spd, Luk Clutch-Kevlar bushing, 4" MBRP Exhaust, Turbo Master Wastegate Controller, ITP Overboost Annihilator, KCM S.S. HPX Line, DiPricol Optix Gauges, DP Tuner F5 Chip with 60T,80E,100 Perf, Superchips 1805 Flashpaq (used for code reading only), Firestone Airbags, 203 degree t'stat, AIS/w fender sleeve, CCV Mod, Hutch In Tank Mod, Harpoon Mod, 6.0 Intercooler, 315/75/16 on 16X10 Eagle Wheels, Ford 08 and above rear differential cover, Royal Purple Gear lube, 2007 Grille and Headlight Mod.
mythreesons is offline
post #3 of 21 (permalink) Old 12-26-2009, 01:01 PM
I pull a 12,000 lb (empty) toyhauler with mine and a 1705 in tow-safe...no problems. Is there a better tuner, probably. Will your truck spontaneously combust with a 1705, NO, but I also suggest you get at least the EGT and Trans temp gauges. Then drive it by the gauges.
I've had the 1705 since '04 or '05 and have towed thousands of miles.
Your results may vary.
2003 F-350 SD, 7.3 PSD, Auto, CC, LB, SRW, FX4, 4.10:1 Genuine Gear Ring and Pinions, Detroit Truetrac Differentials F&R, FabTech Ladder Bars, SuperChips 1705, EBPV delete, IH Up-pipes, Magnaflow 4" Exhaust, Ford AIS Air Cleaner, ISSPRO Boost, Trans, and EGT Guages, Kenwood DNX6160 with Nav & XM, Ford AIC, Brite Box, 203* T-Stat and Billet Housing, Tru-Cool 4739 MAX, ProComp StageII 4" Lift on Eagle 589's with 35x12.50x16.5 BFG AT KO's, Centramatics, WeatherGuard Toolbox, Rhino Liner, B&W Turnover w/Companion 5th Wheel Hitch & Firestone Ride Rite Airbags, PacBrake PRXB.
2009 Forest River XLR 3712SA ToyHauler
capt205 is offline
post #4 of 21 (permalink) Old 12-26-2009, 04:33 PM
I got the 1700 from a guy a couple weeks ago and when it asked if I tow, I selected "no". I guess that means race tune was installed. I noticed a significant gain in both power and fuel mileage. I have no gauges yet, but last week I did tow my Focus 10 miles, car and trailer are about 4,800 pounds give or take.
I guess my point is that if everyone says these are crappy tuners, and I noticed this much improvement- I surely will be blown away with a custom tune. This will do for now till I get one.
BTW, what's the specs on the 1705 and the 1700? Mine was new, but had no packaging so I'm not sure what Superchips "claims" it adds...
wsigo is offline
post #5 of 21 (permalink) Old 12-26-2009, 06:26 PM
The 1700 has 2 settings, 60 & 80hp, with no code reader.
The 1705 has 3 settings, 70hp tow safe, 90hp tow performance, up to 6000 lbs & 110hp no tow, with a code reader.
capt205 is offline
post #6 of 21 (permalink) Old 12-26-2009, 09:17 PM
Thanks for those numbers.
When they differentiate between tow and no tow, is that just a liability thing because they don't know whether you have gauges or not? I'm assuming this is the case...
Will
2001 F250 CCSB Lariat 4X4, 7.3 PSD, 4R100
wsigo is offline
post #7 of 21 (permalink) Old 12-26-2009, 09:43 PM
CHILLLS's Avatar
i have the 1705
what does the 1708 do? what is different?
02 7.3l psd 6 spd 4x4 cc lb srw
cut muffler
afe stage 2 pro guard 7
wicked wheel
superchips programmer
BD x-monitor
aic
pro comp 6.5 lift
35x13.5x18 mtz
kmc wheels
pro comp track bars
viair 480c compressor
5 gal. tank running 200psi
train horns
firestone bags
piaa supper white head lights
70 gallon in bed tank
warn semi hidden winch mount
warn 12,000 winch
piaa 4" smr fog lights
thats it for now but more to come
CHILLLS is offline
post #8 of 21 (permalink) Old 12-26-2009, 09:57 PM
knoweigh's Avatar
You're asking for opinions, so I'll give you mine.
Get gauges!!......VERY IMPORTANT!
or, do yourself a favor;
if you're not open to spending $250 for a set of gauges, then pull the tuner out, sell it and call it a day; put that extra cash in your pocket and at least reduce your chances of melting anything.
Just my opinion.
Yes, it's THAT important. You NEED gauges. That couple hundred bucks could save litterally thousands; (and by thousands we're talking a minimum of $3000 and as much as $10,000 or more)...no joke. I'd run a EGT and Trans temp even on a stock truck w/ no tuner. Those 2 are a must even if not towing.
If I were to put 1 above the other for a COMPLETELY STOCK truck,....I'd say the trans temp is most important.
For a truck with a tuner, EGT and Trans are equally important IMHO.
jleedog likes this.
y2k F250 7.3 psd Calif emissions, ext cab long bed 265/75/R16 E rated tires, 230k miles 4x4 (nv271 manual t-case) 7.3 #1247981 1/18/00 (forged rods), 3.73LSD, non-diode 4R100, Dp tuner stock, 60t 60e 80t 80e, high idle. DIY 6637 air filter, wicked wheel, turbo master WG controller, turbo lifesaver, bellowed uppies, 4" downpipe & exhaust, 203t-stat, triple pod glowshift gauges (egt, tranny, boost), Ride-rite 2330 air bags, BTS VB, Sports a Western plow when the white stuff flies.
2011 6.7 Lariat 4x4 CCSB CM/TM bed w/b&w turnover 285/65r20
knoweigh is offline
post #9 of 21 (permalink) Old 03-02-2019, 11:19 AM
I do not know any thing about these tuners,just got a Max Micro tuner 1705 used can it be re used on other trucks by resetting it or not ?
nhr-16 is offline
post #10 of 21 (permalink) Old 03-03-2019, 10:25 AM
69mach1377's Avatar
Yes, as long as the current truck is reset to the stock tune. Not a terrible tuner but does not change shift points like modern chips do.
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is offline
post #11 of 21 (permalink) Old 03-11-2019, 12:39 PM
Roger45's Avatar
My Photos: (28)
Slightly different view...when I bought my '99 it too came with this same tuner. I ended up going in a different direction and went with the Edge CTS which not only gave me a tuner, but the ability to have a touch screen with up to nine gauges, all of which I can choose from. I pull a heavy 5th wheel at times and love the performance. There are now a number of different touch screens that do this and I think you might want to research them and see if that is a direction you may want to turn.
'99 F350 XLT, SC, LB, 4x4, auto, 4.10 rear, 4" Stainless Steel MBRP turbo back exhaust, TYMAR air intake, EDGE CTS Programmer with electronic Gauges, SprayIn Liner, Bilstein Shocks, Red Head Steering Box.
2008 F32SB2 Cardinal Cameo 5er. PullRite Super 5th 18K ISP Hitch
Roger45 is offline
post #12 of 21 (permalink) Old 03-12-2019, 09:23 AM
1705 max micro tuner
New to this tuner stuff,does the tuner need to be plug in to port at all times,and if you unplug it can you just plug it back in without resetting it ?
nhr-16 is offline
post #13 of 21 (permalink) Old 03-12-2019, 08:34 PM
Roger45's Avatar
My Photos: (28)
With the Edge it must be plugged in at all times, at least the older version I have does. When you want to switch programs, it takes about five minutes or so, so that is a PETA compared to the switch on the fly. The last I checked, Edge also only is compatible with PC and not with MAC. You can plug your PC into it and the firmware will update. The techs at Edge are great to work with if you have any problems...I have spoken to the engineers a couple of times to fix some issues. I'm extremely satisfied with the performance in all modes and the service I have gotten. I love the gauges options as a big time plus.
Roger45 is offline
post #14 of 21 (permalink) Old 03-13-2019, 11:30 AM
1705 max micro tunner
does this 1705 tunner need to stay plugged in to port at all times to get full power when driving,if you unplug it it will not work when driving right ?
nhr-16 is offline
post #15 of 21 (permalink) Old 03-13-2019, 02:41 PM
the 1705 is a programmer so you plug in and put your new program in and unplug and run that program till you want to change than repeat
redrocker is offline
