about to buy upgrades for my truck. will have around 6k to spend. - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 05-23-2013, 05:51 PM Thread Starter
i am running a 2001 f250 7.3 with 219k miles, currently have a DP-Tuner with multiple tunes,4" exhaust turbo back, k&n air intake.
im about to spend about 6k on my truck and need advice on which to do.
what turbo do you guys reccommend going with. should i get an AIRDOG fuel pump now or wait. or should i add a snowsperformance KIT
i have been looking at the gtp38r but later i would like to upgrade to stage 2 or 3 injectors, head studs and gaskets, hpop, regulated fuel return,
also give advice on what would be better to upgrade now to get best performance
01 f250 4x4 7.3 psd, DEP 4" stainless exhaust w/muffler delete, 5" AFE tip, egt-boost-tuner gauge,K&N air intake,DP-Tuner w/no-start,stock,60T,80E,120Race,140 extreme.
01f250powerstroke73 is offline
post #2 of 12 (permalink) Old 05-24-2013, 10:23 AM
your stock fuel pump is more than capable, of keeping up with the demand of whatever you do to the motor. If anything, do the Hutch mod.
Now onto the spending..., if yuo must have a turbo, go with the T4-s366 set-up. Its rebuildable if/when, se lets go. Then later on, invest in what sticks you want.
The R.R. bowl delete, you could do on a DIY kit, or buy Irate's kit.
HPOP, T-500 is a great alternative. I think head studs and gaskets are out of the question.
timmyboy76 is offline
post #3 of 12 (permalink) Old 05-24-2013, 12:36 PM
First thing to get is a new air filtration system. I am not a fan of K&N in a diesel. With diesels you want lots of fresh air and great filtration either the Ford's AIS or Tymar work best there. If you plan to upgrade the injectors in the future...I would look at the GTP38R. It is a bolt on replacement for the stock turbo. If your transmission is an auto...how strong is it? I've always felt the transmission is the weak leak in the PSD diesels. When adding performance...you should always consider improving the stock transmission too. It wasn't designed for that. Just my 2 cents.
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
post #4 of 12 (permalink) Old 05-24-2013, 08:54 PM Thread Starter
should i buy bellowed up pipes or just replace my stock gaskets while i am upgrading my turbo?
is getting the turbo and up pipes ceramic coated really worth the extra 340.00
post #5 of 12 (permalink) Old 05-24-2013, 09:35 PM
rammertide07's Avatar
Send a message via MSN to rammertide07
Bellowed up pipes are a good investment. And no on the ceramic coating.
Sent from AutoGuide.com App
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes/160/stock FFD/PowerSlot rotors and green EBC pads/
/MM Hubs/Hood/HPx/FRx/
rammertide07 is offline
post #6 of 12 (permalink) Old 05-24-2013, 09:39 PM
I would ceramic coat the up-pipes...not sure if I would bother with the turbo. Yes...get the bellowed up-pipes. Even if you buy new donuts...the pipes might be worn enough they should be changed out. If you are going to all the trouble of doing that you might as well put something in you don't have to worry about.
Griz
Griz is offline
post #7 of 12 (permalink) Old 05-28-2013, 01:10 PM
Feedback Score: 3 reviews
First you need to see if you have forged rods if you don't you limited to stage 1's unless you don't mind risking the motor.
Get a RR system and post filter..all that's needed unless your trying for over 500HP.
If you have a auto with those miles...stop and get a built trans, BTS or JW.
Tymar intake is advised
If you need a trans that and the filters and fuel system upgrades will wipe out the $6k budget.
We have everything needed to mod you truck correctly the first time. PM or email me if I can help.
caryt is offline
post #8 of 12 (permalink) Old 05-28-2013, 07:06 PM Thread Starter
yeah i have a stock trans with 220k i already checked and i dont have forged rods(sucks major a$$)
post #9 of 12 (permalink) Old 06-01-2013, 07:41 AM
91diesel's Avatar
Invest your money, wait a few years, and you will have a newer truck by that time to burn money with.
91diesel is offline
post #10 of 12 (permalink) Old 06-02-2013, 12:57 PM Thread Starter
91diesel, why would i want to get a newer diesel when they have emissions and regulations on them. and a 7.3 will out last any newer truck made.
post #11 of 12 (permalink) Old 06-02-2013, 04:55 PM
91diesel's Avatar
Preferences can change over time Just givin ya a hard time on the pmr rods.
I have seen a few people build a truck up real nice to everything they want only to sell it a couple years down the road.
6.4's also do pretty well without the dpf system. (offroad only remember)
I personally would like to see you swap a C7 Caterpillar into your truck, but im not biased towards them or anything.
91diesel is offline
post #12 of 12 (permalink) Old 06-03-2013, 02:48 PM Thread Starter
i would rather put 40 grand in upgrades in my truck than i had to buy a new truck for 50k
in the future i will be looking to buy a used 7.3 engine and build it with forged rods and everything i need to make 600+ hp at the wheels,
