Adding a passenger's side airbag switch - Diesel Forum - TheDieselStop.com
post #1 of 1 (permalink) Old 03-17-2017, 08:45 AM Thread Starter
Texkenusmc's Avatar
Talking Adding a passenger's side airbag switch
I have two sets of twins under two and needed a airbag shutoff switch. After doing some research I found out that no crew cabs came with them but they are easy to add. Everything is behind the dash. All you need is to buy the switch and drill the dash. The dash is even marked on the back side. I am just posting info in case someone else needs this info.
Texkenusmc is offline
