afe intakes any good??? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 05-24-2013, 10:27 AM Thread Starter
i just bought a ts 6 chip and was wondering wat a good intake to go with it will be best.
dent350 is offline
post #2 of 7 (permalink) Old 05-24-2013, 10:32 AM
RT
RT's Avatar
Sure AFe intakes are ok. The two best, based on a lot of independent research, are the Tymar and the Ford Severe Duty AIS. I like the Ford version - it has a honeycomb Donaldson filter and not only flows a lot more air than the others, it filters better. Most "high flow" air filters sacrifice filtration. They Tymar is in the same range, but I don't like the open filter box design personally.
RT is offline
post #3 of 7 (permalink) Old 05-24-2013, 10:34 AM Thread Starter
ok thanks i was just asking about the afe because a site i was looking on had a ts 6 n afe intake combo for a good deal
dent350 is offline
post #4 of 7 (permalink) Old 05-30-2013, 11:40 AM
I'm very pleased with my AFE intake, it was a huge improvement over stock.
2000 F350 lariat, crew cab, long bed, 4x4, 3.73 limited slip
LASB turbo from Irate Diesel
Bellowed up-pipes
4" turbo back exhaust
Gauges (EGT, Trans Temp, Boost)
AFE Stage 2 XP Pro Guard 7
DP Tuner F6 (no start, stock, 80e, 60e, 60t)
AIH delete and CCV mod
F650 Dash with Carling switches
2002 Headlights with FX-R HID bi-xenon projector retrofit and 50W 5000K bulbs
53fordguy is offline
post #5 of 7 (permalink) Old 06-02-2013, 07:43 AM
Jody at DP is on record as stating that the AIS does not flow nearly as much air as an AFE drop in, though he does suggest opening up the snorkel in the 7.3 airbox. As such, I removed my AIS and went back to stock airbox with an AFE drop in.
DOC
2001 4WD 7.3 PSD Excursion: Detroit TrueTrac Vs and CT's Mod Bs ProComp TB Pitman arm ICON Adj TB Tuff Country Ladder Bars Helwig Anti-Roll Bars Front and Rear 2003 Ex Front Bump Stops Superduty Rear Airbags CT's 4 Front and 2 rear Bilstein 5100s Top Gun Double Bilstein Steering Damper Red Head Steering Box 5 Degrees Positive Front Caster Stock wheels with Pirelli Scorpion ATs ART Rotors Porterfield R4S pads Walker BTM Zeibart
DOC4444 is offline
post #6 of 7 (permalink) Old 06-02-2013, 09:24 AM
RT
RT's Avatar
My original point was the Tymar and the Ford Severe Duty AIS flow the most air WHILE offering the best filtration. I'll freely admit the K&N washable will flow more air - lets in a lot of dirt too. I'll even go on record and state that you can get a lot more airflow by just leaving the filter out altogether. In fact, you can just disconnect the cold air intake hose at the turbo. The issue is improved airflow over stock AND improved filtration. The Tymar has a 98% filtration ability and the Donaldson filter (Ford Severe Duty AIS) is ranked at 99.5%. Either of these filters will move enough air to get you to about 500HP. If you're producing more than that - you're probably not worried about blowing motors anyway.
RT is offline
post #7 of 7 (permalink) Old 06-02-2013, 12:03 PM
I agree with RT...you can't go wrong with either the Tymar or Ford's AIS. I personally would stay away from K & N type filters in a diesel. Proper and frequent maintenance is critical with this type of air filter. And most don't know how or do it often enough to be effective. Just my two cents.
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
