ATS Ported Shroud Compressor Housing - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 02-19-2007, 12:43 AM Thread Starter
My Photos: (6)
Just wanted to see if anyone had any personal experience with this compressor housing. I know its a good inch larger and also helps reduce surge.
http://www.itpdiesel.com/store.php?c...on=show_detail
Its quite costly but if it helps (id probably do it along with a WW) then it may be a good investment.
The other question is that I read a few things online about it in combination with the WW was not as good as it with a stock wheel? Any insight would be great!
2001 F350 Dually, Crew Cab, 6x6, Lariat, 7.3 PSD, Auto, 4.10's, Camper Package
6" Lift [4.5" DR lift, X springs upfront, 6" DR Rear blocks] Dual front Bilsteins 5100,
37x12.50x17 Pro Comp Xtreme AT's, Eagle 058's 17x8 front 17x6 rear,
custom 17" steel inners by Rickson, 3" rear dually spacers, BTS trans
DP Tuner F6 Chip (No Start, Stock, Hi Idle, 40T, 60T, 80E, 120R)
4" SS MBRP Cool Duals, Banks 1.0 Exhaust Housing, Banks Big Head, AIS Intake w/ Fender Cutout
DiPricol Optix Boost, Pyro, Full Sweep Trans Temp, DP Tuner Gauge Switcher
DB high-torque starter, Power Slot Cryo rotors, Hawk Pads, SS lines
More to come...
2000 F250 7.3 PSD 35" MT's, MBRP Cool Duals, AIS Intake w/ Fender Cutout, DiPricol Optix Boost, Pyro, Full Sweep Trans Temp
2002 F450 7.3 PSD (30k) 12ft Dump... AIS Intake w/ Fender Cutout
TalontedTSi is offline
post #2 of 17 (permalink) Old 02-19-2007, 01:47 AM
Re: ATS Ported Shroud Compressor Housing
From what I have read the ww works great but the housing does better. If you have both it might have too much noise.
2000 F250 4inchexhaust, homemade intake, ww, superchips tuner
Always ready for more power
Thurman is offline
post #3 of 17 (permalink) Old 02-19-2007, 02:32 AM
I had both the WW and the ATS housing and it whistled pretty good [img]/ubbthreads/images/graemlins/wink.gif[/img]. The stock wheel from what i heard moves more air then the WW but the WW makes a nicer whistle sound. The combo solved my surging issues but eventually i upgraded to bigger injectors and turbo for more power that i desperately needed [img]/ubbthreads/images/graemlins/wink.gif[/img] [img]/ubbthreads/images/graemlins/grin.gif[/img].
Andrew
Ford F550 Crew Cab 4x4 with Fontaine Bed and Air
00PSD1 is offline
post #4 of 17 (permalink) Old 02-19-2007, 08:44 AM
The ATS housing is a permanent design to eliminate surge. The WW is actually LESS efficient than a stock wheel, so it will cure most surge because it doesn't move as much air, and it moves the surge point, but it doesn't cure surge. With a WW you can still get surge, but with an ATS housing there will be no more. I am running a WW and ATS with a 1.15 turbo and love the whistle, its damn near ear piercing from 10psi up. I can only build 23ish lbs of boost with my "somewhat" extensive mods, and i do know that the WW reduces about 2-3 pounds of boost. I have had enough of the whistle, but can still tolerate it. Im making the trip to Lead Hill pretty soon and even at 5psi the turbo is all you can hear going down the road at 80mph. Next time i have my turbo off, i am going to put the stock wheel back in to regain my lost flow, so i can compare the differences.
Hillbilly Deluxe- 2002 F-350 Crew 4x4 Auto Lariat Some stuff, 309/602 before DPtuner
TDS's youngest member
KrisMyers is offline
post #5 of 17 (permalink) Old 02-19-2007, 08:58 AM
JimTJr's Avatar
My Photos: (20)
[/ QUOTE ] IS THERE ANYSUCH THING AS TOO MUCH NOISE??? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
I have the WW and ATS on a van turbo. I LOVE it. I can not compare to a stock wheel and the ATS housing. However if I am loosing anything with the WW, it am sure it is EXTREMELY NEGLIGABLE,,, Not enough to bother me.
I like the sound,,
Nothing better than rolling up next to a big rig pullin a hill with our trailers, and have the driver holler over the CB. "Hey,, is that YOUR TRUCKS turbo I hear whistleing?" OVER HIS??? YEP!! It is!!!
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #6 of 17 (permalink) Old 02-19-2007, 09:34 AM
Location: Imperial, MO - 20 miles south of St. Louis, MO
[/ QUOTE ] - Hmmmmmm [img]/ubbthreads/images/graemlins/confused.gif[/img] that's interesting. My old X with over 170k miles on the odo easily will make at least 27-28 lbs. of boost and I'm just running the Edge Evolution programmer with my mild mods including the WW/ATS Housing combo. I think it may make a little more. I do have the TurboMaster waste gate controller and have adjusted it to open at 25 lbs. of boost so as to prolong the life of my turbo. What are you using for a waste gate controller? Do you have any leaks? I did not lose any boost. I've got video clips showing how ridiculously fast my boost goes up to 25 lbs. - like seconds [img]/ubbthreads/images/graemlins/shrug.gif[/img]
*SOLD - 2000 X ltd.,white/parchment 4X4 loaded,285/75/16 BFG's,dvd,converted 06 oem grill,Xtint,New style clear headlights & clear corners,Fumoto,cut front bumps,Bilstein's,ass'd X badges & ass'd door PSD badges,ISSPRO EV gauges,clear cab lights, Wet Okole front seat covers, Weathertech visors,Pro-Comp steer stab.,Tymar Perf.intake, AIH removal mod w/boost tap,muffler delete turbo back Magnaflow 4" SS exhaust,WW,ATS Housing,Turbomaster controller,CCV Bypass,Edge Evolution Programmer(Extreme every day including towing),Cryo treated Power Slot rotors all around w/Hawk LTS pads,Duralast Gold Batteries, etc HD Heritage Softtail I Love! Will return to boating when sons get older at 2mm LOTO, MO! Harley much cheaper on fuel! Joined the other side with a 2004 2500 HD CC SB GMC Duramax...got a great deal!!
Work hard, play hard; strive to be the best at whatever you are doing!
Jeff27 is offline
post #7 of 17 (permalink) Old 02-19-2007, 11:35 AM
his bigger turbine housing reduces boost too
99.5 cc longbed zf6.
zoodad
hpx 203*
$17 home made ccv
6637
5" canon
F5 dp chipped- 80 econ and 120
autometer ultralite boost/pyro
tankhieu6 is offline
post #8 of 17 (permalink) Old 02-19-2007, 02:10 PM Thread Starter
My Photos: (6)
Thanks for all of the responses. Just to clarify and be sure of this were all taking about the compressor housing right?
Seen here:
http://i9.photobucket.com/albums/a72...lethousing.gif
I just wanted to ask becuase im aware of upgraded exhaust sides as well. The price seems a bit much for a compressor housing but then again if its going to do the job right then its worth it. Now im getting mixed feelings about the WW, not that its going to be bad but its probably better to just save the money.
I do love the turbo spool, what can I say im a turbo person... I own multiple turbo eclipses so yea. Id love more spool but what im after is an overall well rounded turbo.
More to come...
post #9 of 17 (permalink) Old 02-19-2007, 03:15 PM
Kanman's Avatar
I have both the ATS Housing and the WW. Although I do agree the WW is not as efficient as the stock housing. I have zero problem hitting 30 lbs of boost in a heartbeat. If I really peg it I have seen 31 or 31 lbs. I have only the stock wastegate actuator.
Kanman is offline
post #10 of 17 (permalink) Old 02-19-2007, 03:18 PM
Kanman's Avatar
Seen here:
Yep, thats the one were all talking about. Although I am not an ATS fan AT ALL. Their housing is top notch. It will do what it is designed to do, and that is eliminate surge. My vote, do the ATS housing and forget the WW. Unless you just want to hear tons of whistle ALL the dang time. I think there is still a sound clip in my signature somewhere with ATS Housing and WW. You could always hold out just a bit longer and get an aftermarket turbo...
Kanman is offline
post #11 of 17 (permalink) Old 02-19-2007, 05:33 PM Thread Starter
My Photos: (6)
Thanks! [img]/ubbthreads/images/graemlins/cool.gif[/img]
More to come...
post #12 of 17 (permalink) Old 02-19-2007, 09:38 PM
Pappy19's Avatar
My Photos: (6)
I have had the ATS housing and the WW for over 100k and I hit 28lbs of boost with my DP on 80Econo every time I WOT. Yes, it makes alot of screamin' noise, so when I pass those Dodge Rammers, they hear me go by. Like has been said, if the WW added to the ATS pushes less air flow, then it's not that much, and I don't mind. Just make sure you get it balanced, and if you have over 75k, just get the whole turbo rebuilt and balanced with the added ATS and WW from Dennis at ITPDiesel and no more worries.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
Pappy19 is offline
post #13 of 17 (permalink) Old 02-19-2007, 11:29 PM Thread Starter
My Photos: (6)
See what I dont understand, and correct me if im off track is this...
From my experience with turbos if you take one apart internally and or change the wheel you NEED to get it rebalanced. I dont follow how one can just replace the wheel with a WW unit and such. Ive been toying with turbo cars for years and this is how its always been especially considering the speeds turbos spin at.
I know tons of people on here do it regurally and seem to have no problems but im a little skeptic. As far as the ATS housing I know that this doesnt factor in since its just the housing. I also know of an ATS turbo unit that I could replace my stocker with, I believe its the .83 version not the 1.00 version maybe I should look into this over rebuilding my stocker. (which by the way is fine to date)
More to come...
post #14 of 17 (permalink) Old 06-05-2013, 11:25 PM
How is the spool up and throttle response with the ATS housing?
2001 F-250 Lariat, 4x4, Short bed, Supercab, Auto trans, 7.3L Powerstroke, Built trans, 6637 intake, BD billet compressor wheel, 4inch MBRP turbo back exhaust, Straight piped, Glowshift guages, PHP 6 pos. chip, Leveling kit, Rancho RS5000's, Nitto Trail Grappler 35's, N-Fab prerunner bar.
Built
Tough
Kd8324 is offline
post #15 of 17 (permalink) Old 06-07-2013, 10:08 AM
terryf350's Avatar
ww and ATS housing
The ATS housing is a cure for surge when you add a chip to your truck and you tow up hills.
The original WW did the same thing, but didnt always work.
So I dont consider them performance items.
The WWII will add power and eliminate surge.
If you are trying to cure surge you can try a ww or you can get an ATS housing.
If you want more performace out of your stock turbo get a WWII (and no surge). I would add a turbomaster also.
Hope this helps.
Terry
2016 F350 Lariat Shortbed CrewCab 4x4 6.7.
B&W, Hellwig Bigwing swaybar 7271, Bedrug, Husky X Act Contour floormats. Fumoto F106N, Bullrings, Ford wheelguards.
20 Foot Cimarron Gooseneck Horse Trailer
Sold:
2003 F350XLT Shortbed CrewCab 4x4 7.3l 6 speed. 3.73 LS, 9900# GVWR Package. 333,000 miles
1991 F250XLT Supercab 4x4 7.3l E4OD 250,000 miles.
terryf350 is offline
