Ats ported shroud compressor housing vs. 6 position chip - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 06-05-2013, 10:54 PM Thread Starter
I have a 2001 7.3L powerstroke that I'm looking to add another upgrade to but I'm not sure which one would be the best choice, I'm looking into installing an ATS ported shroud compressor housing or a power hungry performance 6 position chip. If someone could help me out with the decision or maybe throw in thoughts from anyone who has either installed on their truck or know someone who has that would be great!
2001 7.3L powerstroke, built trans, 6637 intake, bd billet compressor wheel, mbrp 4 inch turbo back exhaust, sct livewire tuner.
Kd8324 is offline
post #2 of 10 (permalink) Old 06-06-2013, 10:34 AM
you should get both because you will get turbo surge when towing
with out the ATS thats what I found out
redrocker is offline
post #3 of 10 (permalink) Old 06-06-2013, 11:44 AM
I just put the ATS ported housing on my 01. Not really a seat of the pants difference in performance but I'm pretty sure the spool is quicker. Not sooner, just quicker.
There is a slight difference with the housing, it almost has to be with the larger inlet, but in my opinion, it's way over priced.
2001 Lariat, F250, 7.3, 6-speed, 3:73, Ford AIS, MBRP 4" turbo back, ATS ported housing, 205 t-stat, Infinity DX w/DP Tuner 80hp tow, coolant filter, Hutched & Harpooned, EGT & Boost gauge. Fuel Mavericks with 285/18, 86k miles(Jan-2017) Bought brand new April 2001.
aclasshog is offline
post #4 of 10 (permalink) Old 06-06-2013, 11:46 AM Thread Starter
Ok thanks. Do you know if there is a noticeable performance difference with the ATS housing, I've read around but I've seen mixed reviews.
2001 F-250 Lariat, 4x4, Short bed, Supercab, Auto trans, 7.3L Powerstroke, Built trans, 6637 intake, BD billet compressor wheel, 4inch MBRP turbo back exhaust, Straight piped, Glowshift guages, PHP 6 pos. chip, Leveling kit, Rancho RS5000's, Nitto Trail Grappler 35's, N-Fab prerunner bar.
Built
Tough
Kd8324 is offline
post #5 of 10 (permalink) Old 06-06-2013, 11:49 AM Thread Starter
Ok thanks for the help ! I have the money for one or the other in your opinion since you have the ats installed which way would you go ?
Built
Tough
Kd8324 is offline
post #6 of 10 (permalink) Old 06-06-2013, 03:00 PM
I'm certainly not smart enough on these trucks for someone to make a $400 decision based on my comments but I'm really happy with the housing. My truck even sounds different after installing the housing and 4" down pipe to match the rest of my 4" system. Also, the mileage seems to have improved, at least by the overhead display, I havent crunched the numbers yet but I have all the fuel receipts. As long as you have the intake and exhaust to compliment the larger housing, there has to be more flow, and of course, no more surge.
In terms of noticeable performance gains, I'm sure they're there, but it's difficult to notice with the butt dyno.
post #7 of 10 (permalink) Old 06-07-2013, 11:03 AM
terryf350's Avatar
ATS housing
The ATS housing isnt a performance mod per se.
It is there to eliminate surge while towing when you add a chip etc.
In my opinion.
Thanks,
T
2016 F350 Lariat Shortbed CrewCab 4x4 6.7.
B&W, Hellwig Bigwing swaybar 7271, Bedrug, Husky X Act Contour floormats. Fumoto F106N, Bullrings, Ford wheelguards.
20 Foot Cimarron Gooseneck Horse Trailer
Sold:
2003 F350XLT Shortbed CrewCab 4x4 7.3l 6 speed. 3.73 LS, 9900# GVWR Package. 333,000 miles
1991 F250XLT Supercab 4x4 7.3l E4OD 250,000 miles.
terryf350 is offline
post #8 of 10 (permalink) Old 06-07-2013, 11:23 AM Thread Starter
thanks, but why do you not consider it a performance upgrade? im curious because it seems to me that the choked flow would increase spool and throttle response and because it seems that all the aftermarket performance turbos i look at for the 7.3 have the choked flow on the compressor housing so it must be helping with something right?
Built
Tough
Kd8324 is offline
post #9 of 10 (permalink) Old 06-07-2013, 03:43 PM
I respectfully disagree. The housing increases the intake to the compressor by 77%. This decreases the intake loss leading to the eye of the impeller, allowing more air to enter.
2002 F-250 CCLB 4x4 XLT, 7.3, ZF-6 with Midwest Short-throw shifter, ESOF, 3.73 R&P, HPx line, FRx, Racor prefilter before pump, Amsoil bypass filter, Coolant filter too
txgp17 is offline
post #10 of 10 (permalink) Old 06-18-2013, 11:22 AM
terryf350's Avatar
why
because when i put it on there was no noticeable increase in performance when i installed it.
Now when you add your 6 pos chip it will eliminate surge when towing, but so will a ww2 and it will add performance.
I have both.
Terry
Sold:
