Attaching fuel pressure sender - Diesel Forum - TheDieselStop.com
 3Likes
  • 1 Post By Big Horn
  • 2 Post By Big Horn
post #1 of 14 (permalink) Old 01-24-2019, 12:08 AM Thread Starter
Big Horn's Avatar
I know this has been kicked around a lot- I took RT’s advice and others and purchased an electric fuel gage to run into the cabin. As I still run the fuel bowl I was going to use the passenger side, bottom pressure port which as I understand is the post filter port.
I’m guessing that this way I’ll be able to see fuel psi under a load while driving as well as getting a glimpse of filter condition in bowl.
I picked up the Auto Meter 8463 fuel gage. Directions says for high vibration / race engines the sender should be remotely located to the fender well.
I don’t know if the 7.3L would be considered high vibration. Has anyone had any issues mounting the sender right to the fuel bowl? How many have relocated sender to a remote location. Thanks!
2002 F350 7.3L / 4R100 - 4WD CC DRW 8 Box, AIH Delete, Gauges- Pyro, Trans Temp, Boost, Fuel Pressure, TS-6 tuner, Zoodad Mod, Mishimoto 31 row Trans cooler, Mobil 1 ATF, Trans return line ATF filter, Hutch/Harpoon Mod, Air Lift Load Lifter 5000 rear air springs, Rancho 9000 shocks, Timbrens on the front.
Big Horn is offline
post #2 of 14 (permalink) Old 01-24-2019, 12:12 AM
klhansen's Avatar
My Photos: (180)
My guess would be that the 7.3L would be considered high vibration, as would about any diesel.
A hose from the port to the sensor mounted at the firewall or fender would eliminate any vibration.
RT should be able to tell you if he's had any issues with his setup.
), AIS,
regulated return,
klhansen is offline
post #3 of 14 (permalink) Old 01-29-2019, 01:43 PM Thread Starter
Big Horn's Avatar
OK—simple item, but I’m stuck and hoping someone can offer a better suggestion if there is one. On a search of the above subject a thread came up in which the OP stated he bought an extension fuel line from Strictly Diesel—runs from fuel bowl to remote sender location. I spoke to their customer service and the extension fuel line they carry is only for the 6.0. (I don’t understand the difference- I thought both engines used a fuel bowl) I have contacted both Strictly Diesel & DieselORings and apparently all they carry for the 7.3 is what I already have -the fitting (#4 thread/O-ring) and 90 elbow, & Schrader valve that goes in the fuel bowl back port. In my discussion at DieselORing we discussed the max fuel psi being in the neighborhood of 65psi (+ or - ) and using barbed fittings, fuel hose, and double hose clamps. Can someone give some insight or better way to do it- maybe RT if he’s online.
Thanks!
Big Horn is offline
post #4 of 14 (permalink) Old 01-29-2019, 01:49 PM Thread Starter
Big Horn's Avatar
I guess my initial thought was we use very small hydraulic lines on our equipment at work for guages and such and I would think the hydraulic hose would be compatible with diesel fuel. IDK
Big Horn is offline
post #5 of 14 (permalink) Old 01-29-2019, 03:38 PM
klhansen's Avatar
My Photos: (180)
Most any hydraulic shop can set you up with 100 psi rated hose and push-on fittings. That's what I have on my fuel supply lines from the fuel bowl to the heads. Adapting to the SAE o-ring fitting should be easy if the fuel sending unit threads are tapered pipe threads.
), AIS,
regulated return,
klhansen is offline
post #6 of 14 (permalink) Old 01-29-2019, 03:49 PM Thread Starter
Big Horn's Avatar
Thanks Kevin. I haven’t even looked at my Hutch Mod kit yet, so looked it up on line and found this: (attached). (Parker Push-Lok fitting)
Big Horn is offline
post #7 of 14 (permalink) Old 01-29-2019, 05:12 PM
brian42's Avatar
I have the ISSPRO EV2 fuel pressure gauge. I'm using the "stock" setup from ISSPRO with a straight fitting on the lower port and have no problems.
The Money Pit
2003 F-250 7.3L PSD FX4 CCSB, Dual Alternators - 160/80 SS, T500, FRx, 6.0 IC & TC (w/Derale), S&B, RR 4/4 Wheel, EBPV-less, RR OCR, IH Up-Pipes, Hydra (PHP & GH), ISSPRO Gauges, FTVB, 4" MBRP, H&H, Racor PS120, 140A Alternators, North Stars, Dynatrac, XRF, ATS Springs
brian42 is offline
post #8 of 14 (permalink) Old 02-02-2019, 10:09 PM Thread Starter
Big Horn's Avatar
Just an update- I ordered my push-lok hose (1/4”) and push-lok fittings (1/8” mnpt / 1/4” hose i.d. After a lot of consideration I decided to mount the 2-1/16” fuel psi gage just to the left of the 12v accessory (power point) plug for a cleaner look. There was no factory switch in that location for the passenger air bag—area is deep, but space is very limited....and you have to get the hole centered just right—you can see the view from the back side of dash. I can see the gage face well from the drivers seat, figured I didn’t need it right in front of me as one of the discussions earlier was it isn’t something that needs constant attention.
I haven’t used any of the push-lok items before so one thing worth mentioning that I found after digging through lots of literature from the manufacturer was that the push-lok hose has to be used with the push-lok fittings so as to guarantee a secure hose that can’t come off the barbed end.
69mach1377 likes this.
Big Horn is offline
post #9 of 14 (permalink) Old 02-03-2019, 09:22 AM
69mach1377's Avatar
Nice, how about a pic at the fuel bowl?
2000 F250 XLT 4x4 SC 7.3 w/Auto Tranny w/ TC L/U Sw & shift kit, 3 autometer gages, Super Zoodad, PHP Hydra chip, 4" DP/Exhaust w/dual 3.5" outlets, 275/70/18 Kumho AT51s on 8.5" rims, 08 AlumDiffCvr, Bilsteins, 31 row trans cooler, WW, BPV delete, AIH delete, hutch, harpoon and billet FPR (70psi), trans cooler bypass delete by accident, rear air bags, Jimmijammers.
Jayco 26BHS elite, no RV parks...just the woods if possible.
See my album for a recent pic.
69mach1377 is offline
post #10 of 14 (permalink) Old 02-03-2019, 05:53 PM
jleedog's Avatar
Nice and clean setup, now I am considering doing the same.
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #11 of 14 (permalink) Old 02-03-2019, 07:29 PM Thread Starter
Big Horn's Avatar
Thanks- I’m waiting on my fittings & hose (ordered on eBay) As soon as I get it plumbed I’ll post a picture.
Spent a good part of the day running the winch power- 2/0 welding cable (+ & -) through the front of truck, up to the engine compartment, positive to a 600A Disconnect, to 500A in-line ANL fuse, and to battery. I bought the hydraulic crimper for attaching the cable lugs/eyelets and it really worked sweet!
Big Horn is offline
post #12 of 14 (permalink) Old 02-04-2019, 12:37 PM
BS Hauler's Avatar
I have a ISS PRO fuel gauge also. Its sensor mounts directly to the fuel bowl. Has worked flawlessly for 7 years and is very stable on accuracy.
02 F350 Lariet CCLB 4wd Dually 7.3 6sp M. 122,000 miles, Manual hubs and transfer case.
Stock as of yet. So far have bought
4" MBRA turbo back with muffler
GTP 38R BB turbo and WWII wheel and high flow housing, Non EBV pedestal, Adrenaline HPOP.
New IH up-pipes, Aluminum intake plenums, 203* Therm with aluminum housing, Boost relief valve, all new boots, FPRx and HPRx. Coolant and Trans Filter kits. Max AC Assist control Valve. 8 gauges,
Boost,Pyro,Fuel,HPOP,LPOP pressure. Water,Oil and Trans Temp. Need tunes and injectors yet.
03 26' CM 4 Horse trailer and 25' GN flat bed.
06 F-350 Lariet CCSB SRW 4wd Auto 6.0 78,000
miles. Atlas 80 with Ed's lifetime, Blue spring, MBRP 4" turbo back with muffler, Bully Dog for monitoring. So far no problems.
BS Hauler is offline
post #13 of 14 (permalink) Old 02-04-2019, 01:33 PM Thread Starter
Big Horn's Avatar
I looked up their website (gage that you and Brian42 have), look like good gages—- maybe something for the future if I have issues with the AutoMeter
Big Horn is offline
post #14 of 14 (permalink) Old 02-18-2019, 01:43 PM Thread Starter
Big Horn's Avatar
Installed: I bought a 90 degree fitting from Diesel-O-Rings, Push-Lok fittings & 1/4” hose from JEGS- rated for gas/oil/diesel 300 psi. For now just zip ties but I have 1-1/4” black split loom on the way to clean up the fuel hose, boost psi line, and gpr wire to gauge across hood cowl.
Again, Thank you to all the knowledgeable people on this site and for their help. I only joined as a lifetime member to give back to the forum $ and to help with administration of the site, it’s been very valuable to me—-
here’s some pictures- the pic of the fuel psi gauge is at idle, rev it up and it didn’t fluctuate, looking forward to seeing what it does on the road:
69mach1377 and jleedog like this.
Big Horn is offline
