Banks Big Head Actuator - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 25 (permalink) Old 05-03-2006, 01:21 PM
My Photos: (38)
Re: Banks Big Head Actuator
isn't running all that boost and having the comp not know it bad? I know as far as gas motors go its crutial to up fuel in times of higher boost.. what is teh difference for diesels? I know the mechanics of the engine, as I am a mechanical engineer, but why can you up boost w\o more fuel and or not breaking things
You have to let go of that gasser theory. You are correct in gasser worlds, the most dangerous situation is too lean, that is why fuel has to be upped with more boost.
Diesels however accelerate by adding FUEL not air, therefore they need AIR AIR and more AIR. You could say there's really no such thing as 'too lean' with a diesel.
That it's not a major concern to the engine at elevated boost levels. It is set the defuel by the stock MAP limits is for performance/detuning and emissions reasons.
gregrob is offline
post #17 of 25 (permalink) Old 05-03-2006, 01:30 PM
Any one have a link to Dennis
at ITP for the boost regulator
Do I need this mod if I get the
big head actuator my mods are
super chip program Hi per tow
4" turbo back exhaust
K&N intake
ATS housing
thanks for all the help
(in spending more$$$$) [img]/ubbthreads/images/graemlins/smile.gif[/img]
redrocker is offline
post #18 of 25 (permalink) Old 05-03-2006, 01:42 PM
My Photos: (38)
K&N intake
ATS housing
http://www.itpdiesel.com/store.php?c...on=show_detail
gregrob is offline
post #19 of 25 (permalink) Old 05-03-2006, 02:30 PM
Greg gave ya the link there. You'll need it, yes, if you add the Big Head... unless you grandma drive it all the time. [img]/ubbthreads/images/graemlins/wink.gif[/img]
02Powerstroke, the main issue with higher boost numbers is that past around 25-27 psi the stock turbo gets outside its efficiency range, and compressing the air further than that just generates excessive heat and not much more helpful dense air. Over time the heat can damage the turbo. From what I understand, adding an ATS housing to the stocker bumps the efficiency line up some, so you can run up higher than 25 psi and still be creating efficient boost.
As for damaging the engine... well, there's a truck belonging to Wide Open Performance with compound turbos, makes up to around 100 psi from what I understand... on the STOCK PCM: no programming of any kind... yet. [img]/ubbthreads/images/graemlins/cool.gif[/img]
ryaneverk2 is offline
post #20 of 25 (permalink) Old 05-03-2006, 02:50 PM
My Photos: (22)
You don't need programming if you have huge injectors that spray a ton of fuel at stock pulsewidth. In fact, I've heard of instances where jody has basically built programs that less pulsewidth than stock to get better control of high flow injectors.
Hammer
TheHammer69 is offline
post #21 of 25 (permalink) Old 05-03-2006, 03:23 PM
Hammer, does Zane's truck already have huge injectors?
edit - that's a silly question... it must! [img]/ubbthreads/images/graemlins/cool.gif[/img]
post #22 of 25 (permalink) Old 05-03-2006, 04:18 PM
My Photos: (38)
Bet that's not on stock headbolts and gaskets. [img]/ubbthreads/images/graemlins/wink.gif[/img]
gregrob is offline
post #23 of 25 (permalink) Old 05-03-2006, 05:13 PM
Woopsie... yeah, there's those small details that should be mentioned. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
But with the Big Head, we're generally talking 25-32 psi.... not 100. [img]/ubbthreads/images/graemlins/smirk.gif[/img] [img]/ubbthreads/images/graemlins/blush.gif[/img]
post #24 of 25 (permalink) Old 05-03-2006, 06:25 PM
My Photos: (5)
Some report good luck adjusting the OE waste gate tighter 3 to 6 turns. Some report breaking the rod while trying.
For a stock truck IMO put your $$$ elsewhere.
Priceless...Thanks....R
2001 F-250 PSD SWB CC, 3:73 Ls, 4R, PMT.
Triple hpops, 1000hp vaporware injectors, dual reg return 1" feed to each head, triple sd fuel pumps, dos turbos + 1, triple 6647 air filters, Quadruple disc T/C with elephant man transmission, 6 pos Moe betta chip stacked with banks 6 gun, edge ez and sooper chit tuner, cryo'ed PMR's, fuzzy dice a pine tree air freshener and JJ's/HC's.
rustler is offline
post #25 of 25 (permalink) Old 05-04-2006, 12:11 AM
My waste gate is blowing open at 22 psi. if I tighten up the rod some will this help solve my problem.
thedieselkid is offline
